Question about Creative Labs ZEN V Plus MP3 Player
Frozen creative zen v plus 4 gb
I was deliting a recording and it got stuck i tryed to turn it off and its still stuck and i pressed the reset button lots of different times and ways but its still stuck on a blue screen that says deliting
Muzica
Posted on May 06, 2008
    President:
  • 4,402 Answers
Replace hard drive
http://www.hardwarezone.com/articles/view.php?cid=9&id=1331
Posted on Apr 24, 2008
Mp3 players stuck on line in recording
I had the same problem. I opened my zen V plus and noticed that the recording switch did not have the proper tactile feedback, which means the spring is somehow jammed and the contact blade can open or close the contact randomly. I scratched away the top half of the plastic casing (which was abnormally soft) and removed with a tweezer the tiny blade that closes the contact. I refit the whole thing back together and it works fine. Obviously the voice recording function is gone, but personally, I don't care...ht tactile feedback (spring not working properly. So I decided
May 30, 2009 | Creative Labs ZEN V Plus MP3 Player
Zen V plus says processing while being stuck on line in recording
if it is stuck for about 30 min then u have to reset there's a small hole below the power,used paper clip to reset.
Frozen
Usually it takes a couple of tries before the computer will recognize it if it's frozen. Once the computer recognizes it, format it immediately and that should fix it.
Apr 22, 2009 | Creative Labs Zen Stone Plus MP3 Player
My zen is frozen on creative
If a reset does not work then try this: First, back up all of your music and do this: Turn off the player and disconnect it from the computer. Then press and hold the play/puse button and turn it on simultaneously. The player should be in recovery mode. Scroll down and select format (all) and let it format. Then reload all of music back onto your player and it should work like new. Hope this helps!
Feb 20, 2009 | Creative Labs ZEN V Plus MP3 Player
My creative zen is frozen
Did you try the reset button on the side under the on/off slider?
Jul 12, 2008 | Creative Labs ZEN V Plus MP3 Player
Frozen on radio station
on the side, near the power slider, there is a small hole. Gently stick the end of a paperclip in there and it will re-set the player.
Jun 24, 2008 | Creative Labs ZEN V Plus MP3 Player
My Zen Freaking Froze Up!!!
Reset button to left - use a paperclip. If its a 4gB it might be faulty.
Apr 27, 2008 | Creative Labs ZEN V Plus MP3 Player
Creative Zen V Plus Frozen on the product title screen
this helped me as after it rebuilds the libary then it always froze on a song let the battery run out!
this worked for me straight away and i had tried loads of other ideas this actually came from the tech guys !!!
  1. Detach the player from the PC if it is connected, and turn off the player.
  2. Press and hold the Play button while powering on the player.
  3. When the player displays the Creative logo, release the Play button
  4. Select Format (All) and select Yes to format the player.
  5. After the player has finished formatting, select Reboot.
  6. Re-transfer the tracks to the player.
Feb 16, 2008 | Creative Labs ZEN V Plus MP3 Player
ZEN V Plus frozen on creative screen
you might need to format the player by holding the play button as you press reset, this will bring up the options to reset of format the plkayer update firmware etc etc.
Oct 02, 2007 | Creative Labs ZEN V Plus MP3 Player
Zen V Plus 4 GB
Have you tried updating the firmware of your Zen V Plus? I've had mine for almost an year and haven't had these issues -- I updated the firmware as soon as I unpacked it.
try downloading the
MP3 player recovery tool from Creative's website (the tool contains the latest firmware update available -- 1.15.03). Plug your ZV+ into your PC, run the program and let it update the firmware. Then format, reload your music and try it.
By the way, before updating the firmware, let the battery have a full charge, ok
Aug 09, 2007 | Creative Labs ZEN V Plus MP3 Player
Creative Labs ZEN V Plus MP3 Player Logo
63 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
