Question about Tomtom ONE GPS Receiver
Hi my tom tom dose not hold a charge for two long . can you buy a new battery and have it fitted
SOURCE: tom tom one battery change
I too dropped my tom tom go 300. It appears the battery was disloged as it will only work if attached to another power source; AC Adapter or cigarette plug. Does anyone know how to open the case to check on the battery?
Posted on Nov 03, 2008
  • 373 Answers
SOURCE: What do you use to charge the tom tom 910 in the house
In the box you have a 'desktop' mount. Looks like the windscreen mount without the ******.
Also you will have got a mains power lead.
Plug the lead into the 'desktop mount' (Left hand side) of the stick up bit.
Plug in and put your 910 onto the mount. It will 'Click' into place
The green light will shine to show it's charging.
To release the unit from the mount PRESS in the button in the middle of the screen top rim and lift off.
Remember to turn of the power at the socket to stop wasting electricity
The usb part of the desktop mount goes into your pc so you can connect to TomTom home or just plain old 'back it up'
It is ok to have power switched on or off when connect to the pc, there is no need to unplug the jackplug.
Hope this helps
Posted on Feb 28, 2009
  • 59 Answers
SOURCE: tom tom will not switch on
try charging the tom tom fully and then reset while it is charging. a tom tom will not reset unless the new battery is fully charged which may take some time if you only have a car charger.
please give me a fixya! rating if this helped.
Posted on Apr 05, 2009
  • 297 Answers
SOURCE: my tom tom one won't charge because the charging
She charges on USB with a PC. If USB port suplies power, not all do.
Seperate home charger for sale.
Or replace original.
I hope you talk apot that cable to cigarette lighter.
Mind you I have a Go 300
Posted on Apr 17, 2009
  • 503 Answers
SOURCE: My TOM TOM G920 battery doesnt hold charge for
QUick and dirty this is how it should go. Might be a little different so use some caution.
1- Remove the 4 screws from the outer corners of the gps unit. These are on the back in the corners.
2- Try sticking a small (JEWELERS/PRECISION) screw driver between the two halves of the case. There are small snap locks around the case, these are what you are trying to get to open up.
3- When you get the two halves seperated do not pull them apart. Look carefully inside you might see wires running to tha back half of the case, check on these and see where they go and what they are connected to. If you are lucky they are just speakers and they will have a quick connect on them.
4- Once you have the case seperated, the battery should be right there, remove the battery and install the new one. NOTE-- IMPORTANT sometimes you cannot get the right battery but you can get the same one but with a different end on it. IF YOU are CAREFULL you may be able to get the end off the original battery and put it on the new one.
Hope this helps you out and good luck.
Posted on Mar 15, 2010
The Battery in my Tom Tom one does not take a charge and show green after hours of charging . Can I get a new battery fitted?
Yes you can do it yourself, the battery is available on eBay. Then check YouTube for a video on how to do the replacement.
Jul 12, 2017 | GPS
No charge on tom tom 1 sat nav. if i wiggle it it will charge but i cannot hold it all day
the battery is wekend you need to change it try buyng a new battery anf format it to hold more
Feb 24, 2011 | Sony Televison & Video
My Tom Tom XL 325 wont hold a charge while left off
Hi, leaving the unit in the cradle exposed to the sun during hot days has been known to fry the battery causing loss of battery capacity. perhaps this could be your problem. I replaced the battery in my last GPS 4 times because of this before I analysed the problem. This will most likely be outlined in your user manual too. You might also compare the output capabilities between your blackberry and tomtom charger - it is entirely possible that you are starving the unit of a decent charge if the blackberry charger is not to the same current capacity as the tomtom charger.
Mar 19, 2010 | Tomtom One XL GPS Receiver
Battery not holding charge
hi dave_hanc93
you say its not holding a charge, but is it charging?
plug the charger in and make sure the light is on on the charger, then on the map screen, tap the screen where the satellites are. on that screen on the top right is the charge indicator. is it green and moving from left to right? if not, then its not charging.
try hooking it up to the home dock to your computer and check and see if its charging on the home dock.
let me know how you make out.
bill
Oct 08, 2009 | Tomtom GO 910 GPS Receiver
My tom tom will not hold a charge.
  1. This can be sovled by buying a new battery from a place like batteries plus
Aug 31, 2009 | Tomtom ONE 3rd Edition GPS
Tom tom will not switch on
Apr 04, 2009 | Tomtom ONE 3rd Edition GPS
Tom tom one battery change
Feb 28, 2008 | Tomtom GO 300 GPS Receiver
Dvd player dose not charge battery
how do i get a new battery for my dvd and if there a 1800-number that i can call thanks
Feb 20, 2008 | Durabrand Portable DVD
How to replace internal battery
Remove the Front facia surround Undo four screws holding internal works to outside body You will need a T6 star screwdriver for this. Remove internal works from body at the base you will see silver foil covering feel over this you will find 4 T5 star screws securing this remove these and also remove speaker by two locating T8 star screws. Gently remove the electronic board keep all locating cables intact You will then see two T4 star screws holding battery holder remove these and the plastic holder .Unclip battery and disconnect from Pcb Board fit new battery and reassemble. .
Jan 07, 2008 | Tomtom GO 300 GPS Receiver
Tomtom ONE GPS Receiver Logo
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
