Screen menu problem of HCL Monitor
My screen shows monitor menu automatically. It remains in middle of screen. I exited the menu but it remains on screen.Pl.help to solve the problem.
  • 732 Answers
Jain rajendr, You or electronics technician will need to verify proper operation of your monitor's internal AC to DC power supply first. When very strange things start to appear on the lcd panel, the first place I would look would be the units SMPS/inverter power supply. 12fixlouie
Posted on Jun 04, 2010
I am having hcl monitor, recently monitor shows automatically contrast 100 message in red colorer box, i tried to use eixt button on the monitor screen but dos't work. how can solve this problem,
what is the motherboard model number ? what computer model are you using
what is the model number of LCD
what do you mean HCL, what is that ?
Oct 15, 2010 | Computers & Internet
Menu bar appears automatically in front of monitor and automatically uses it.
My SAMTRON monitor 56V is having a problem now..
The control menu of monitor settings which will appear
when the monitor control panel is pressed(Brightness,Contrast....) is coming frequently at my monitor without activation...
Now when the monitor is turned on, the control panel will come,and will not go even if we change the settings..
The control panel is switching between the CONTROL LOCK and UNLOCKED mode during each 5 seconds....So now I cant see anything on my screen
at the middle of the screen due to this overlaying settings panel.
I is giving the same effect as the Menu key is pressed in the panel..(exit,-,+,Menu).
This problem started some 2-3 months before..
Today I hav put some etylene cleaning solution through the gaps to clean from dust... still no change...
If somebody having a remedy please help me..
Sep 11, 2010 | Computers & Internet
I have a small screen which appears in the middle of my main screen which is for adjusting contrast ect. I keeps popping up I can not remove it there are buttons in the front for exit ect which will not...
Sounds like the monitor menu is popping up. If so, it is not your computer but the monitor that is causing the problem. Is the monitor menu button stuck?
Aug 03, 2010 | E-Machines eMachines Desktop PC
Brightness indicator windows does not go away
Dear sir This is common problem observed in many monitors compaq,HP,HCL,IBM this is happens mainly in rainy season due to moisture,by this moisture monitor button circuit get rust inside and button pad remain pressed. so it shows a strip at the middle of monitor like contrast or brightness. So this is minor problem just replace the monitor display control button sensor or circuit.Temporarily you can warm up the monitor by hanging a bulb of 60 watt nearer your monitor to takeoff the moisture.(Dont hang the bulb too near to the monitor). It definitely solves your problem.
Have a Nice Day
Sep 17, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
HCL Monitor Screen Display Problem with Contrast menu showing up.
my hcl 17inches monitor is displaying contrast,brightness etc automatically
in the middle of the screen.even if i press the menu buttons it
disappears for a sec and comes again and again.what should i do to
solve this?
Sep 13, 2009 | Computers & Internet
Contrast Ghost
Good Luck
Sep 02, 2009 | Computers & Internet
Desktop is continuing to display contrast as 100
Dear mahendra
Welcome to Fixya Customer support
This is common problem observed in many monitors compaq,HP,IBM this is happens mainly in rainy season due to moisture,by this moisture monitor botton circuit get rust inside and button pad remain pressed. so it shows a strip at the middle of monitor like contrast or brightness. So this is minor problem just replace the monitor display control button sensor or circuit.It deffinately solves your problem.
Good Luck
Fixya Customer Support
Chandrashekhar
Jul 22, 2009 | IBM E54 15" CRT Monitor
Monitor not working
You will need to change the display settings for the type of lcd monitor you have, it is a wide screen I am assuming, you can change this by right clicking on the desktop select properties then settings the screen resolution should be on the middle left side and change this until you get a screen that you like There is also an advanced setting then select monitor at the top tab and change to refresh rate to the lowest setting (60 hz) this should get the HCL monitor up then change the setting until they dont work the operating system will revert to the previous settings if you cant see anything after a change. you may also need to use the automated setup on the lcd monitor select auto from the menu (osd). Now if you can not do this on the HCL lcd you may need to use that other Samsung monitor and then set up on that at the lowest resolution so that the lcd can be changed with a working screen. Lastly you may need to uninstall the samsung monitor drivers if you installed those, and leave the generic drivers in for the monitor (plug and play monitor).
I am making some guesses here as you did not tell me if the 1st Samsung monitor was a lcd also , and if the second HCL monitor is a wide screen etc what type of operating system are you running is also important 98 is fussy and 2000 is much more simplified as is XP , vista would be garbage (if you could get it to run on a pIII),
As for reasons for resolution problems, way too many variables to discuss in a short answer forum like this, sufficed to say that the resolution is different because in the past there were lower resolution (less pixels) on monitors, the refresh rates were different by manufacturers and the way the lines were scanned could be different, so setup of the monitor with the video card was also very important interlacing etc was also handled differently until that industry decided on a common standard.
I hope this helps you to get the monitor up and running.
Jul 17, 2008 | Computers & Internet
Computers & Internet Logo
167 people viewed this question
David Payne
David Payne
