Question about Kodak EasyShare CD33 Digital Camera
I did not use my camera for a couple of months now it will not turn on, although I have installed new fully charged batteries, Is there a reset button?
  • kakima Jun 02, 2010
    Did you leave the batteries in it for the duration? If so, you might have some corrosion on the contacts. Try cleaning them with a pencil eraser.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kodak Master
  • 102,366 Answers
Having gone over a month with no response, I assume this is no longer a problem.
Posted on Jul 07, 2010
Why doesn't it turn on?
Batteries installed correctly?
Batteries are fully charged? Even new batteries might not be, if they are rechargeable. It is also possible, although rare, that new alkaline batteries might be bad. Try replacing the batteries. Camera's internal computer might be bad. Take the camera to local camera repair service center or check manufacturer's customer service for additional help.
Hope this helps. Mike
Aug 18, 2015 | Kodak EasyShare M552 Digital Camera
Battery
Might be the camera's battery terminals, not the battery itself. Take a qtip and some isopropyl aclohol and clean the terminals in the battery well of camera.
Jul 23, 2013 | Nikon D3000 Digital Camera
Every time I change the battery in my pentax s5i the time and date revert to' as new' and I have to reset date and time. I have been using the camera for 6 years without this problem. Any ideas?
It may be a circuit designed to maintain date/time settings when the battery is removed that has failed.
Although a very good camera, I would imagine the cost of repair would be greater than the value of the camera.
A couple of thoughts though, if you are making an immediate swap with a charged spare battery, then there's a fault, you may find a firmware upgrade on the Pentax website which may help.
If there is a delay in replacing the battery, then having a spare, fully charged battery available at the time, may circumvent the problem.
Sep 06, 2010 | Pentax Optio S5i Digital Camera
Hello
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
Jan 02, 2010 | Kodak EASYSHARE M1063 Digital Camera
Kodak 8.2 will not turn on i've only had the camera for a couple of months . I have charges the camera for a day or two and it still will not come on
I think you mean the camera and not the ESS software. Since you have only noted the kond of the software and not the model of the camera I have written 2 possible solutions for you:
I hope this will help:
If your cam use AA batt.:
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
Battery support : KAA2HR,CRV3, 2xAA Ni-MH and 2xAA Lithium-Ion
Here are the steps:
3. Without the memory card,turn on your camera.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
If your cam use manufactors rechargeble batt.:
Make sure that you are installing a fresh/ full charge battery
Here are the steps:
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
Nov 25, 2009 | Kodak EasyShare One Digital Camera
Turns on then off. I have bought a new battery. Still didn't work. Charged it for hours. Still nothing. Only 4 months old.
Here are the steps:
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair w.4 months and no cust damage it is covered under the warranty.
Contact KODAK:
Nov 13, 2009 | Kodak EasyShare M1073 IS Digital Camera
Camera will not turn on although battery is fully charged
turn it were it would turn on then trun it of then back on
Jun 21, 2009 | Casio Exilim EX-Z77 Digital Camera
My camera won't turn on!
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
Feb 22, 2009 | Cameras
Camera powers off
I think battery went on protection mode and if you give couple of hours rest to battery by take out from camera and place it on shelf. Hope this trick will work.
May 28, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Using rechargable battery with new camera for the first time
If you are using a rechargeable battery, yes you should fully charge it before you use the camera for the first time. Rechargeable batteries are normally supplied without a charge from the factory, but not always. Fully charged batteries may be in storage for a long time before the camera is purchased and unlike modern dry cells, rechargables will not hold a charge for years.
Fully charge your battery, then run it until it has completely exhausted. If you plan to put the camera in storage at some point in the future, always recharge the battery every couple of months or so, to keep it in good condition.
Of course make sure the supplied battery is in fact rechargeable and not a lithium which should not be recharged.
If you found this info useful, please give me a thumbs up...
Mar 11, 2008 | Kodak Easyshare M753 Digital Camera
Kodak EasyShare CD33 Digital Camera Logo
44 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
