Question about LaCie (300728U) 250 GB Hard Drive
The hard drive is nott being recognzied
I have a p-4 machine & it does not even say that a device is been connected or anything like that .i tried downloading a driver but no use .
could sum one help
  • lausou May 06, 2008
    I did exactly as suggested: start; run; cmd etc. The hardrive is listed, so it is recognized. However, it still does not appear when I look for it in "my computer". Any other suggestion?
  • 537 Answers
Is the hard drive spinning? Do you have it powered?
Which OS are you in? If winxp or vista, try the following:
start | run
cmd
diskpart
list disk
If your disk is listed, then it is at least recogized by the computer. If not, then it's not connected properly or has a problem.
Posted on Apr 09, 2008
SOURCE:
My emachines says it cannot find the hard drive and i get blue screen after i restart it
Things to try:
1. Remove and reconnect the hard drive.
2. Remove all USB attached devices. Like other hard drives and anything non-critical.
3. Wipe and reinstall Windows once the hard drive is properly installed.
4. Replace hard drive if bad.
Jan 22, 2013 | E-Machines eMachines Desktop PC
Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive is causing my computer in windows to nott show the drive for t and saying i/o device error to appear. what would cause that and what
The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible. There is a connection problem such as a bad cable
click start control panel administration tools computer management device manager scroll through all of your devices
if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver
if you computer came with a motherboard disk the drivers could be on it
One bad lead can cause a computer to continue on a cycle to shutdown or fail to detect a hard drive
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a
secure connection and are not faulty or just replace them they could be faulty if its a flat 40pin ide
this will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions
or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Apr 05, 2012 | Western Digital WD Passport 250GB Portable...
THE MANUL THAT CAME WITH THE UNIT IS TOOOO SMAL TO READ even with classes.
Dont even bother to read the manual. These drives are plug and play; just hook it to your machine and start using it. Once connected, your machine will tell you tha *** has found another storage device.
Jan 09, 2011 | Hitachi 1TB External USB 2.0 Hard Drive
I have a StoreJet 25M 500GB. The other day it just stopped working wen I tried to access it. Now windows don't detect it. Not even in "Disk Management" Also every time i connect it, it makes a strange...
understand one thing....all USB devices act funny now a days....it's common...so i suggest u try it out on another machine...or on a different USB port...
if it doesnt work in WindowsXP try Win7
Sep 29, 2010 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Scanner does not scan anything. When i put it scan mode and try scan nothing happens.
Ensure the software for the printer and the drivers are installed correctly first.
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Oct 08, 2009 | Canon LaserBase MF3220 All-In-One Printer
Dropped my hard drive and my computer is not able to read it
It’s hard to even try to do anything with it…the hard drive is made of very small parts and when gets hit it cannot be put back without opening it and that is impossible as it need to be in clean room…let me know how that work for you and please do not forget to rate my service so we can improve on it with your help. God bless
Sep 28, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Simple Tech 250 GB external hard drive won't work
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
Sep 23, 2009 | SimpleTech Signature Mini 250GB External...
I have a Acom data hard drive Model HD500uhe5-72
Here's what you need to do:
1. Try connecting the HD (hard drive) into different USB ports of the computer.
2. Try another computer to see if the HD would be detected.
3. Try another USB cable.
Do you hear a clicking sound on the HD itself while it's turned on? Check the Disk Management of your Vista computer to see if the HD would be detected under the Disk Management. Please follow the steps below:
1. On your Desktop screen, right-click the "Computer" icon > select "Manage".
2. Double-click on "Disk Management"
3. Connect the HD while looking at the Disk Management. If the drive letter appear then, it's your Acomdata HD.
4. Check the status if it's healthy or unallocated disk space. If it appeared to be unallocated, you need to reformat the HD to make it work again.
To reformat it, just right-click on the drive letter that would appear and there's an option to reformat.
NOTE: Formatting a HD would erase all the data saved in it.
Have a great day!
Sep 21, 2009 | Acomdata 500GB External Firewire HD 500 GB...
My emachines computer wont recognzie my cd drive
A common cause of machines not recognising the CD drive is a little issue in the registry settings. Go here http://support.microsoft.com/kb/314060
and follow the instructions (runs a little program to fix the issue)
Jul 15, 2009 | E-Machines emachines (emachinees) CD-ROM...
How to recover data from lacie etherdisk when it does not keep a network conntection.
I'll have to look into it a little more but off the top of my head I would say that the nic may be going bad or some other component of the etherdisk. You can try opening it up and putting the hard drive into an enclosure and connecting it to a pc via usb to get the data, you can also then share the usb drive and use it over the network, however removing the hard drive may void any warranty you may have. If the hard drive is in fact bad then you should be able to replace it and then continue to use the device. I'll get back to you when I get more info about the device.
Sep 21, 2008 | LaCie Ethernet Disk (300788) 1000 GB...
LaCie (300728U) 250 GB Hard Drive Logo
81 people viewed this question
Top LaCie Computers & Internet Experts
Ekse
Marvin
Marvin
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
