Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
How do you open console on whirlpool LSN2000JQ2 TO REPLACE LID SWITCH? Do I have to do from the rear or front? There seem to be two plastic tabs on both sides in the back. How do they comes off?
  • 375 Answers
DO NOT REMOVE PLASTIC TABS!
Access is from the front. Remove screws located in the rear corners of the side trim pieces of the control panel. Control panel slides forward and then you can swing it up. You'll see metal brackets on both corners attaching the rear wall to the cabinet. Remove brackets. Disconnect plug with 3 wires on the cabinet. Pull cabinet up-forward.
Posted on Jun 02, 2010
I have a Whirlpool Gold Ultimate Care II washer (MOD# GSQ9669LW0) The washer stopped, was full of water and will not restart on any cycle or settings.
This problem sounds like a broken lid switch. Power to the drive motor is routed to the lid switch and if the lid switch fails, the machine will fail work on any cycle. Verify this by bypassing the lid switch.
Disconnect power to the washer then remove the screws securing the console to the rear of the cabinet.
Pull forward and up on the console and lay it back on the hinges.
Disconnect the lid switch harness connector by pressing on the tab located in the middle and pulling it up.
Jump a wire between the outer terminals of the disconnected connector from the top of the cabinet then reconnect power. The problem is indeed the lid switch if the machine starts. Check the lid switch plunger and the lid switch attachment to the cabinet. It may not activate properly if the mounting is loose, re-tighten it. Replace the lid switch if the plunger is intact and and if it is mounted tightly and properly.
The cabinet is attached to the rear of the washer by two brass-colored retaining clips. Insert a flat blade screwdriver into the turned-up edge of the clip, located on both sides, and then pry back to release the clip from the slot in the cabinet.
Open and hold the lid while grabbing the cabinet front opening then tilt the top of the cabinet toward you by pulling the cabinet away from the base. This releases the front and back slots of the cabinet from the tabs in the front and back of the base.
Using the side of your leg and/or body as a support for the front of the cabinet, carefully lift up the cabinet and lay the front on a cushioned floor to access the lid switch.
Remove the lid switch ground and mounting screws then release the wire harness from the metal retainers. Pull the lid switch connector out and install the new lid switch in reverse order of the removal steps.
Bring the cabinet to the front of the washer then slide the front bottom rail of the cabinet under the rail at the base of the machine then lay down the cabinet into position. Make sure the slots in the cabinet sit into the tabs at the base of machine.
Reconnect the lid switch harness then push the retaining clips back down into position to secure the cabinet to the rear of the machine. Reinstall and secure the console to complete the repair.
Jan 11, 2011 | Whirlpool Washing Machines
Tip
Replacing a Lid Switch on Whirlpool Top Loaders
This advice is for just about all Kenmore and Whirlpool model TOP LOADING washing machines. This is an easy repair that anyone with a little know-how and determination can perform.
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. The washer may have release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. If not equipped with this type of console, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame, just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job. Some models will have the switch located on the right-hand side of the lid rim opening, while other models will have the switch located on the left-hand side near the lid hinge.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, and then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle BEFORE you reassemble the console. This is easy to forget.
Good Luck.
on Feb 07, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Need to know how to replace the Lid switch
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 11, 2010 | Whirlpool LSQ8000 Top Load Washer
WHIRLPOOL LSB6000PQ0, FILLS BUT DOES NOT DRAIN, THINKING THE TIMER NEEDS REPLACEMENT?
Slide a old CD under the left and right front corners of the control console to release cabinet clips. Fold the console to the rear of the machine. Unplug the lid switch plug at the connector. Take a volt meter set for continuity and place the leads in the lid switch connector. Open and close the lid. If you have continuity the lid switch is good and you should replace the timer. If you have no continuity replace the lid switch.
Nov 03, 2009 | Whirlpool LSB6000PQ Top Load Washer
Mine wont spin
Your problem is more likely a broken lid switch. To test for this, lift the washer cover and look for a small hole in the washer top where the cover was. Push a toothpick gently into the hole and press the piece of plastic you see in the hole downward and listen for a soft clicking sound. If you don't hear a click or the plastic tab is not in the hole replace the lid switch.
Unplug the washer. Check the actuator on the lid that operates the lid switch to see if broken. Open the console of the washer. After removing the screws, the console will lift up and hinge back. Disconnect the plug going to the lid switch. Picture. Check the lid switch [lid closed] with an ohm meter from the wire plug-in leading to the switch. If no continuity, replace the lid switch. You will need to remove the cabinet to replace the switch. There are only a couple screws holding the lid switch assembly and a ground wire connection to the cabinet. Reassemble the washer and test the operation.
Unplug washer, remove the two console screws and tilt console back, remove cabinet clips, unlock lid switch block and then remove the cabinet. Remove the lid switch mounting screws, disconnect ground wire and remove lid switch assembly. Compare old switch to the new one. If the plastic sleeve of the new switch is longer, break off at the score mark. Pull wire partially out of sleeve before shortening sleeve. If the sleeve had to be shortened, the wires must be looped to take up the excess wire. Use supplied wire tie from the new kit. Install new switch assembly. New lid switch
Pay VERY close attention to assembling case back onto base so that sides engage tabs in base.
Sep 21, 2009 | Whirlpool Washing Machines
Instructions on how to replace lid switch on Whirlpool Washer, model # LSQ911OPW2
The following link explains how to replace the lid switch on a Whirlpool top loader:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
The part number (if you haven't purchased a replacement yet) is 3949247. If you have questions about this repair, or need additional assistance, please let me know. I hope this helps you.
Sep 11, 2009 | Washing Machines
Whirlpool Washer no spin cylcle
This could be a symptom of a defective lid switch. If you try opening and closing the lid and do not hear a distinctive "clicking" sound, your lid switch may need to be replaced. Some lid switches are located on the right-hand side of the lid opening with a small slot. It is activated by a plastic piece called a “lid strike” on the lid itself. Make sure the lid strike is not broken off. This will keep the switch from not working. On some model washers the lid switch is located on the left-hand side, in the rear, mounted under the casing near the lid hinge. It is activated by a rod on the lid hinge. Sometimes the rod can be adjusted if it is not making good contact with the switch. In either case, if the switch is not activated, it will allow the washer to fill and maybe agitate, but will not start the rinse or drain cycles. If you diagnose it and wish to attempt the repair yourself, the switch costs about $35 and is fairly simple to replace if you follow the steps below:
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. I believe your washer has release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. Or, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
You do not have to remove it all the way from the frame. Just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job.
2. Insert the brass-colored clips into the slot on the washer rear panel first, then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle and close the console.
I hope you find this helpful. If you have any questions (or if I'm incorrect in my assumption) please back and let me know.
Mar 31, 2008 | Washing Machines
Washer won't spin and drain water (does everything else)
If you are talking about a small plastic piece that is on the washer lid that pushes down on the lid switch when the lid is closed, it called a "lid strike". This is an easy fix and does not require opening the washer. If, however, the lid switch itself (which is mounted under the washer tub rim) is damaged you can replace it by following these steps:
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. The washer may have release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. If not equipped with this type of console, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. And, still there are some of the older models that have screws holding the console in place from the back. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
You do not have to remove it all the way from the frame, just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in on the side of the tub opening and a ground wire attached to the casing. Remove the connector plug, by pushing in on the release tabs on either side and pushing it down through the opening in the washer casing. The wire harness will be held in place by clips under the washer rim. It's a pretty easy repair job. Some models will have the switch located on the right-hand side of the lid rim opening, while other models will have the switch located on the left-hand side near the lid hinge.
Replacement parts can be found at searspartsdirect.com or repairclinic.com. Simply type in your COMPLETE model number (located along the opening of the tub rim under the lid) in the Search Index. A parts index with illustrations and prices is available.
Good Luck and I hope this helps you. Post back if you have any further comments/questions.
Feb 24, 2008 | Whirlpool LSR6232J Top Load Washer
How to replace a switch-lid on a whirlpool washer
You can check various appliance repair websites for self help manuals, or you can follow these steps:
I hope you find this helpful. If you have any questions please let me know by posting comments.
Have you purchased a lid switch yet? Most major appliance repair centers carry them. The price is about $35. If you have not purchased one yet, let me know what your EXACT model number is (located on the rim of the wash tub opening under the lid) and I will locate a part number for you. I hope this information helps you.
Jan 21, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Estate Lid switch
If you still need to get to the lid switch, just follow these steps:
Parts can be found at searspartsdirect.com and repairclinic.com. Just type in your COMPLETE model number (located along the tub rim under the lid) and there will be a parts index available to you with illustrations and pricing info.
Good Luck to you. I hope this helps you. Post back if you have any further questions/comments.
Dec 11, 2007 | Whirlpool LSR6232J Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
243 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
