Question about Insignia IS-LCDTV32 32 in. Television
Connecting a onkyo tx82 reciever to a insingia tv
I have a yellow cable. Is it IS-LCDTV32. Is it Receiver Video Out to TV Video out or in?
  • bbbbsando Apr 09, 2008
    How do I connect a Onkyo TX 82 receiver. I have a yellow cable. Is it Receiver Video Out to TV Video out?
  • 934 Answers
With the Onkyo you're just going to amplify sound... Thus it would be left/right audio OUT of Tv to left/right audio IN Onkyo...
Bill
Posted on Apr 09, 2008
Cant get tv audio through receiver directly (without satallite, Game, DVD connection)
If your TV doesn't support audio return channel (ARC, which is your TV audio routed back to the receiver through the same HDMI cable), you then need to connect your television audio-out to your Onkyo TV audio input, using a digital cable or an analog one according to the connections on the back of your TV. If you use a digital connection (optical or coaxial), make sure you have the proper digital port assigned to TV on the onkyo I/O assign menu/digital inputs.
In case your TV does support ARC, you need to activate it in the Onkyo's hardware/HDMI setup menu, either by turning on HDMI control (tv or receiver control each other via cable), or by turning ARC on (you'd probably need to activate ARC on your TV as well).
Hope this help,
M G
Jan 03, 2013 | Onkyo TX-NR609
I have the onkyo tx sr502, onkyo dv sp402e with the speakers..etc.. i'm trying to set up the whole thing to a normal television. that is, what cables go from what components, out/inputs..etc..and which...
Hi troy my names Josh i would be glad to be able to help you with your setup. First things first some people have a preference with they way they like things and for one do myself. I set up and intstalled my home theatre. I have receiver much like yours. On the back of your reciever you should have multiple inputs of coarse some for sound some for video. Your sound inputs would include digital optical, digital coax, standard analog which of coarse is the red and white RCA inputs and then a multi in which i doubt you have. So lets start simple If you have satalite or some form of cable i would assume you have your reciever box feeding a signal to your tv and the same for your DVD. I would recommend for your sat. that you connect your picture and sound strait to the tv rather it be component video or s video or standard video source or connect then for your sound strait analog to your tv thats just Red and White RCAs which will give you your sound to your tv. Repeat the same for your DVD depending on the kind of inputs and number of inputs you have on your TV. Now for the sound to your reciever. I ran digital sound from both my DVD and my Satilite to the reciever which means on the back of your recievers providing you have a similar configuration you would look for a plug on your dvd player that says optical thats your digital to run sound to your onkyo and the same for your sat or cable if you have a box look for either digital optical or a single digtal coax output that will also be ran to the onkyo for sound. You should only have two cables running to the onkyo one fiber optic from your dvd to the onkyo and one digital coax or fiber optic to your onkyo depending on the number of those inputs you have on the back of the onkyo you can run it how ever you want.
Oct 07, 2010 | Onkyo TX-SR502 Receiver
How do I connect a sony cd/dvd player to a onkyo receiver model Tx-SR600 to a Mitsubishi big screen TV model no. WS-65411 . I cannot get a picture for the dvd when I turn on the player I have sound coming...
If your using compsite cables, Yellow , Red and White cables the red and white is sound you connect to reciever, then yellow to the coposite in on the Tv Screen. If it is a HDMI cable connect to Tv Screen not Reciever. What cables are you using?
Nov 08, 2009 | Sony Televison & Video
No audio from pc connected using hdmi
Are you not getting audio to the television speakers and the onkyo reciever speakers when connected HDMI thru the reciever or just the television. If it is just thru the television then it is because the reciever is grabbing the HDMI audio signal and converting it so it does not reach the TV. If it is both then try changing the HDMI signal output from PCM to DOLBY DIGITAL on the computer. Your reciever may not be able to process the PCM signal of the computer. Does the reciever show a PCM or DOBLY DIGITAL display when HDMI is hooked up to it?
Oct 03, 2009 | Onkyo TX-SR606 Receiver
I have a onkyo 706 reciever and I can't get any TV sound
Component (i.e. TV) should be connected to plug labeled IN (signal IN receiver).
Jul 15, 2009 | Onkyo TX-SR606 Receiver
No surround sound from my PS3 through the Onkyo 5100. Video OK
Unfortunately only the higher end Onkyo Reciever pass audio over HDMI for sound. 605,705,805,905 exc. Your reciever will carry Video over HDMI but you will need a digital optical cable for sound.
thanks.
Jan 24, 2009 | Onkyo Audio Players & Recorders
ONKYO TX-SR606 Single output to TV
Hi there. for your receiver, the only time it can upconvert is when you go out as HDMI. In your current hookup (component out to tv) the signal from your cable (using a composite) will not be able to pass through the component cable. This means you either have to hook up your cable box using a component cable as well or add a composite cable (yellow) from monitor out of the receiver to the tv. Page 22 of the manual will show a diagram of the video signal flow. hope this helps.. ^_^
Dec 02, 2008 | Onkyo TX-SR606 Receiver
Xbox 360
There are a couple of options you can use.
Are your DVD and cable actually going to the Onkyo first and then to the TV? I am assuming it is, if you listen to the Onkyo when watching a DVD or cable.
The Onkyo receiver you have has 2 hdmi inputs and 1 hdmi output.
Does your Xbox360 have an hdmi output and that is what you want to connect to the Onkyo? Some do and some don't.
If your Xbox has a hdmi output and you are already using the 2 hdmi inputs on the Onkyo, you can not connect the Xbox using the hdmi, you have no more hdmi to connect to, so you must go thru one of the other inputs of the Onkyo.
The hdmi has the video and audio together, the other video options do not. you would need to run seperate audio cables as well.
Your Xbox should have a composite video (yellow RCA jack) output or a component video (1 red, 1 blue, 1 green RCA jack) output.
When you connect the Xbox thru, lets say the composite video of the Onkyo , you will also need to connect the audio from the Xbox to the Onkyo on the same input. It should be right next to the yellow RCA jack or right under it. They are 2 RCA jacks, one red and one white.
You will then need to connect the composite output of the Onkyo to the composite input of the TV.
When connecting like this, you will also need to select the composite input on your TV with your remote for your TV. Your TV should have an input button that lets you go thru all the different inputs to it.
you can also use the component video from the Xbox if it has that. But you must also run the audio to the Onkyo as well to the corresponding audio inputs of the component video input on the Onkyo.
This may sound a little confusing, but remember that the hdmi has the audio and video in one cable, the other video options do not, so you must run additional cables for the audio to the Onkyo from the Xbox.
Also remember whichever video you use from the Xbox to the Onkyo, you must also run that same video from the Onkyo to the TV and then switch the TV over to that input when you want to watch the Xbox on the TV
Jun 21, 2008 | Onkyo TX-SR605 Receiver
There is no tv slot on the Onkyo
You simply take and audio sample from the Tv to the Onkyo. You could use tape or CD input on the Onkyo it really doesn't matter. Just make sure you have audio out from the Tv and set the Onkyo menu to look at the input you select. If you choose to put it into the CD, make sure you select CD to listen to it. Assuming of course you have the speakers hooked up to listen to the Onkyo.
Bill
Apr 09, 2008 | Insignia IS-LCDTV32 32 in. Television
Installed surround sound, no picture on tv
I could not get my TV to recognize an S-video signal from my reciever either. I ended up just bypassing the reciever and running the video straight from the cable box to the TV. It might be a better option anyways as some quality is lost if you run it through the reciever.
Mar 20, 2007 | Onkyo TX-SR602 Receiver
Insignia IS-LCDTV32 32 in. Television Logo
59 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
