Question about HP Wireless Optical Mouse
Left click stopped working on HP optical mouse
Went to mouse properties and switched left click functions to right click as a temporary work around..... any guesses what might be causing this?
  • 39 Answers
Bad contacts? Honestly, these should be considered consumables. Should just pick up a new one for 10 bucks.
Posted on Jun 02, 2010
The left click is not functioning, right click works just fine but left click has no response whatsoever.
Usually either the lever (button) has slipped out of it's pivot point, the spring has come out, or the switch below the button is broken. To check, look around the edges for a small screwdriver slot or small screw. Open the mouse. Look at the button to see how it pivots. If on opening there are small pieces of plastic, discard the mouse. if it has just slipped out of its spot, realign and close the mouse, it should be good to go.
Mar 22, 2015 | Logitech LX3 Optical Wired USB Mouse Grey
My mouse pad left and right buttons stopped working on my HP pavilion. External mouse works OK. Also had a problem with tap function but now working after unchecking button function in settings!
Anytime a device, (keyboard, mouse, USB device) stops working, the very first point of issue is to re-install the drivers. Drivers have been known to inexplicably become corrupt and will malfunction or not function at all. In case such as yours, where the device is built into the hardware itself, it's best to go to Start>Computer, right click Computer, click on Properties, then click on Device Manager. Find the device that is malfunctioning, in your case, the mousepad, and right click on it...then click uninstall. Reboot your system and it will reload the drivers on restart. Nine times out of ten, this will resolve the problem. There is a slim possibility that your mouspad plug has become loose...if that's the case, you will have to remove the keyboard and reseat the plug. Youtube has tons of videos showing how to do this with various laptops.
Jul 09, 2014 | HP Computers & Internet
I bought a cordless mouse Fha 3410. When I let down the left click, it acts like double click, so do not let me select objects. I need to solve this problem, since I can not work normally in any...
Hi..
Go to - Devices and Printers in Control Panel
Go to - Mouse properties and check for the Doubel click speed.. See to that it is not set to the max.
May 30, 2011 | HP Wireless Optical Mouse
The click button on the left hand side is not working
this may mean it is dirty under the button, see if you can clean with a cotton swab, if it still does not work click start > right click my computer > properties > hardware tab > device manager > select the mouse and right click properties > click the roll back driver button.
i know you cannot click, which is why you will need to press the tab button a few times, this will move the selection around then you can press enter when it gets to the desired button.
if this does not work it means the mouse will need replacing, i hope this has helped you
Mar 30, 2011 | HP Wireless Optical Mouse
My HP Optical mouse Left Mouse Button has stopped working. The RMB still performs its function (so batteries on mouse still OK etc). I have tried shfitng the USB port etc but nothing seems to fix the...
Similar problem which I resolved today.
I have a hp wireless mouse model no. 5189URF. I bought this in hp online in April 2009. It needs 2 x AA Alkaline batteries.
Steps I did to resolve.
1. Removed battery cover.
2. Removed batteries below which 2 screws exist.
3. Remove 2 screws and remove the top casing of mouse.
4. You can see 2 very small square push button corresponding to left and right clicks in mouse.
5. try to press the left button and make sure its free. The issue seem to be that this button becomes rusty internally and lost contact. Therefore clicks are not recognized. You may need to press it repeatedly and also with a slight thrust circumferentially.
6. You can test your mouse in WIndows Help & support option linked with HP hardware diagnostics tool.
Oct 31, 2010 | HP Wireless Optical Mouse
Scroll pad not working on hp laptop mouse still works though
Need to enable Scroll function on the notebook.
Scrolling function is not working:
  1. The scroll function may stop working if the scrolling feature is disabled in Mouse Properties. To enable the scroll function, follow the steps below.
  1. Click Start , Control Panel . Select Classic View from the left side of the Control Panel window.
  1. Double-click Mouse in Control Panel, and then select the Device Settings tab in the Mouse Properties window.
  1. Click Settings , Virtual Scrolling . Select the boxes labeled Enable vertical scrolling and Enable horizontal scrolling .
  1. Click OK to save and exit the Mouse Properties window.
  1. After changing these settings, the scroll function on the touchpad will be enabled.
Jul 24, 2010 | HP Pavilion dv5000t Notebook
Want a left handed mouse
To change mouse settings in XP for left-handed users:
Click Start and click Control Panel.
Double click the Mouse applet.
Verify that the Buttons tab is selected.
Select the Switch primary and secondary buttons option is selected.
Click OK.
May 07, 2009 | HP Wireless Optical Mouse
Left button problem
This problem of yours has a simple solution:just change the left push to on switch.desolder the original one, get a switch from the local electronic market of the same type(if possible OR another one which will b placed correctly on d pcb and which ensures that d click works)
The problem is that the spring in d switch has lost it's physical properties,which is a aging problem.
Solder the new switch,and there u go,click click click,all working fine.
May 03, 2008 | Microsoft Standard Wireless Optical Mouse
HP Wireless Optical Mouse Logo
226 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
