Question about Nokia N900 Smartphone
Hi, my nokia N900 screen goes slightly duller after about 2 secs of being switched on, is this normal? Many thanks
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 114 Answers
It's completely normal. This means you have the display brightness set to lower than full brightness. To solve this, go to menu, select Settings, then select Display from Personalization menu and then adjust brightness to full and click save. now, switch off your device and then back on. Problem solved :-)
Posted on Jul 14, 2010
  • 100 Answers
Its not normal Nokia 900 has problems. These problems are small and are not simple. But also, these problems are solvable. you should concern with nokia outlet it may problem of your screen power or resolution of lcd it can help you or you can follow the nokia user guide site or can follow this
linkhttp://www.nokiausa.com/get-support-and-software/guides-and-demos
Posted on Jun 02, 2010
I have a nokia n900 and when I want to turn on the phone, it will not boot only be switched on and off (to restart)
Hello:
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Feb 10, 2013 | Nokia N900 Smartphone
Tip
Nokia N900 Firmware Update
Nokia N900 Smartphone Firmware Update v3.2010.02-8 (PR 1.1.1)
If your Nokia N900 smartphone is freezing, hanging or acting up I recommend you update the system software / firmware of your device. Erratic behavior can often be corrected by a firmware upgrade.
Here are the instructions for updating your N900 smartphone:
Over the Air (OTA) Update
  1. From the phone's home screen key in *#0000# or go to Device manager
  2. Select Options then Check for updates
  3. Follow the prompts on the screen to complete the update
Update via a Windows PC
  1. Download and install the Nokia Software Updater
  2. Connect your N900 to your PC with the supplied USB Cable
  3. Open the Nokia Software Updater application
  4. Follow the on-screen prompts to update your device
Update via a Mac
  1. Download the 770Flasher tool
  2. Download the latest available N900 firmware image
  3. Turn the N900 off
  4. Connect the N900 to your computer via USB cable (with the device turned off)
  5. Run the 770Flasher application
  6. Drag the firmware you downloaded in step 2 to the 770Flasher application (you will get an error regarding a USB device not being found, ignore it)
  7. Turn the phone on
  8. The update process will now begin automatically once the N900 boots
  9. You are safe to disconnect your phone from the computer when you see the normal desktop reappear on the N900 display
Update via a Linux PC
  1. Download and extract the Linux Flasher tool
  4. Connect the phone to your computer via USB cable (with the device turned off)
  5. Open a Terminal window and run 'sudo ./flasher-3.5 -F -f -R' (you will get an error regarding a USB device not being found, ignore it)
  6. Turn the phone on
  7. The update process will now begin automatically once the N900 boots
  8. You are safe to disconnect your phone from the computer when you see the normal desktop reappear on the N900 display
I hope that helps.
on Apr 02, 2010 | Nokia N900 Smartphone
My nokia n900 fn is locked. how to unlocked?
Hi, You can unlock your Nokia N900 safer and easier using unlock code. You can get the unlock code from www.onlinegsmunlock.com/nokia-n900/rs7wp9/ at affordable cost .
Here are the steps for unlocking a Nokia N900,
1 - Switch on your Nokia N900 without any sim card.
2 - Don't bother as to what is displayed on your Nokia N900.
3 - Compose #pw+CODE+1#.
4 - The Nokia N900 would then display the message "SIM Restriction Off" and will be unlocked!
Sep 08, 2012 | Nokia N900 Smartphone
How to unlock n900 from us to philippines
It simple to unlock the Phone from Network lock,you can get the Unlock code from the site
www.classicunlocking.com and UNLOCK it, you can follow the instructions below and unlock it step by step...
Nokia N900 Unlocking Instructions
Warning : Do not enter any wrong unlock codes on your Nokia N900 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia N900 mobile phone, your phone may get hard locked and sometimes become unusable.
Note :For Nokia N900 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia N900
Oct 13, 2011 | Nokia N900 Smartphone
I forgot my reset code
- To unlock you Nokia N900 (if forgot or lost lock code) you can unlock it using a master code. - To get the master code i need the IMEI code of your mobile phone. - With the help of
this IMEI code we can get the master code of your mobile and unlock the mobile and reset it with a new password.
- The IMEI number can usually be found on the sticker underneath the battery or by
typing *#06# into the phone keypad.
Hope this helps, please rate and leave a comment if the solution was helpful, thanks!
Aug 30, 2011 | Nokia N900 Smartphone
I dropped my Nokia N900 in the water, i dried it and placed it in the rice for 2 days hrs nothing happened, now when i plug in the charger it turns on shows Nokia in the screen and the loading then the...
MY DEAR,
the phone system has encountered a software problem due to the water that got into it, and the phone needs flashing.
visit an engineer near you for the MOBILE FLASHING
THANK YOU FOR CHOOSING FIXYA
Jul 29, 2011 | Nokia N900 Smartphone
Hi, my nokia n900 will not boot. When i try to switch it on the nokia logo appears then it switches off and the same the things happens over and over until I switch it off. Can you help?
hi...
if the phone is in warranty then goto the service center and update software.
if problems remains same then change the strip of the mobile from nokia service center.
Feb 01, 2011 | Nokia N900 Smartphone
How to eniarge font on nokia n900
Hi, download the user's guide to see how font is been enlarged
(retrevo.com/support/Nokia-N900-Cell-Phones-manual/id/23541ci957/t/2/).
Hope it helps.
Aug 06, 2010 | Nokia N900 Smartphone
N900 freezing and turning off
My advice is to download the latest firmware from Nokia website (which is version PR1.2) and install it through the USB cable provided to you. If this is something you can not personally do, please go to an authorised nokia service point and have this done for you. They should NOT charge you but ask about that before. For the battery removal issue, there is a way to bypass this process. Please press the power on/off switch for about 10 seconds. normally the device will unfreeze and go off without having to remove the battery. wait a few seconds and then you should be able to switch it on again.
thank you :-)
Jun 30, 2010 | Nokia N900 Smartphone
The phone turns on then the screen goes white
Hi Friend,
The problem may be because any software my got hanged or any virus may create this problem so kindly check it out.
Or you may try the below steps,
1.Switch off the mobile
2.Remove the battery,sim card and the memory card
3.Hold the Switch ON/OFF button for 20 to 30 sec's
4.Now Replace the battery and the Sim card
5.After it has Switched ON,replace the Memory Card.
Check and revert back
Thanks and revert back
Regards,
Ayyasam
Jul 31, 2009 | Nokia 6500 Slide Cellular Phone
Nokia N900  Smartphone Logo
171 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
