Question about Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator
Frequency determination Can you tell me which frequency rage the following HT 1000 wouyld be in, based on Serial Number? Serial Number 355ABE1974 X Thanks in advance,
  • slur2112 Feb 02, 2009
    Need to know the frequency range for a Motorola HT1000 SN/H01SDC9AA2AN
The number you are looking for should start out with a "H"
Example H01UCC6DB3AN, The 4th character "U", in this case denotes 806-870mhz range.
Post back with you model #
Podge
Posted on May 18, 2008
Where can I find unlock code for 1993 auddi Quattro 100 Bose stock radio, or can u hive it to me
The radio should have a serial number on the unit which also can be given to the Audi dealer and checked in their data base of radio security codes. The serial number will start with AUZ, one radio serial number for example is AUZ1Z9A1965412.
First you must turn on the radio. Then simultaneously press the FM1 and the AM buttons at the same time, and hold them down until "1000" lights up in the display. Use station preset buttons 1 to 4 to input the radio code.
If the code starts with "1", you don't need to enter this digit, move on and just use buttons 2, 3, and 4 because the "1" will already be displayed. If the code starts with "0" then press button 1 once to go change the "1" to a "0". Press button 2 as many times as the second digit of your code. Use button 3 for the third digit and button 4 for the fourth digit.
Once the correct code is shown on the display, you must once again press the FM1 and the AM buttons simultaneously and hold both of them down until the word "SAFE" appears in the frequency display. Then release the buttons. You will now have a radio frequency displayed and the radio has been unlocked. If you incorrectly enter the code twice in a row, you will have to turn the radio off and wait about an hour before you can try to enter the code again.
Look here for more details sjmautotechnik com
Feb 22, 2015 | Audi Quattro Cars & Trucks
I NEED TO KNOW WHAT FREQ. RANGE IS ON THIS SERIAL # 777FWLE408
Sorry, the serial number does not tell the frequency band of the radio. From this serial number I can tell you it is likely an SP50 radio, and it wwas produced Nov. 1996. You would need the model number to know the frequency band. The model number of an SP50 radio beginning with P93 would be VHF, and if P94 it would be UHF.
Note: With the mandated change to narrowband by Jan. 2013, only SP50 radios with a 00 (double zero) in the model number will do the new narrowband. Those models on wideband would have a 20 (twenty) in the model number. Example: P94YQT20AA2 would be a wideband UHF radio.
Best regards.
Aug 17, 2012 | Motorola HT1000, MTS2000, MTX8000/9000...
How do I manually program frequencies?
  • Hi, i can help.
  • This scanner is pretty easy to program. Follow these steps ---
  1. First press the "MANUAL" button to stop the scanner from scanning.
  2. Now pick a channel you want to store a frequency on. For instance if the channel will be 15 the press the number 1 and then the number 5 and then press "MANUAL" again.
  3. Now enter the frequency you want to program and include the decimal point.
  4. Now press the "E" button to enter the frequency into that channel.
  5. Repeat them steps to fill up your scanner.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Sep 19, 2011 | Uniden BC248CLT Base Scanner
I have a winchester model 88 308 serial # 160901A can you tell me year manufactured and location
See this page here Winchester Model 88 info, for a bit of info on your gun and find a serial number rage also. Hope this helps Fix Ya up.
Jun 21, 2011 | FPS Winchester 1000xs Pellet Rifle- 1000 ...
I bought 2 sets of the uniden DECT 1480-3. I want 6 handsets to work with one base. How do I add 3 handsets to a base that already has 3 handsets?
Jill,
The only logical way is to get the additional handsets to communicate with the base. And to do that you must set them to the frequency of the base. You Use guide will tell you how to set the frequency n the handsets to talk to the base. They way you set the original ones.
BUT, I doubt if this will work. Why? Because if that was the case if you and I had the same company phones, then I would stand outside your home and set the same frequency on my handset and misuse your phone. A great security risk in today's world. But there is no harm trying it out. Just set the same frequency on the additional ones as the base. If it works, then you will have that many more intercoms too. And do let me know if it works.
Apr 11, 2011 | Uniden Additional Handsets - DCT640 Phone
I have reset my uniden bc scanner and am trying to re porgram frequencies in i press hold, put in frequency number , press func. and then prgm. and it keeps telling me error. What could be wrong?
First, be sure that the frequency that you're trying to enter is withjin the scanner's tuning range. The ERROR message will appear if you enter an invalid frequency.
Second, follow this sequence to program a known frequency:
- Power the scanner ON.
- Press HOLD.
- Enter the number of the channel you wish to program.
- Press the Func and Pgm keys (channel number will display).
- Enter the frequency, including the decimal point.
- Press E to enter your information into the scanner's memory.
Need the owners manual for your scanner? You can download and print it, at no cost, here:
http://www.uniden.com/pdf/BC72XLTom.pdf
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Bill B.
Listening in since the 60's
Dec 08, 2010 | Uniden BC72XLT Handheld Scanner
What processor can use to upgrade my Pentium 4 2GHz in my HP M1270
HP Media Center M1270n desktop PC?
Here are the Product Specifications,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00280666&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=443756
Here is the Motherboard Specifications,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00297771&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=443756
The Asus PTGD1-LA motherboard, is a Proprietary motherboard, made Especially for HP.
HP's name is PufferM-UL8E
You won't find it on the Asus Support website.
Fortunately, HP listed basic information for CPU (Processor) Support.
When you look to the right of the CPU/Processor heading, you can see it states -
A) Socket LGA 775 (Processor socket)
Looks like this,
http://en.wikipedia.org/wiki/LGA_775
Processors that fit this processor socket, have the socket holes.
775 of them.
The LGA 775 processor socket, has the pins that go up into the socket holes of the Processor.
775 of them.
[The Socket 478 processor socket, that was before the Land Grid Array 775 processor socket, has the socket holes (478), and the processors that fit this processor socket, has the pins. {478 of them]
B) Supports processors with up to a 3.8GigaHertz frequency rate.
3.8GHz.
['Speed' is a slang term for Frequency Rate.
Giga = Approximately 1 Billion
Hertz stands for Cycles per Second.
3.8 Billion Cycles per Second.
Can also be stated as 3800 MegaHertz.
Mega = approximately 1 Million ]
C) Can support Intel Pentium 4 processors with HT.
Hyperthreading Technology.
D) Looking to the right of the Front-side bus (FSB) heading, you will see it states -
800MHz.
This means the Asus PTGD1-LA motherboard will support Pentium 4 processors with,
1) HT
2) UP TO a 3.8GHz frequency rate
3) Up to a FSB frequency rate of 800Megahertz.
4) Use an LGA 775 processor socket.
Now let's look at one example, of a chart of Pentium 4's with HT, that fits these specifications,
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Prescott_.2890.C2.A0nm.29_2
See the heading - Prescott (90nm)?
This means the processors in this chart, are based on the Prescott Core, and the 90nm architecture.
(nm stands for NanoMeter. Approximately 1 Billionth of a meter)
Looking at the headings in the chart, you will see Model Number, sSpec Number, Frequency, L2-cache, Front-Side Bus, Multiplier, Voltage, TDP, Socket, Release Date, Part Number/s, and Release Price.
At this point I would only concern myself with the,
Model Number, (If applicable),
sSpec Number,
Frequency,
FSB, (Front Side Bus),
Voltage,
Socket,
and Part Number(s)
1) Model Number:
The older Intel Pentium 4 HT processors did not have a Model Number.
Intel didn't start using a Model Number until later.
Model Number examples start with 517, 520, 520J, and so on.
Look for the sSpec Number, and the Part Number, for the older Pentium 4 HT's. They're printed on the top of the processor's case, and should be listed by the seller.
2) sSpec Number:
Intel brought this out.
Their way of marking a processor.
Another identifier for you to use.
3) Frequency:
The Maximum frequency rate, ('Speed'), that the Processor is supposed to be able to operate at.
4) L2-cache:
The small memory area for the Processor. The Processor accesses this small memory area first, because it operates at the same frequency rate as the Processor.
You can't change it, and 2MB of L2-cache, is the largest size for an Intel Pentium 4 with HT.
Just thought I would include this information.
(Ram Memory is next. Typically, Ram Memory operates at half of the FSB frequency rate. The Harddrive is next)
5) Front-Side Bus (FSB):
The frequency rate that the Processor transfers data (Information) to the Northbridge chip, and back from the Northbridge chip.
More on the Northbridge chip in a moment.
6) Voltage:
Pretty self-explanatory. The Voltage range the Processor will use.
You need the Voltage range of 1.25/1.4 Volts.
(1.25 Volts to 1.4 Volts)
Any Processor (That is Intel Pentium 4 HT, Socket LGA 775), that uses Voltage in this range will work.
7) Socket:
The type of processor socket that the Processor will fit in.
Has to be LGA 775.
8) Part Number(s)
Self-explanatory again.
The Part Number, that is stamped on top of the Processor's top case.
Part Number(s) is listed, because there may be more than one Processor in the Model Series, that fits the same specifications.
If there is no Model Number, refer to the sSpec Number, or Part Number.
The largest frequency rate (Speed) of Processor you can use, is a Pentium 4 HT that operates at 3.8GHz. (And fits in an LGA 775 processor socket)
Barring that a Pentium 4 at 3.8GHz cannot be found, you will know what Processors you Can use.
Scroll across the headings with your eyes, and start under the Frequency heading.
Find the frequency rate ('Speed') you wish to try.
Go across to the Front Side Bus heading. You should look for a processor listed that has an 800MHz listing.
Look at the Voltage.
All of the Intel Pentium 4 HT processors that fit in an LGA socket, use an 800MHz FSB, and are in THIS particular chart, fall within the same Voltage range.
Keep the Voltage range in your mind, as you look at the other charts below this one.
Socket.
You know you need a processor that fits in an LGA 775 socket.
Look at the chart below this Prescott Core (90nm) example.
Prescott 2M Core (90nm)
Use the above criteria above in this chart.
I wouldn't recommend any Pentium 4 HT's, in the Cedar Mill (65nm) chart.
It isn't that the architecture is smaller (65nm), but that the BIOS program,and version on your motherboard, may not be able to handle these processors listed.
I also do not see a BIOS update for one, and for two, if you make a mistake when performing a BIOS update, your motherboard becomes an expensive Frisbee, or doorstop.
You also do not want any of the processors listed under the Pentium 4 Extreme Edition heading.
(Mobile Processors are for laptops Laptops are M-O-B-I-L-E)
Northbridge chip.
1) The Northbridge chip, and the Southbridge chip make up the motherboard chipset.
(Does not apply to the new motherboards that support the Intel i3, i5, and i7 Core processors)
2) Chip and Chipset are slang terms for I.C.
Integrated Circuit.
http://en.wikipedia.org/wiki/Integrated_circuit
The Northbridge chip handles the faster processes of the computer.
Processor, Ram Memory, and High speed graphics.
(AGP or PCI Express. Not a graphics card in a PCI slot, nor Integrated Graphics on the motherboard. These are slower processes of the computer)
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
(CPU = Processor
Memory Slots = Ram Memory slots)
Looking at the diagram, you can see the slower processes handled by the Southbridge chip.
Looking back at the Motherboard Specifications, look across from the Chipset heading.
Northbridge: i915P graphics and memory controller hub
(MCH)
Southbridge: ICH6 Intel I/O Controller Hub 6
Uses an Intel 915P Northbridge chip, and an Intel ICH6 Southbridge chip.
Jun 27, 2010 | HP Media Center m1270n (PP132AA#ABA) PC...
Max RAM for Intel 102 GGC motherboard
Thanks to Intel website The board has two 240-pin DIMM sockets and supports the following memory features: * 1.8 V (only) DDR2 SDRAM DIMMs with gold-plated contacts * Unbuffered, single-sided or double-sided DIMMs with the following restriction: Double-sided DIMMs with x16 organization are not supported. * 2 GB maximum total system memory * Minimum total system memory: 128 MB * Non-ECC DIMMs * Serial Presence Detect * DDR2 533 or DDR2 400 SDRAM DIMMs Note To be fully compliant with all applicable DDR SDRAM memory specifications, the board should be populated with DIMMs that support the Serial Presence Detect (SPD) data structure. This allows the BIOS to read the SPD data and program the chipset to accurately configure memory settings for optimum performance. If non-SPD memory is installed, the BIOS will attempt to correctly configure the memory settings, but performance and reliability may be impacted or the DIMMs may not function under the determined frequency.
Jun 16, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
Sideband carrier??
im not sure carriers are measured in pounds, but SSB is a supressed carrier mode, in SSB only one sideband is transmitted and the carrier is inserted at the other end in the receiver. In AM mode the carried and both sidebands are transmitted. with regular am there is a carried and when modulation (your voice) is added a signal appears both above and below the carrier frequency at a distance relative to the frequency of your voice. so if you have a carrier at 1000 khz and modulated it with a tone of 100 hertz the signal will contain frequencies of 900,1000, and 1100 hertz, then its changed to SSB by supressing the carrier (1000) and one sideband (1100) if you are on lower sideband and (900) if you one upper sideband, and transmits the remaining frequency.
Nov 06, 2008 | Ranger RCI-2995DX Base Scanner
Microwave frequency
The frequency has to do directly with the the wave a microwave oven omitts. Frequency is a measure of the number of occurrences of a repeating event per unit time. Usually microwaves run at a frequency of 2.54 Ghz, a wave length of 12.34 CM.
Jul 25, 2008 | GE JVM1650 1000 Watts Microwave Oven
Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator Logo
167 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
