Question about GE Profile JTP56 Electric Double Oven
How do I find the part number for replacing control board for GE?
I gave a GE Profile Double oven *circa 1997), model number JKP45B0W1BB. It is flashing "DOOR LOCKED" on both upper and lower displays, even though the door opens just fine. I want to install a new Control Board, but I need to know the part number and where to order it. Anyone help finding the Part Number?
  • 375 Answers
WB27T10290
I would not be so sure about that the problem is in the control board. Check switches on the door lock assemblies first.
Posted on Jun 02, 2010
How do I fix the F7 problem?
This is a common problem. Basically your electronic control board needs to be replaced. You can find your part online appliancepartspros.com just enter you model number and a list of parts will be displayed for your unit.
Oct 28, 2015 | GE Profile JTP56 Electric Double Oven
F1 code comes up on my ge double oven
Hello & Welcome to FixYa
Error code F1 is displayed due to electronic oven control failure and the only way to solve this problem is by replacing the control board which is bad. Sorry for the bad news but hope you understand... Please get back to me if you have any other questions.
Kevin
Nov 25, 2011 | GE Profile JTP56 Electric Double Oven
Double wall oven F0 error code
The F0 error code means that the control board has detected a defect within the control board itself, the F0 code can be cleared by pushing the CANCEL/OFF button and if it goes away and returns all is well,however if a short time later the F0 returns the control board would need to be replaced.
GENE
Oct 04, 2011 | GE Profile 30" Built-In Double Electric...
GE double oven Model JTP56WOA2WW top oven won't heat up, fan runs, relay clicks, no heat
This indicates an open/shorted oven temperature sensor and to solve this problem the temp.sensor needs replacement. If you want to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Mar 27, 2011 | GE Profile JKP56 Electric Double Oven
Ge double oven, no heating
check that u have continuity through the elements if you dont then replace the element next if you do have continuity through both elements check to make sure you have power coming from the main control to the element if you dont have any power leaving the control board then replace the control
May 18, 2010 | GE Profile JTP56 Electric Double Oven
My GE JTP45WOV2WW Double Oven is beeping with an F2 code and I don't know how to stop it
F2 means the controller thinks the oven is over temperature. (590degrees if door is unlocked, 990degrees if door is locked). This is a problem with either your temperature sensor or the control board.
If the temperature sensor is about 1080 ohms at room temperature, it is very likely the control board.
These can be rebuilt: www.fixyourboard.com
Apr 01, 2010 | GE Profile JTP56 Electric Double Oven
Ge profile double oven. The bottom oven is beepin and f7 is showing. we have not used the oven today. what does this mean
HI, this is a Stuck button on the function pad or, the clock or ERC(control board) is damaged. Try to free the stuck button.(in some models, this is not an option). if the pad is fixed(keypad and board are integrated), simply replace the oven control board.
Jul 27, 2009 | Ovens
GE Profile JT952 Touch Pad Button Issue
Try this link
http://www.fixya.com/howto/h155060-dreaded_f7_error
Mar 28, 2009 | GE Profile JT952 Electric Double Oven
GE Profile-electric oven
Copper, F3 means oven temp sensor is open. You need to replace the probe. Easy job. Part number I have for this is WB23X5340, but double check your model number. Look it up on the net to see what you are going after...Catriver..post back
Sep 19, 2006 | GE Profile JTP18 Electric Single Oven
GE Profile JTP56 Electric Double Oven Logo
374 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
