Toshiba TV won't turn power on, while plugged on. I don't see flashing lights, or hear any kind of sound while trying to turn it on via remote, or on/off button.
  • DilectioKJ23 Apr 09, 2008
    How will I know if the fuse is good or bad? Is it like a house fuse, i'll see something broke inside, or what? The TV is only 3 years old, at best. Is this typical with TV's?
    Scholar:
  • 170 Answers
Check fuse inside set. if fuse is good. inspect board for damage.
if good try replacing your main regulator.
need more info
Posted on Apr 09, 2008
  • Scott Henderson
    Scott Henderson Apr 10, 2008
    checking a fuse is very basic. it should be a glass fuse, and you will usually see it next to where the power cord connects to the power supply. take the fuse out and inspect it. if good, then you prob need to replace your regulator. if you don't know what your doing then you prob need to leave it for a certified tech.
My 40 inch S400A Series Full HD BRAVIA LCD TV does not turn on. When i plug it in, the green light (next to the Red power light) blinks. If i try to power on via remote, the red power light turns on and...
this again sounds like the power supply,.if you hear a click when you push the power button, this means your main board is reading good so replace the power supply,.
Apr 06, 2014 | Sony BRAVIA KDL-40S2010 40 in. LCD...
No picture or sound
Looks like a power supply issue the only solution to fix this up is to get it repaired.
Goodluck..
May 03, 2008 | Toshiba 32HFX72 32" TV
Toshiba 32AV502R won't turn on even though green light goes on
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 30, 2012 | Toshiba 32AV502R LCD TV
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
We have a red light flashing on the front of the tv.It shut off and we don't know how to turn it back on.
A red flahing light is sometimes a Standby Mode. Does the power button on the remote turn it on.Sometimes the remote has multi funtions and you need to select TV for it to work.Try using the Power Button on the TV.Good Luck.
Jul 29, 2011 | Toshiba 44NHM84 TV
Hi Hi have a toshiba regza 32av555db that was working fine however it will now not turn on, the red standby light is flashing and the green on light flashes also. I have tried a different remote for the...
Problems it is not the tv remote control.This tv have a dying power supply board,that the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.
Jul 11, 2011 | Toshiba 32AV555DB 32" HDTV-Ready LCD TV
Lamp light flashing on toshiba 50" projection tv
TV tries to come on - yellow light next to power light flashes but then it turn itslef off.........It tries agin after few sceonds and sequence repeats. I can hear the sound but no video
Dec 29, 2008 | Televison & Video
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
Flashing power indicator
Sounds like a power supply problem unless there is a short in the deflection circuits causing the power light to flash. I'm afraid it'll take a technican to figure out what is wrong. If it's more than 7 years old, you might consider replacing it.
Jan 25, 2007 | Toshiba CX27F60 TV
Televison & Video Logo
Top Televison & Video Experts
