Question about Motorola Mobility ROKR E6 Smartphone
Well it got a little wet since than its screen has turned red saying usb bp pass through mode
Hi tarun, pls share how u solve your problem, i m facing the same issue :(
Posted on Jun 12, 2010
If u wanna sell ur dead moto rokr contact me I wanna use its body and stylus in my own moto rokr.. 9818506171
Posted on Jun 02, 2010
How can i unlock screen on motorola droid bionic because i forgot passcode?
This might help
Droid Bionic Stuck on too many unlock attempts Verizon Wireless Community
  • Power the device off.
    • Press and hold the Power button then select Power off
    • If the device isn't responding Remove / replace the battery
  • Press and hold Volume down and Volume Up, the press Power
  • Display shows Available boot modes
    1. Normal powerup
    2. Recovery
    3. AP Fastboot
    4. BP SBF Flash
    5. BP Only
    6. AP BP USB Bypass
    7. BP Tools
  • Use volume down to scroll to "Recovery", press Volume up to select
  • Once display shows Android triage screen, press Volume up & Down at the same time
  • Display shows Android Recovery
  • Options are:
    1. Reboot System now
    2. Apply Update from SDCard
    3. Wipe data / Factory Reset
    4. Wipe Cache partition
  • Use volume down to scroll to Wipe Data/factory Reset, press power to select
  • Display shows Confirm Wipe of all user data - This can not be undone
  • Use volume down to scroll down to YES - Delete All data - Press Power to Select
  • Device will perform format wipe
  • Display then shows Android System Recovery
  • Ensure reboot system now is selected then press the Power button to select
Oct 16, 2015 | Motorola Cell Phones
I have forgot my locked code? please help me
flash your rokr e6 . and your code is be default ....
for flash help go to this link..http://www.gsmindia.in/forum/p2k-series/11437-flash-your-motorokr-e6-at-home.html
or try this step..
Go to your Dial Pad and dial: WWW008W. To make the W hit the menu button while in the dial pad, then hit insert->insert wait to make the W .
You should see something like:
R533_G_11.12.08P
BP: R533_G_11.12.08PB
PFlex: GSZMCAUT678SW016
DSP: 63343400 TECHNOLOGY
Look at the numbers at the end of the first line for the version. The version shown here is .08P.
The Following are all Generic Firmware
R533_G_11.12.02P
R533_G_11.12.06P
R533_G_11.12.08P
Change Log - Nothing has changed until 08p which includes an EQ for Real player & Screen 3.
1. Download the file Motorola_USB_Driver_32_v2.7.6 to your PC and unrar it to your desktop so you can easily find it.
2. Install a program called "RSDLite" on your PC. To Download RSD lite Click thread for the file. For trouble free installation, if you are running Windows XP, you should have Service Pack 2 installed.
3. Download the firmware file that you want to flash to and unrar it to your desktop.
4. Start up RSDLite on your PC. You may be asked to install a number of drivers (5 or 6) to your PC. Point it in the direction to the motpcsdrivers folder you unrared.
5. Put the phone in Bootloader Mode - MBM mode by turning on phone while also holding down the Camera Button and the On/off button (These need to be all be held down together). The phone should start up with a red screen and say its in MBM mode.
6. Plug phone in using usb cable.
7. RSDLite should list the phone (this may take a minute or so. If it does not close down RSDLite and restart it). Start the flash process, by clicking the button on the top with the ??? and select the firmware file to install then click ?Start?. The process will take several minutes so be patient, the screen on you phone will turn off, but RSDLite will still show progress.
8. When the "Found New Hardware" screen pops up, select ?NO? for ?Can Windows connect to Windows Update?? then select ?Y? for ?Install Software from a specific location? and point it to the motpcsdrivers folder you unrared. Once the driver has installed, click on ?Finish? on the ?Found New Hardware wizard? to continue the process.
9. You will need to install quite a few drivers ? so just keep repeating. It may ask you to manually restart the phone ? if so, unplug the cable from PC, remove the battery for 5 seconds (make sure unplugged first!), put battery back in then turn phone back on.
10. Once its fully on, go to Setup --> USB Mode and change mode from "Mass Storage" to "Modem".
11. Plug phone back into the PC using the cable. RSDLite should say "complete" or ?PASS?
12. Unplug the phone again, turn it off and on. All should be complete.
You can now restore all your contacts, calendar and tasks back to your phone using MPT. (Be sure to remove the SIM card before doing this as the recovery function from MPT deletes any contact on SIM for some reason!)
Try This This Helps
by....ASHISH KUMAR
Jan 29, 2011 | Motorola Mobility MOTOROKR E6
My hone got wet and i imeadiately removed the battery i tried a hair dryer and letting the phone and battery sit in bags of rice. The phone comes on but is stuck on usb download mode screen at the bottom...
i droped y samsung intesity in water a few weeks ago. it was able to call out but now the screen will only blink the verizon logo and at the moment it says useb download mode. Is there anyways that i can recover my data form the phone?
Jul 02, 2010 | Samsung SCH-U450 Cell Phone
Hi my oldest daughter has a touch screen ipod but my 3 yr old had it now it is saying disabled plz put in pass word
  1. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPod touch to turn off.
  2. Press and hold the Home button while reconnecting the USB cable to iPod. When you reconnect the USB to iPod, the device should then power on.
  3. Continue holding the Home button while iPod starts up. While starting up, you will see the Apple logo.
  4. When you see "Connect to iTunes" on the screen, you can release the Home button and iTunes will display the recovery mode message:
  5. Restore and it'll download ~240mb firmware and you're done
Sep 19, 2009 | Apple iPod touch
Cant listen to music on ipod touch because its disabled
force it into recovery mode...here's how
  1. Verify you have iTunes 7.5 or later. Apple recommends using the latest version of iTunes.
  2. Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
  3. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
  4. Press and hold the Home button while reconnecting the USB cable to iPhone. When you reconnect the USB to iPhone, the device should then power on.
    Note: If you see the message "Charging... Please Wait" or you see the screen pictured below, let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again.ht1808_01.jpg
  5. Continue holding the Home button while iPhone starts up. While starting up, you will see the Apple logo.
  6. When you see "Connect to iTunes" on the screen, you can release the Home button and iTunes will display the recovery mode message:
    ht1808_02.jpgIf you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPhone and repeat steps 3-6.
Aug 10, 2009 | Apple iPod touch
Phone got wet stuck on download screen & vibrates
the phone needs service, when it got wet it damaged the mother board of the phone.
Jun 30, 2009 | Samsung Propel A767 Cell Phone
Samsung SGH-a707 solid red screen and says download! PLEASE HELP!
mAn i've gOt dA same pRoblem.............mA sgh a707 wAs fallen in water n aftR tHat i hAd da sAm eRror.........i took out da battery....n aFtr 2dAys mA cell was wOrkin..........
Jun 01, 2009 | Samsung SYNC SGH-A707 Cellular Phone
Nothing but the blue ring lights up
ok..idk if this will work but it might...first turn off the sansa...then turn the hold switch on (it should turn red). hold down the record button on the side of the player..then while still holding that hold the power button down...but keep holding them untill a screen shows up saying something about recovory mode..itll say to plug in the usb..u could do that..idk it that will work..it it doesnt instead of plugging in tthe usb in the computer..wait about 15 seconds after the recovory mode screen shows up and then hold down the power button for about 15-20 sec...then itll go all black (including the blue light) press the power button again like u would to turn it on...and everything should be back to normal..hope this helps...:)
May 04, 2009 | SanDisk Sansa e250 MP3 Player
Wont take photos outside
The symptoms you're describing could be caused by either the "Fireworks" special scene selection mode, or manual mode with too much exposure compensation. Look at your mode selector (back of the camera, upper left hand corner). Is the mode set to the still image setting (pointing at the liittle red camera)? Or is it set to special scene selection (SCN)?
If you are unintentionally in SCN mode, to get it out of "Fireworks", just turn the mode selector dial to select "still image" (pointing at the little red camera). Or you can also select an SCN mode more appropriate for outdoors. Just turn the dial to SCN, press the FUNC button, then press the left/right arrow buttons to select Portrait, Beach, Snow etc...
But if your mode selector is already in still image selection, then check to make sure that you're not in "Manual" picture mode. Turn the mode selector dial to "still picture mode" (pointing at the little red camera), then press the "FUNC" button. Now look at the bottom of the screen. If it says "Manual", press the "left" button controller once to select and put the camera in "Auto" still picture mode.
Feb 29, 2008 | Canon PowerShot A400 Digital Camera
Motorola Mobility ROKR E6 Smartphone Logo
Top Motorola Mobility Computers & Internet Experts
Unlockingcom
AJMAL KHAN
Tom Chichester
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
