Question about Intel Computers & Internet
You have just installed Windows 98.During testing,it fails to start after the starting Windows 98 message appears.What should you do to troubleshoot this problem?
    President:
  • 1,216 Answers
May be possible that it is the cd not the pc who is the culprit.you should try another cd to verify this.
may be possible that your windows has become corrupt
try to repair or re-install your windows.
Posted on Jun 02, 2010
4 Suggested Answers
  • 13433 Answers
SOURCE: You have just installed Windows 98. During
I would look into if the computer can run windows 2000 instead. 12year old system its been 9 years since I last really used it.
Posted on Jun 10, 2009
I would have a cold boot up with the command prompt to find out at what step that unit starts acting up. It is likely the hardware failure related problems.
Posted on Jun 04, 2009
stranger_ab
  • 133 Answers
SOURCE: fails to start
Insert the installation disc and select repair.
If problem persists, format the windows partition and install a fresh copy of the OS from a ORIGINAL CD.
Posted on Mar 27, 2010
Fails to start
Mar 26, 2010 | Microsoft Windows 98 Second Edition for PC
My AR-5316 dont work in network with computer i am using. it shows that "required user intervention" when i am printing cadd drawing.. what should i do?
Before starting the installation, make sure the USB or parallel interface cable is not
connected to the MFP.
Insert the supplied CD-ROM into your CD-ROM drive.
Double-click "My Computer" (
), and then double-click the
CD-ROM (
) icon.
When any of "Hardware Found", or "Found New Hardware Wizard"
messages appear during the software installation, be sure to click the
"Cancel" button.
Double-click the "setup" (
) icon.
If the language selection screen appears after you double click the
"setup" icon, select the language you wish to use and click the "Next"
button. (Normally, the correct language is selected automatically.)
Select the software packages to be
installed, and then click the "Next"
button.
The software packages with checkmark (
on the list on the screen will be installed.
Click the "Display README" button to show
the information on the selected package.
In Windows 95/NT 4.0, "Button
Manager" does not appear. In
Windows 98/Me/2000, do not select
the "Button Manager" checkbox.
because this is not supported when
using the parallel interface.
5
The next screen appears. Make sure that the parallel interface
cable is not connected, and click "OK".
Windows 95/NT 4.0 Windows 98/Me/2000
6
Check the contents of the package on the screen, and then
click the "Start" button.
The software packages to be installed will be displayed on the screen. If
inappropriate packages are displayed, click the "Back" button to select only
appropriate software packages.
28
7
Copying files for MFP driver installation and parallel interface
setup (This step will start if it was selected in step 4).
After confirming the message in the "Welcome" window, click the
Aug 06, 2009 | Sharp AR-5320 Black and White Copier
You have just installed Windows 98. During testing, it fails to start after the ''starting windows 98'' message appears. What should you do to troubleshoot this problem?
Jun 04, 2009 | Microsoft Windows 98 Second Edition for PC
Error code 2352
http://service1.symantec.com/SUPPORT/nav.nsf/pfdocs/2003020714354306?Open&docid=2003020714354306&nsf=nav.nsf&view=pfdocs
To run the Microsoft Windows Installer if Norton AntiVirus was installed from the CD
  1. Insert the Norton AntiVirus CD into the CD-ROM drive.
  2. Do one of the following:
    • If the installation program appears, then click Browse the CD
    • If the installation program does not appear, then double-click the My Computer icon on the Windows desktop, and then double-click the CD-ROM drive icon.
  3. Double-click the MSI folder.
  4. Do one of the following:
    • In Windows 98/Me, double-click the WIN9x folder.
    • In Windows 2000/XP, double-click the WINNT folder.
  5. Do one of the following:
    • In Windows 98/Me, double-click the Instmsi.exe file.
    • In Windows 2000/XP, double-click Instmsiw.exe if you have Windows 2000/XP.
  6. In the next dialog box, click Yes.
  7. After the rollback has finished, then reinstall Norton AntiVirus.
    Follow the instruction in Reinstalling your Symantec program after a failed installation or after you see error messages to start the computer without any programs running on startup and then reinstall your Norton program.
If these steps do not fix the problem, then go on to the next section.
To run the Microsoft Windows Installer if Norton AntiVirus was installed from a downloaded version
  1. On the Windows taskbar, click Start > Find (or Search) > Files or Folders.
  2. Ensure that "Look in" is set to the drive where you downloaded Norton AntiVirus, and that "Include subfolders" is checked.
  3. In the "Named" or "Search for..." box, do one of the following:
    • In Windows 98/Me, type the following:
      instmsi.exe
    • In Windows 2000/XP, type the following:
      instmsiw.exe
  4. Click Find Now or Search Now.
    You might see many files with this name. Look for the file with this name that is located in either the Symantec_Norton_AntiVirus_2003 or the your Windows temporary file location depending on your version of Norton AntiVirus.
  5. In the Search Results window, do one of the following, depending on your version of Windows:
    • In Windows 98/Me, double-click Instmsi.exe.
    • In Windows 2000/XP, double-click Instmsiw.exe.
    This will undo the changes that were made to your system during the first failed installation.
  7. After the process finishes, then reinstall Norton AntiVirus.
Apr 22, 2009 | Microsoft Windows Vista Home Premium...
Problem with booting-up on HP Pavilion dv9334us laptop
1.there is problem in screen fl inverter replace it screen will on
2.format and reload the windows
Mar 26, 2009 | Computers & Internet
Start menu wont show up
application softwares &system software in start menu
Feb 02, 2009 | Microsoft Windows 98 for PC
Installation failure
I have already started to answer on the original thread!, let's keep the conversation in one place.
Oct 08, 2008 | Computers & Internet
Installation failed
I think there is no need to install windows media player it was already located in your program accessories, better to check it. But you can only update media player with the latest version not to install it again.
Hope this will helpful.
Nov 24, 2007 | Microsoft Windows 98 for PC
Computers & Internet Logo
147 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
