Question about GE Spacemaker JVM1640SJ Microwave Oven
GE XL 1400 Spacesaver is not heating things up AGAIN!
My GE XL 1400 Spacesaver is not heating things up again. Same behavior as last time, but this time, ohm testing the magnetron did not see anything wrong with it. (See my post (name sclieu) 2 years ago about similar problem with the same microwave: http://www.fixya.com/support/t336131-ge_spacesaver_over_range_microwave_oven)
I am not sure if the HV Capacitor is bad. It has 3 prongs, not 2. Is there a way I can test to see if it's good or not? If I can't test the HV capacitor via ohm testing it, what is a safe way to test it during load? Could it be the damn magnetron again???
    Problem Solver:
  • 19 Answers
It's what, about 7or 8 years old? I'd buy a new one on sale. Probably not worth messing with just to squeeze out another year or two. You can pull out the Capacitor and take it to any electronics appliance repair place and have it checked for little or nothing, but if it's bad and you order a new one you have no microwave for a while. IF that's the ONLY thing wrong you're back in business.
Posted on Apr 25, 2017
SOURCE: spacesaver micro not heating
I have a spacesaver profile and after 4 1/2 years the magnatron went out. magnatron has a 5 year warranty so it was replace,But I had to pay for labor. 1 1/2 later it went out again. haven't replaced it yet. had a friend buy the same one at around the same time and the exact thing happened to them. I'm trying to find out if this a recall or if GE will stand behind there product. lets face it the time a microwave gets used at minutes at a time it really isn't much
Posted on Nov 18, 2007
  • 43 Answers
SOURCE: GE Spacesaver over the range microwave oven
GE Microwave ovens, and Microwave Ovens produced by GE but released under different brand names, have had several power problems for the past 20 years. Because it is so easy to sell parts and charge outrageous rates for repair GE never corrected the problems. They just continued it in the next model. They found that you would most likely purchase a new unit rather than paying $75. for a service charge, and $150. for labor plus parts (if out of warranty period).
Most failures were cold solder connections on the power relay board. These would come completely dis-connected after arcing and burning away the solder. Could be 1 month, could be years, but they knew it would happen. This power relay board feeds 120volts to the LV (low voltage) side of the HV (high voltage) Transformer. No High Voltage,,No cook. Everything seems to run normal, but if you listen carefully you will not hear the low tone from the HV Transformer. Over my thirty years in the business I have re-soldered rather than replace so many I couldn't count.
Next to that, a defective Magnetron.
Posted on Jan 25, 2008
SOURCE: What size are t top mounting screws on the GE JVM1350 spacesave
You may be looking for the philips flat head 1/4 x 28 tpi (threads per inch) threaded bolt that is about 4" long. The tip of the bolt does not have threads, which aids in locating the threaded hole in the top of the microwave:
General Electric's part number for their OTR microwave cabinet mounting screw is WB01X10180 (or AP3205964 or 942461 as listed on some repair parts sites).
A set of three is GE's p/n WB01X10125 (or AP3185225 or 910236 as listed on some repair parts sites).
This flathead screw is used on most Advantium Speedcook microwave ovens such as the SCA2001BSS03 or SCA2000FWW03 or SCA2001KSS03.
Here's a picture of three screws:
Posted on Apr 27, 2009
MicrowaveSvc
  • 9085 Answers
SOURCE: Wires to magnetron
It matters!
The wire from the high voltage transformer high voltage tap goes only to one side of the high voltage capacitor. No other wire is connected to that terminal of the high voltage capacitor.
The other side of the high voltage capacitor connects to the anode (A) of the high voltage diode and to the "FA" terminal of the magnetron.
The cathode (K) of the high voltage diode is connected to chassis ground.
The pair of wires connected to the secondary (thinner) winding of the high voltage transformer are the filament wires and are connected to the "F" and "FA" terminals of the magnetron.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
It has the overall wiring diagram and schematic.
For further free help, e-mail me at http://www.microwavecontrol.com
Posted on Jul 13, 2009
SOURCE: My spacesaver dated September of 2004 shuts off
I solved the problem by buying a new microwave and it was not a GE. I feel that GE should have had a recall on this problem, since it seemed to be a major problem in their system. I will never buy another GE product.
Posted on Oct 17, 2009
Have ge profile spacesaver xl sensor. will not heat strange buzzing sound and burning smell. clock, light, vent still work
This is most likely a defective magnetron, especially with the burning smell. There are two other parts that can be a problem, the high voltage capacitor and diode, all three work together to heat food. If the magnetron is the culprit, probably cheaper to replace the microwave oven.
Mar 02, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacesaver jvm1540 it runs, lights, fan works, just no heat. then slow heat, now heat again, but seems to take longer? please help
Sorry to read about your problem, I hope this helps you out.
it seems you may have defective magnetron, I suggest you contact a service company, that has the proper tools to check the problem...
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 27, 2010 | GE Spacemaker JVM1540 Microwave Oven
Light's on, plate rotates, no heat
When the microwave works properly but just doesn't heat, then the magnetron is bad and will need to be replaced. You can get the part and the diagram at partselect . com or repairclinic . com
Jul 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacesaver 1400 does not heat
The most common fault with not heating is the high voltage fuse. I advise to either take it to a authorised repair agent to prevent shock or injury as many components still hold a large charge even after being switched off. Otherwise reply to this post and I will talk you through how to repair.Good Luck.
Apr 15, 2010 | GE Microwave Ovens
GE Spacesaver Microwave no longer heats JVM3670SF02
I would bet that either the first time or this time it is/was the magnetron tube, which has a 10 year warranty on the part, you pay for labor. Check and see what they did the last time, but they did have some trouble with the mags in these microwaves. If it was the mag, I'm not sure what area you are from, but $200 is a little high just for labor.
Jun 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge XL spacesaver Microwave blowing fuses
I had the same problem.
Took it in to the local repair guy and he found the transformer was blown.
Cost $120 including tax
Jan 15, 2009 | GE JVM1630 Microwave Oven
GE Spacesaver XL JVM1341WW002 microwave broken door handle!
Its a free country Bage, but microwave energy is extremely dangerous! Repairs are not feasible unless performed by factory personnel under warrantry, and certified. I suggest you contact the manufacturer about the problem.
Ray
Nov 19, 2008 | GE JVM2050 Microwave Oven
GE XL 1800 quit heating
I don't like to pass on your problem but it sounds very much like either the high voltage supply ot the magnetron has bit the dust.
Either one would make the repair marginal at best.
This is apparently not a very good unit, many microwaves jsut kind of fade away as their magnetron emissions decay.
This one seems to have a bad rep. look at this link:
http://www.fixya.com/search/p489218-ge_xl1800_1100_watts_microwave_oven/not_heat
Sorry, have owned a lemon or two myself.
Aug 27, 2008 | GE XL1800 1100 Watts Microwave Oven
Spacesaver micro not heating
Your magnetron, HV diode, Capacitor, or control board maybe bad most of these components run with high voltage and difficult to test without the proper equipment
Oct 28, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacesaver doesn't heat
if you are as lucky as i was...i have a ge spacesaver model jvm130...same problem. first unplug unit and check fuse on the "power control module". if fuse is ok...unscrew the screws holding the "power control module" in place...carefully tilt module and see if a solder joint needs to be re-soldered. my problem was the solder joint under the front plug (5 large wire plug). you may have to unplug the three connectors to the board to get access to bottom. this is the second time i had to re-solder...last one was several years ago though. best of luck tennisrme
Aug 21, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
294 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
