Question about Sony FD Trinitron KD-34XBR960 34" TV
I have a Sony KD-34XBR960 that sound like it is
I have a Sony KD-34XBR960 direct view TV that sounds like it is turning on when the power button is pushed and the standby/timer light blinks, then nothing. No picture and no sound. Any suggestions?
    Problem Solver:
  • 10 Answers
Phillips has the same problem but if your tv actually turns on it could be a short or just a fuse sonys a better tv than phillips should be an easy fix call a repir guy going price for that problem is 75.00 dont pay any more than that. the economy is bad everyone needs the work be smart. make sure if you say yes to the work that the repair guy will waive the consultaion cost of usually 35 to 75 dollars, if you chose to have the work done.
Posted on Jun 02, 2010
Engineer seeks help with no-picture, no-sound, normal standby blinking
Could just be a power issue. I have not done much with CRT televisions except smash them to bits. I would open it up and try and look for anything obvious. Since it is taking so long to come on, I am wandering if there is a cap that is failing. It will be hard to know if there is no visual evidence of failure, and the only true way to measure is with an ESR meter.
Apr 24, 2013 | Sony Fd Trinitron Wega Kd-34xbr960 34 in....
Sony KD-34XBR960 has no power; working perfect, on next start up the usual pop when powered on with remote, but failed to come on. No flashing lights, nothing. Unplugged, waited 24 hours, plugged into...
The problem is in the power supply, the most common cause is an open fuse and open capacitors, if the set is more than 10 years old consideration should given in replacing the tv especially if a professional gets involved.
May 15, 2011 | Sony FD Trinitron KD-34XBR960 34" TV
Sony KD-34XBR960....problem is that screen is black; LED light blinks 7 times in a row pauses and then starts blinking again. Have powered off and no improvement.
This tv have two power ICS left side of the FBT-The Flyback Transformer.The big black block of plastic with a red wire with a cap hook to a CRT(tv tube).Replaced those 2 power ICS,tv will solved this LED power light flashing,tv will have stable power again,tv will work.
Oct 23, 2010 | Sony FD Trinitron KD-34XBR960 34" TV
We have a SONY kd-34XBR960 I turned it off and
Turning your tv off did not cause this issue, so don't blame yourself for that. A 6 or 7 blink shutdown is because one of the two switch mode power supply control ic's have failed. the part number on them is mcz3001. They are located on the "D" baord, i don't recommend replacing this yourself because even with a tv unplugged from the wall high voltages still exist in the set.
A repairman may preform one of the two following things, he may change the whole D board or he may replace the individual components. The repair will cost around $200 if they replace the components, and if they replace the board it will cost more.
Sep 05, 2009 | Sony FD Trinitron KD-34XBR960 34" TV
My Sony KD-34XBR960 has no picture when power button is pressed.
This is often caused by a faulty transistor, they breakdown over a period of time and can continue to work by shcok treatment ( like unplugging etc) but eventually collapse. The srvice center for your Sony may repair it or replace the whole board to the video section. Its a Bravia so expect a pretty expensive callout, somewhat cheaper to take it to a technician in this case
Aug 17, 2009 | Sony FD Trinitron KD-34XBR960 34" TV
Dear Sir, Is a 250.00 sony KD-34xbr960 a good buy(mfg date 6-05)? This unit is a sony "factory remanufacture" Thank you Arthur Dodge
Arthur,
Thats is a good deal, these sets last a long time and are very solid. I would have no problem paying 250 for that unit
Jul 16, 2009 | Sony FD Trinitron KD-34XBR960 34" TV
STANDBY LIGHT KEEPS BLINKING BUT NO PICTURE OR SOUND
just try unplugging it for a little bit and see how that works.
Feb 01, 2009 | Sony FD Trinitron KD-34XBR960 34" TV
Electromagnetic device or leaser device turn off a tv
y do you think it is you neighbour is there any reason
Jun 23, 2008 | Sony FD Trinitron KD-34XBR960 34" TV
Our set turns itself off by itself. Prior to this happening, it goes to a green screen. It usually happens after the set has been on for a couple of hours. We bought the set in April, 2004 and the warrantly has now expired. The longer we keep the set on, the more it turns itself off. Is this a tuner, on/off problem or the tube? Any estimates for repair?
Jun 15, 2008 | Sony FD Trinitron KD-34XBR960 34" TV
Timer/Standby light blinks but no picture or sound when power button is pressed.
I'm having the same problem. My stand-by light blinks 3 times though. The tv clicks as if it is going to turn on, but it never does. Is there a simple solution to this problem?
Dec 22, 2007 | Sony FD Trinitron KD-34XBR960 34" TV
Sony FD Trinitron KD-34XBR960 34" TV Logo
579 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
