Question about Garden
6.5hp i/c intek edge starts with prime runs a few secs and dies ??? I just bought this mower used. no info on history. ran fine for first two uses. the motor is on a scotts walk behind mower turf vac3 ? 3n1 ?
    President:
  • 1,545 Answers
Check the brass bolt that holds the carb bowl on. Remove it and clean the tiny holes on the smooth part above the threads. Carb and Choke cleaner should do this. This is actually the main jet for the carburetor and when partially clogged causes exactly the problem you are having. Clean the bowl too while you have it off.
Posted on Jun 13, 2010
  • 80 Answers
Take carburetor apart carefully clean and inspect float and needle also clean bowl retaining nut it is brass and has holes in it that need to be cleaned as well. A carb kit is inexpensive and has what you need as far as bowl gaskets and needle and seat.
Posted on Aug 30, 2012
Deffinetly a carb issue a good cleaning and maybe a bowl gasket and a needle and seat will fix it. nice engine when you get it fixed, take your time and do it right it will last forever
Posted on Jan 25, 2012
Will start but will only stay running if you prim it until its warm then runs fine
Lawn Mower Repair pt.1: starts & dies, Tecumseh/Craftsman ...
? 2:10
https://www.youtube.com/watch?v=IVYYYpAviPA
Mar 7, 2011 - Uploaded by Alameda Repair Shop
Spray with starting fluid and the engine runs a bit longer but dies.... I especially like how you use the gas can to hold up the mower, Classic :) ... After I started it up, it would only stay running for a few seconds before dying. .... LAWNMOWER REPAIR: briggsand stratton pulsa prime carb overhaul - Duration: ...
How to fix a gas lawnmower that starts then dies - YouTube
? 7:37
https://www.youtube.com/watch?v=caa0WrpxqyU
May 3, 2011 - Uploaded by SmallEngineRepairGuy
This is a how to video on what to do if your gas mower starts up then dies after a ... I have a different lawnmower and not very mechanical but this got my ... Got the job done and now i can do a thorough cleanout of it when i run it dry of gas. .... How to FixBriggs & Stratton Small Engine that Only Runs Off the ...
Craftsman 5.3hp starts but won't stay running... - DoItYourself ...
Dec 09, 2015 | Briggs & Stratton Briggs Stratton Intek V...
Have a 6hp craftsman mower starts and runs for 30 sec dies have replacer carb with running mower carb replaced plug replaced coil flywheel key fuel tank sounds like it is seizing up slows down for a
you have bad valves seats probably broken loose do to overheating replace short block or by new motor short block cost to much 300.00 new motor 225.00 to 245.00
Sep 07, 2014 | Garden
Engine is misfiring.
Put the old plugs back in. The new plugs my not be gapped correctly or one may be bad.
May 05, 2014 | Briggs AND Stratton Intek Briggs &...
Lawn mower will start when primed but will only run for few secon
It starts because of excess fuel from priming. It usually then gets it fuel from main jet in carb.
You need to find the main jet and run a fine piece of sturdy wire through it. That will restore fuel flow so your mower can continue running after the priming fuel is gone.
This is a good thing to learn. Main jets tend to clog a lot on mowers these days.
Jul 05, 2010 | Poulan "Poulan" Push Mower
The mower is 3 months old worked fine untill yesterday
the problem is either u have trash in the bowl of the carb or the float in the carb is stuck. either way u need to have someone look at it.
Aug 12, 2009 | Mtd 22" Yard Machine Push Mower
Self-Propelled Model Starts, then dies after about 15 seconds
I posted same problem as this couple days ago. Took mower to shop. The governor spring (located just under the air filter) had come off. So glad it was something so minor!
Jul 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
859 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
