Question about Vacuums
The feetdog is not moving the material. when I check it whithout material and preasurefoot up it lookslike it works fine, but when I try to sew its staying in the same place. Gunter
    President:
  • 1,469 Answers
Hi, you can try to troubleshoot the vacuum cleaner first, an object might be blocking it movement from not moving.
You can also use this link to check on what to troubleshoot on your vacuum cleaner.scroll down and see some videos, and also check to see more info. on the site.
answerbag.com/vacuum-cleaner-repair.
Hope it helped.
Take care.
Posted on Jun 03, 2010
I havd loose bobbin thread, but I also just went to a heavier thread.
Bobbin thread and top thread should both be the same. If you have a heavier thread, then you should adjust the tension accordingly - looser or tighter, move one click up or down and check on a similar or same scrap piece of material that you plan to use on your project..
Oct 26, 2014 | Singer 4411 Heavy Duty Sewing Machine
Empisal dress maker 270d
Sounds like your tension is vibrating off to a least tension position, When the machine does this again check your tension button. Hope this is the solution?
May 16, 2014 | Vacuums
I got this for my daughter in law. The machine bunches thread up underneath material. I have tried moving the upper tension, rethreaded (with pressor foot up) the needle & bobbin. I have changed...
the tension at bobbin seems to be the problem, make sure bobbin thread is in placed in bobbin CORRECTLY...then it should not be loose but loose enough to pull out with the slightest pull, top tension should be set on around 4,,,,,
Feb 28, 2014 | Singer 4411 Heavy Duty Sewing Machine
My Kenmore sewing machine timing has gotten off. I am sewing a big upholstery project and it starting bunching thread from the bobbin. The thread is so heavy that I had to put some pressure just to get...
Hello
Disassemble your bobbin case which is realy quite easy, clean thoroughly with a brush and air, paying particular attention to any rust that may have formed, and any thread that may have weazeled it's way into small but very incremental areas of your case.
Make sure your needle is not in backwards.The rounded side should be on the outside
. If threading is correct and your tension is properly adjusted , then check the hook for scratches. If you have ever hit the hook with a needle, it will be scarred and will catch the thread every time the upper thread passes around the bobbin case. the hook is the sharp point on the shuttle that holds the bobbin case. If it is scratched, polish it smooth with VERY fine sand paper
Make sure that your thread arm that rises and falls, constantly having tension running through it and that it is in fact staying in place.
Alternate between the metal and plastic bobbins - sometimes the plastic bobbins tend to chip
Dec 04, 2010 | Kenmore Vacuums
THE ROLLER BRUSH WILL NOT TURN. I PUT ON A NEW BELT AND IT BROKE IMMEDIATELY. THE ROD THAT HOLDS THE BELT IS MOVING BUT THE BRUSH IS NOT MOVING.
Apparently something is binding the brush, keeping it from turning. Remove any string, hair, etc., that is wrapped around the brush. Removing the brush is the easiest way to do this, then cut the material through at one point.
While the brush is out, check the ends for signs of damage that may cause the brush to bind. Also, check the area the brush connects to.
Reattach the brush and try to spin it. If it spins freely, put your vacuum back together, with another belt, and try again.
If this doesn't work, I suggest a new/different vacuum.
Oct 25, 2010 | Bissell Vacuum - Momentum Cyclonic 1 ea...
My dyson vacuum is running really rough, I took
clean the filter, clean the upper part of the canister (unclog the holes) check for clogs.
if you vacuumed up fine Powdery materials or something damp/wet.. these are no no's and they involve repair.
Mar 28, 2010 | Vacuums
With my K6 Industrial Singer sewing machine the top thread seems to be too tight. The bottom thread is looping too much on the top of the fabric. The timming is ok. I have checked and rechecked that I have...
Hello there, loosen your top thread tension,if it looping on top of the material the tension is way too tight, you will also find changing the thread size to smaller thread, the top tension will also reduce,depending on application a good size thread to use is 25 grade,bobbin tension should have just a slight amount of drag as the top thread and bottom work against each other when sewing.
regards
Tony
Apr 04, 2008 | Singer Vacuums
Vacuums Logo
20 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
