Question about Cameras
Turns on then right back off like the battery is
My koday easysharem340 turns on, then right back off like the battery is dead. tried charging the battery, also buying a new battery but problem still insists
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 178 Answers
I know you mean your kodak easyshare camera battery life is over,and the new kodak battery replacement you buy isn't effective to you camera, it may be a compatibility problem,You should have take your camera with you to test if it is fit.Now you can get some kadak battery information or get from Inernet search engine.
Posted on Jun 02, 2010
I was using my psp while it was charging and the charging light turned off, so i naturally assumed that it was fully charged. But a few minutes later the battery died and it wont charge when i plug it in....
Have you tried to remove the battery and put it back in and try to turn it on. Try removing the battery and putting the charger in and starting the PSP. If it starts, it might be the battery. If it doesn't, it's either the plugin for the charger or the PSP is just dead. If it does start with the charger, try putting the battery back in, if it charges awesome. If it doesn't the battery might be dead.
Sep 27, 2011 | Sony PlayStation Portable (PSP) Console
My laptop won't turn on..it goes dead and doesn't turn back on..Is there some procedure to help this..its an acer aspire 5532..
When you say it goes dead are you saying the batteries die because if so you do realize they have to be charged once in awhile right? If you do know that and were serious about the problem try removing the battery for a minute then replace battery and restart see if that helps!
Good luck!!!
Jun 08, 2011 | Computers & Internet
My phone is not holding a charge. It seems completely dead, and when I try and charge it it flashes sporodically and vibrates for a second or two before dying again
When your phone tries to come on and goes back off after vibrating for a second or two.
This is due to the fact that the battery is completely dead and is trying to pick up when you plugged it to the charger.
Try to charge the battery of your phone in another phone before fixing it back into your phone.
turn it on before trying to charge it again.
make sure the battery never runs out before you charge it back.
take care
Jun 12, 2010 | Sony Ericsson K850i Mobile Phone
I was using my Koday M893 one day, and i sat it down for a second, when i picked it back up the screen was blank, and the lens is still out. The camera will not turn back on, and i feel like i have tried...
What exactly did you try?
Check these:
  • Fully charged batteries
  • Taking batteries our from the camera and reinserting
  • Other set of batteries
If you did try all of the above without success, the only thing you could do is take the camera to a local electronist, or Kodak dealer for repairs.
Apr 09, 2010 | Kodak Easyshare M893 Digital Camera
Key stuck, won't turn, won't shift...replace ignition switch?
Before you replace the switch try this. As you try to turn the key rock the steering wheel back and forth. The key may turn then, if so it was stuck due to pressure from the steering wheel lock. If it still doesn't turn yes the key and tumbler are bad.
Sep 07, 2009 | 2002 Chevrolet TrailBlazer
Turns off right away
You probably didn't get all the sand out and now it's preventing the lens from opening correctly prompting the camera to shut down.
Aug 16, 2009 | Polaroid T831 Digital Camera
Haven't used my koday easyshare v803 in about 3 months so it had gone dead. Now charging and it won't even turn on.
Your fix could be as simple as cleaning the camera's battery contacts, or it could be something more serious and expensive. First try removing the batteries and cleaning the camera contacts with a small metal brush, steel wool, or fine sandpaper. If that doesn't fix the problem, check the Kodak Help Center by clicking on the link below. It uses a simple Q&A format to diagnose problems and propose solutions.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Jul 13, 2009 | Kodak Cameras
Kodak Easyshare Z1285
Are you using the batteries listed as compatible according to the cameras battery door? Or are you using NON-compatible Alkaline or Ni-Cad batteries? Only Li-Ion and Ni-MH are compatible. Hope this helps...
Jun 29, 2008 | Kodak EASYSHARE Z1285 Digital Camera
Is there a generic fault???
its not dead it crashed. try taking the battery out of it and put back in it should turn back on and alow u to charge it.
Jun 25, 2008 | LG KU990 Viewty
Garmin ique 3600 won't turn on after battery goes dead
I had the identical problem; I called Garmin and a new battery = $50, installed only @ the factory. I tried buying one off eBay, but those batteries spec out ok but don't have the pigtail leads required for my M3 (probably would work just fine for M5). I soldered on the pigtail from the old battery from my M3, then put it all back together. Works! However, the new battery ultimately drains down over several hours so when I'm not using it I have to trickle-charge the thing constantly. Bottom line: I suggest sending your M3 back to the factory for a new battery rather than trying to replace it on your own.
Jan 25, 2008 | Garmin iQue M3 Pocket PC GPS Receiver
Cameras Logo
149 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
