Your a guru so i posted this again directly to you lol
Lol ok well my mixer is hooked to my pc through my sound card i was told the lcd lights are supposed to light up but even if i yelled in my dynamic mic i barely get the first line lighting up here are my settings..
gain is at just over half compression is 3/4 green light bla dont matter i know how to muck with them the big white one under those is just over half my effects are on my phatom button is not pushed red knob under that? dunno monitor phones is just over half monitor mix is at half to stereo to monitor button is up and my stereo butoon the big red one is at 3/4 isnt the lights spose to flash up more? lol i dunno and ty
  • 1 more comment
  • cazzaa Apr 09, 2008
    yeah i seen the quide will give it a bash ty
  • cazzaa Apr 10, 2008
    robo i think i may know whats wrong i have the mixer going to line on my comp and thats it should i have line out as well to go back into mixer? someone told me that may cause a loop?
    well im gonna run the music from my comp into the mixer mic is in the mixer and then record it back on the comp so i need a line out from comp into the 7/8 line in on mixer is that right? someone trold me you cant run a line out and in on same soundcard?
  • 1,512 Answers
Hi, did you get the other post? Sent you a quick start to identify the gain control that you may need to use.
Posted on Apr 09, 2008
  • Graeme Ross
    Graeme Ross Apr 10, 2008
    If you want to hear what you have done played back from the computer,yes then you need to hook line out from the comp to "2 track in" on the mixer an adjust your volume with "monitor mix" level. Turn it down again before you record but:) it will feedback
Pioneer cdj-1000 mk2 sound issue
Diconnnect the player from the mixer, hook directly to your receiver or amplifier, now try it out, if nothing! replace the audio cords from the player to the receiver/amp, power up both units, hopefully this will work.
Mar 22, 2012 | Pioneer CDJ-1000 CD Player
LG LED 4600 - TV power ons but nothing comes up on the screen. No sound No picture. The remote power on light indicates Red or White as and when we press the power on remote button. Please suggest
Do you at least get a blue screen? Usually with no picture you get a blue screen. Try hooking up a DVD Player to it and see what you get... Good luck...Keep me posted ..Sincerely HDTV GURU JAY.
Mar 16, 2011 | LG 42LC2D 42 in. LCD HDTV
I have 1604-Vlz3, M-audio Delta 1010LT With Cubase 5 . There is a main problem when it's normal with an apm it's no problem no sound problem but when the direct out is working with the sound card the...
You MAY be overdriving the sound card. Near flat should work for vocal, but setting the levels throughout the mixer is important as well as the sound card. You can use the LOW CUT to reduce hum if you have noisy system. Describing balancing the levels is more than I can do here. There are many good videos about mixer setup on YouTube.com. You cannot "fix" problems created by improper levels and noise injected into the system using the EQ.
What is important is to see that all gain controls and faders are around mid range to 70% when operating normally. You should be using BALANCED lines everywhere possible either XLR or TRS cables. ALL interconnected equipment should be powered from the same receptacle or power source INCLUDING all amps and powered speakers. Often users use unbalanced lines from mixers to sound boards and pick up noise or they have the levels set wrong between the mixer and sound board resulting in clipping and distortion or poor signal-to-noise ratio.
Jan 18, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
I am looking for a cable to go from my PC Sound board to go directly into the M-900MK2
As I can see from the manual of your mixer/preamplifier (here is a link for that in case you lost it) there are line inputs with dual RCA jacks (U-03R). You can connect a cable with 3.5mm mini jack stereo male from one side (this for your pc's sound card) and 2 RCA jacks male at the other side (for your mixer/preamplifier). In case you need it, here is a photo of that cable.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Mar 25, 2010 | TOA Electronics M-900MK2 Amplifier
How do i connect yamaha mixer to pc or yamaha receiver
I am sorry to disagree, but some information in the previous post is INCORRECT. DO NOT connect the output of the mixer to the MIC input. The mixer generates LINE level output that should go to the LINE-IN on the sound card. If you connect the mixer to the mic input, you will damage the sound card. MIC level inputs have an additional amplification stage.
Dan
Mar 09, 2010 | Yamaha Mg102c Stereo Mixer
This is the active mixer error message... --------------------------- Volume Control --------------------------- There are no active mixer devices available. To install mixer devices, go to Control Panel,...
NO active mixer is one of the volume control, your sound card or your audio port is not installed. try to install again your motherboard installer and locate for the audio of it of for the soundcard. Then after that restart and when the sounds come then you successfully installed it
Jan 10, 2010 | Computers & Internet
How to connect mixer an amp to laptop?
How is everything hooked up?
Mic to Mixer, and Mixer to Laptop? Or is your mic connected directly to your laptop?
To do this properly, you will need a secondary audio input device of some kind that accepts line level input. Microphone inputs are intended for low level signals, and are not going to accept the input form a mixer properly. (you can get it to work, but it will generally be distorted)
There are various USB or PCMCIA audio input card options that aren't too expensive. Once you have that, you would need to route your music and microphone through your mixer, and the output of the mixer to your audio input device.
Mar 20, 2009 | HP Pavilion dv9000z Notebook
I have a yamaha mg82cx mixer and my bar lights dont really light up
hehehe sounds like a good party... mixers... bar lights... balloons..lol can you describe to me again what is happening? Is it the master VU that is not coming up or not glowing brightly, or just not enough level coming through the mixer to light up the VU?
regards
Graeme
Apr 09, 2008 | Audio Players & Recorders
No output mixer settings
u need dj card hi tech stuf fnot sb lol ok go to guitar center get you self a in and out box usb midi ok has quder in in jacks for record players cd and software they make a dj labtop card also dual inputs hi tech gear not stander sb stuff ok tascam makes sum alot compains that do u wann wann run record player son to dj on with cool effects mensu ? try tractor software maby for lp and a nice in and out box ok
Jan 15, 2008 | Creative Labs Sound Blaster Live! 24-bit...
3 PC's networked to BEFSX41 very slow accessing internet
sounds like your internet access is the slow down, not the router. You don't say if you have DSL or CABLE or what.  I'd check there. Make sure you are getting a strong signal.  Hook up one system directly, without the router and check the speed.
Oct 14, 2007 | Linksys BEFSX41 Router (DHBEFSX41)
24 people viewed this question
 Grubhead
Grubhead
