Question about HP (219462-001) Cooling Fan
Cooling fan (902)
Hi Friends,
This is Sreekanth, recently I bought HP dv6 laptop and facing the cooling fan problem regularly. I have installed the BIOS path which is provided by HP.
(http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02066988&tmp_task=solveCategory&lc=en&dlc=de&cc=at&lang=de&product=4186100)
Still am facing the same problem, can anyone please tell me how to resolve this issue or i need to return the laptop.
Thanks in Advance
Sreekanth
  • shrikanth_pa Jun 02, 2010
    Cooling fan(902) error, because of this issue my laptop is not started and for this issue HP provide a BIOS patch, i have installed the BIOS patch as well but even then my laptop is not getting started.
    Please provide me a solution.
    Thanks
    Sreekanth
    New Friend:
In monitor display " Cooling fan (902), problem on the fan, it could be the motherboard detects the fan is not spinning, it could be the fan spins slowly, opening her fan motherboar and check if it needs to change, then the problem is solved
Posted on May 30, 2013
IMPORTANT !!!
Obtained the correct BIOS file, HP seem to provide many different BIOS's.
For instance the BIOS for CQ45-107AU is not the same as CQ45-107TX.
For the CQ45-107TX I used the Insyde BIOS version F.04 file 30F7F04.FD then
  • Renamed the file 30F7F04.FD to 30F7.BIN and placed it on a USB thumb drive.
    Disconnected the AC adapter from the notebook.
    Removed the battery from the notebook.
    Inserted the USB thumb drive into one of the USB ports on the notebook.
    Didn't seem to matter which one.
    Held down the 'Windows' Key and the 'B' key.
    Connected the AC adapter.
    Pressed the 'Power' button on the notebook.
    When the LEDs came on, let go of power button and the two keys held down earlier.
    On the CQ45-107TX the touch pad LED came on as amber (disabled) instead of the normal white (enabled).
    After about 10 seconds the notebook started reading the USB thumb drive.
    While searching for the file the notebook beeped once a second.
    The number of beeps varied, depending on how big the thumb drive was and
    the number of files on the thumb drive, from just one beep to many.
    If the file was not found, the notebook would reset itself and try again.
    If the file was found then it took about 12 seconds for the notebook to load it.
    No beeping sounds heard during the loading time.
    When loaded the notebook started flashing, indicated by beeps every 2 seconds.
    This took about 32 seconds.
    About 5 seconds after the beeping had stopped the notebook shutdown.
    BIOS worked normally thereafter.
***Note: i'm doing this for the Envy 15-1050nr
Posted on Aug 27, 2010
  • 39 Answers
What do you mean by cooling fan problem? Is it overheating & shutting down? Is the fan running all the time due to the heat? Be more specific & I will try to give you appropriate advice.
Rgds
Posted on Jun 02, 2010
  • coz Jun 02, 2010
    Never heard of a system not starting because of a fan problem. Fan really does not become an issue until overheating occurs. Are you able to access the bios? How were you able to apply the bios update if you are not able to start? Or, does your hardware start to load Windows, but never complete the boot cycle?
4 Suggested Answers
  • 59 Answers
SOURCE: Cooling Fan Options in HP System
Sounds like the fan might have dust build up on it. If that is the case the best thing to do is get a new fan. You will have to take the computer apart and check the fan to see if the dust has built up. If not then the barrings maybe shot. In which case you will need a new fan.
Hope this helps.
Posted on Mar 02, 2009
  • 917 Answers
SOURCE: Hi, how can i change
The fan control is a function of the bios and any override sttings would be available in the bios.
Posted on Mar 14, 2011
Geekman
  • 32281 Answers
SOURCE: This morning when I
When the CPU overheats then it will shutdown (i.e. thermal overload) and won't boot up again until it has cooled down.If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Posted on Aug 04, 2011
Testimonial: "Hi Geekman, Thanks for your solution which I think, precisely addresses the issue faced by me. The heat sink s duly cleaned up ."
Core temp
The fan could be partially faulty and cannot spin fast enough.
You can also purchase a fan assisted cooling pad and place the laptop on this cooling pad.
Apr 06, 2013 | HP Pavilion dv6-1030us Notebook
Cooling fan 902
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Oct 28, 2012 | HP Computers & Internet
How to clean the fan
Buy a can of compressed air, attach straw and give the cooling fan a few good blasts, and the open ports.
May 10, 2012 | HP DV6-1238NR (YA843UA) PC Notebook
System bios says the is a 902 cooling fan error
Replace the cooling fan. It is going bad and will cause the laptop to overheat.
Mar 04, 2012 | HP Mini 110-1037NR Netbook
Fix HP lapton error 902 cooling fan
the laptop was fixed by blowing into it
do it very care fully.
Feb 04, 2012 | Computers & Internet
This morning when I tried to start my laptop ( HP Pavillion entertainment PC) I got a flash window that due to the cooling fan 902 issues the start up could not happe and I have been advised to contact...
Aug 04, 2011 | HP (219462-001) Cooling Fan
Where i can run cooling fan on hp pavilion dv6 laptop 2011 ? i buy new one but i don't no which button i have to press Please help me
It sounds like your cooling fan has stopped and you bought a new one.
The fans are plugged into the motherboard. Your motherboard probably has at least two fan connectors-they are marked "fan" or "case fan" or something like that. There is no button to turn them on. They come on when you start the system.
Jun 03, 2011 | Computers & Internet
Hi. I have a HP laptop for about 3 months and now it gives me the message " a cooling factor is not working properly" , and it shuts down 15 minutes later. what should I do? Should I go to the...
The laptop should be covered since it is only three months old. That's the good news. The less than good news, is that you may have to wait a while before you get your computer back.
I don't have the laptop in front of me, so naturally I can't diagnose the problem directly.
I would hazard an intelligent guess that the Cooling Fan inside the laptop has failed.
Components inside a computer are normally cooled by air. (High tech gamer computers may use a different type of cooling system. They may use water, or a refrigerant of some sort. { Dry Ice, Nitrogen, Freon, etc)
Two main computer components generate the most heat.
The Processor, and the graphics chipset. (Video chip, Same/same)
The Processor is the 'Brain' of the computer. It's designed to operate up to a maximum temperature, (Thermal Limit), and no higher, or damage to the Processor will result.
There is a Fail Safe feature built-in to turn the Processor off, if it becomes too hot.
(BIOS turns the Processor off)
With no cooling fan operating the Processor will overheat.
You didn't indicate what model name, and model number your HP laptop is.
This is to just show you what an average cooling fan looks like in an HP laptop,
(HP DV6 series ), and what is entailed in order to access it,
http://www.insidemylaptop.com/disassemble-hp-pavilion-dv6-laptop/
Scrolling down to Step 24, and 25 shows the top view of the cooling fan.
Step 29 shows the bottom view.
Would appreciate hearing the outcome, please reply in a Comment.
Regards,
joecoolvette
Apr 26, 2011 | HP (344872-001) Laptop Cooler, Cooling Fan
I have hp pavilion dv6 laptop windows xp drivers
I have the solution! Read this thread and install this version of XP 32-bit. I am currently running this version of Windows XP Pro 32-bit on my HP Pavilion dv6-1030us. IT WORKS!!! I promise. After you install that version of Windows XP 32-bit than follow the second link here. Good Luck.
Step 1) Download this OS here: http://www.mininova.org/tor/2863191
Step 2) Burn the ISO using your favorite ISO burner. (I use ImgBurn)
Step 3) Do a complete fresh install.
Step 4) Install these drivers: http://h30434.www3.hp.com/psg/board/message?board.id=OS&thread.id=9700&view=by_date_ascending&page=6
Step 4) The drivers on that page are post by Daniel, so please give him kudos for hunting down the entire driver list.
Step 5) Reboot and ENJOY!
-=Viralnexxus=-
Mar 11, 2009 | Computers & Internet
Computers & Internet Logo
5,606 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
