Question about Kohler Electrical Supplies
Kohler gas geset no fuel to carb
Kohler marine gas geset no fuel to carb, fuel pump, or fuel line check valve?
  • 905 Answers
The pickup tube in the craft's fuel tank has likely worked loose and dropped into the tank. The generator lost its "straw" that it needs to siphon fuel through.
Posted on Jun 12, 2010
Not getting fuel, will run if gas is supplied by pouring into carb. how can I troubleshoot fuel pump?
Disconnect the fuel line from the carb and turn on. If no fuel comes out of the hose, the pump is bad.
Mar 11, 2016 | Kohler 25HP COMMAND SERIES ENGINE
40 hp mariner won't fire 1994
First check for fire on spark plugs if you have fire make sure it is getting fuel by pulling fuel line off carb if still wont crank carb is probably dirty if fuel injected line and pump may be clogged or the filter may be
Sep 27, 2014 | Boating
24 hp brig motor does not seem to be getting fuel
the additive in gas eth. causes fuel lines to break down and not deliver gas to the carb. replace fuel line.
check fuel pump, remove fuel line to carb. turn motor over, if fuel does not spurt out fuel line replace fuel pump.
float in carb may be stuck, remove bowl from carb. and check needle valve, if gummed up clean.
Jun 02, 2014 | Briggs & Stratton Briggs Stratton Intek V...
I have a 1996 Mercury 25 H.P. Tracker motor 2 stroke. It is hard starting but when it starts it will stop running after a short time. If I keep the gas pump bowl pumped up it will still run and then stop...
removing from the motor on the boat is not difficult
rebuilding the carby is for professional marine shops as you cannot get out and walk home if you get it wrong
from your description the problem is in the fuel pump on the side of the motor ( rubber bits in the valves)
most carby and fuel problems come from rotting rubber in the lines , pump ( diaphragm and valves )and those bits blocking the carby inlet and jets
to add to your woes , if you use e mix as a fuel, it collects water and that helps the rotting process as well as rusting in the tank
for safety sake let the marine mechanics do the job
more than your life can be at stake
Apr 08, 2017 | Boating
Idles and runs good at low rpm. Stalls above 3500 rpm. It is a1990 115 mariner outboard( 2 stroke)
Starving for gas! check fuel tank vent. Check fuel lines. Check Fuel filter. Check fule pump. Check carbs. clean with seafoam!
Sep 09, 2013 | Boating
Cub Cadet has gas, has spark, has air -still won't start/run
Are you pulling the plug to check for wetness after cranking it a few times, WITHOUT using the starting fluid? Also, I would recommend using carb cleaner in place of the starting fluid. Starting fluid runs the engine VERY hot for a brief time and can possibly damage rings, valves, and aluminum parts.
Jun 09, 2013 | Garden
Kohler cv491s
It could be fuel pump or carburetor. Make sure tank valve is open (if equipped), remove fuel line from carb and carefully have someone turn engine over, if you get a good stream coming from line you know pump is good, then you know problem is in carburetor. Hope this helps.
May 03, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My 25 horse kohler starts when I put gas in the carb, then shuts off. I have gas from the fuel pump--HELP!
first check for power going to the solenoid on the bottom of the carb its a anti backfire valve if you have power there when the key is cranking and when turned on the solenoid might just be stuck if that works maybe the gas that was left in the carb turn bad
Apr 10, 2012 | Husqvarna Garden
289 2 barrel with new fuel pump. gas will not stay in the fuel line after the car sits even for a few minutes. Has to be pumped back up into the filter and carb. by cranking at least 20 times.
Even if that was true, the car would run for 20 seconds without any fuel in the line, because the carb would have gas in the bowl. Why was the fuel pump replaced? How do you know theres no gas in the line? The check valve in the fuel pump should keep fuel from going backwards into the tank. The carb should hold gas, if not, find out why.
Dec 11, 2009 | 1965 Ford Mustang
Kohler motor starts then carb loads up with gas
If the engine is running rough then this could mean that you have weak spark or valve adjustment. When an engine runs rough it will not burn all the fuel, which will create excess fuel in the air cleaner housing. Also, make sure the the float is closing in the carberator.
May 01, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Electrical Supplies Logo
403 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
John Trevino
jdthefixer
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
