Question about Dishwashers
Kenmore Elite Dishwasher (665.16053402). Suddenly stopped draining water from inside tub. Washed dishes were kinda funky leading up to the failure to drain. Have replaced air gap on sink top - still no drain. Send help...
  • kt0038 Jun 02, 2010
    Kenmore elite dishwasher (665.16053402).
    Won't drain, have removed lower spray arm and also three torx screws in an attempt to lift the screen filter assembly.
    Hopefully once inside the drain area the culprit will be obvious. However I need help in removing the flat round drain screen (just under the spray arm. Have heard/read tha the check valve might be the problem. I would prefer a simple (?) repair to a replacement.
    Am I on the right track? Any help, any at all would be appreciated.
    Thanks,
  • 12,061 Answers
Http://www.servicematters.com/maytag_library/docs/16021814.pdf
http://www.repairclinic.com/Dishwasher-Repair-Help
Please find above a service and repair manual, please work through the simple troubleshooting steps, and you will soon isolate and hopefully be able to repair your issue. Below is a DIY self help website to assist you in what to do. You need to check, your filter, pump etc, all in manual step by step.
Posted on Jun 02, 2010
    President:
  • 949 Answers
To determine what is wrong start a cycle then push cancel/drain. Listen at the front lower kick panel. If you hear a buzz or hum that is the drain motor. If you do not hear the drain motor running then the problem is the motor itself. I have put a picture at the bottom of this showing the drain motor as 17, it hooks up right up front and a bit to the right side just behind that bottom toe panel.
If you do hear that motor running when you push cancel drain then the issue is somewhere between that drain pump and the sink where the dishwasher drains into. If you had a garbage disposer hooked up recently it could be the knock out plug for that is still there. What I would suggest is take the drain hose off at the air gap that you just installed and put the hose into a bucket, see if the dishwasher drains into that if it does then the problem is between the air gap and sink, if not then move back toward the dishwasher until you get to the point where you drain.
  • 1 more comment
    Additional info on drain problem below:
    Thanks,
    A link to the repair manual for this model (665.10653402) would be most excellent!
  • Philip Jun 02, 2010
    Here are some instructions I put together that will show you want you need. I will find the complete manual and send a link in a couple minutes, take a look at this first, it is not for your issue but should help you take it down to the check valve.
    Sump Clean Out
    Here is the link, it is for KitchenAid, that is who makes this model.
    Sorry you rejected my advice. But I really do not think the check valve is not where you will find the trouble.
    Best wishes!
    Service Manual
We have a Kenmore Elite 16579. The soap as stopped dissolving and the dishes are not getting clean. There seems to be good amount of water, and good heat.
Hi
If the water inlet valve is fine and it fills with water then the issue seems to be with the float switch assembly that is bad and should be replaced. Float assembly is found inside the dishwasher's tub, on the bottom. The water that fills the dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with dishwasher's filling and/or draining ability. Use voltmeter to test the switch. Set the device to the ohms setting x 1. Take each probe and touch them to one switch terminal each. This should produce a reading of either zero or infinity. Continue to touch the probes to the terminals, and press down on the switch's button. The reading should change to the opposite extreme. If the switch fails either of these tests, you should replace it. Hope this helps...please post back for further assistance.
Daniel
Aug 27, 2011 | Kenmore Dishwashers
My Kenmore Elite dishwasher did not drain the water out of the bottom after the dishes were washed last night. Could I possibly have pushed a wrong button to keep it from draining, or do I have a problem?...
Yes , If the program controller has hung it would have skipped the drain cycle. So try to redo the cycle and see if the drain works, is not check the program controller and the drain valve/pump.- if there is food particles that have clogged and blocked.
Jul 26, 2011 | Kenmore Dishwashers
I have a Kenmore Dishwasher model # 587.1523. For some reason, after washing or rinsing cycles are complete, water is still in the bottom tub. My question is, besides the troubleshotting tips in my use and...
Good Evening,
Have a Kenmore\Quiet Standard Model#587.1523 900
Dishes are not getting washed, cyles through , Believe the inside Top Nozzle is not getting any water up the tub to the top of the washer ?? Not sure hoo to fix this ?
Thank YOU for Your Time.
Mrs. Garza
Jan 13, 2010 | Kenmore Dishwashers
Kenmore elite dishwasher, does not get the dishes wet
sounds like wash motor is not going . it will fill and control thinks motor is working . then it will drain wash water / ( drain pump is a different motor ) and then refill and so on .. never washes but fills and drains and heats. ( look for leakage under the motor i'm sure you will find some ..
Nov 22, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore elite not washing dishes
Sounds like the motor is stuck. If your careful you can unplug the dishwasher or turn the breaker off, take the bottom panel off and reach in with your finger and spin the motor assembly.
Nov 12, 2009 | Dishwashers
Kenmore elite washer problem
you can use a shop wet vac on the drain hose to **** the rest of the water out then you can remove the hoses to check to see if anything is suct in hoses or pump-,mike
Apr 24, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
New dishwasher leaving powder residue on dishes.
the problem is hard water and there is a new product out called the dishwasher filtration system. it actually filters the water going into your dishwasher and leaves your dishes spot free. after the first load i was amazed that the white film was gone and my dishes were sparkling. you can get it at www.dishwasherfilter.com.
Sep 06, 2006 | Kenmore 13869 / 13864 / 13862 Dishwasher
Dishwashers Logo
138 people viewed this question
Top Dishwashers Experts
Owen Barnes
