Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
How to fix broken lid switch. The plastic casing is cracked only left with the two wires hanging.
  • 375 Answers
Replace the switch. It's relatively cheap. Part number 8054980
Posted on Jun 02, 2010
The lid of my EP91 quad blade is broken
Hi Rosa
Depending on the severity of the broken lid....
I fix a lot of plastic items with either super glue or 2 part epoxy resin.
Then for reinforcement at the edges. I take a 2cm (aprox) piece of thin wire. Like a staple. Then heat it with the soldering iron. sliding back and forth until the wire is embedded into the plastic. even slightly covered over.
This often makes a cracked piece of plastic quite strong.
It may not look great but it might hold you over till you find a replacement
Good Luck
Here are some ideas....
Repairing plastic parts
How to Fix Broken or Cracked Plastic or Weld Plastic
Mar 16, 2016 | Euro-Pro EP91 Quad-Blade Food Processor
How to fix lid switch.
there are two screw you have to unscrew on the back panel and the you pull the panel up and foward then you will see the plug for the door switch and two gold clips on both side of the washer undo the clips and the pull the whole casing of the washer off and the door switch is under the casing or you can strip the wires back that are show and put a wire nut on it and i will work just fine but you will be able to open the lid while in a spin cycle so if you have little kids i would not do this but if not save the money and just tie the wire together.
Jun 02, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
The lid switch on my kenmore 70 series has broken off. The wires are still attached, but the plastic unit is no longer connected to the underside of the machine top. I need to drain the machine somehow in...
There are two wires attached to the lid switch, just connect them together and the machine will work as normal. Please take care not to open the lid while it is operating. This switch is a safety cutout.
Nov 18, 2009 | Freezers
Mine wont spin
Your problem is more likely a broken lid switch. To test for this, lift the washer cover and look for a small hole in the washer top where the cover was. Push a toothpick gently into the hole and press the piece of plastic you see in the hole downward and listen for a soft clicking sound. If you don't hear a click or the plastic tab is not in the hole replace the lid switch.
Unplug the washer. Check the actuator on the lid that operates the lid switch to see if broken. Open the console of the washer. After removing the screws, the console will lift up and hinge back. Disconnect the plug going to the lid switch. Picture. Check the lid switch [lid closed] with an ohm meter from the wire plug-in leading to the switch. If no continuity, replace the lid switch. You will need to remove the cabinet to replace the switch. There are only a couple screws holding the lid switch assembly and a ground wire connection to the cabinet. Reassemble the washer and test the operation.
Unplug washer, remove the two console screws and tilt console back, remove cabinet clips, unlock lid switch block and then remove the cabinet. Remove the lid switch mounting screws, disconnect ground wire and remove lid switch assembly. Compare old switch to the new one. If the plastic sleeve of the new switch is longer, break off at the score mark. Pull wire partially out of sleeve before shortening sleeve. If the sleeve had to be shortened, the wires must be looped to take up the excess wire. Use supplied wire tie from the new kit. Install new switch assembly. New lid switch
Pay VERY close attention to assembling case back onto base so that sides engage tabs in base.
Sep 21, 2009 | Whirlpool Washing Machines
Lid switch is out
I would recommend you replace the lid switch rather than by-passing it. The following link explains how:
http://www.fixya.com/support/r385198-replacing_lid_switch
The lid switch is a safety feature that is to protect the consumer from the high speed rotation of the wash tub and the agitator. If you by-pass it, you will need to push in the timer PRIOR to opening the lid in order for the tub to stop. I would recommend by-passing as a last resort (temporary repair) while awaiting a new switch.
To by-pass a lid switch, follow the steps in the link provided to open the console. Make sure the washer is UNPLUGGED. Locate the white lid switch connector and unplug it. Remove the washer exterior case and remove the lid switch from under the washer casing. With the lid switch in your hand, cut the connector plug off, leaving about 2 inches of wire. Remove the green (center wire) from the plug and crimp the two black wires together. You have just made yourself a by-pass plug. Plug this back into the connector on the timer and the washer will now operate without the lid switch.
As I stated before, you will need to push in the timer prior to opening the lid to stop the tub. You can save the plug for future use, but use only as a temporary fix.
Replacement switches are available at searspartsdirect.com, appliancepartspros.com, repairclinic.com, and pcappliancerepair.com. They don't cost much and I provided you with easy instructions to follow.
If you have any questions, please let me know. I hope this helps you.
Jul 06, 2009 | Kenmore 24032\24036 Top Load Washer
Can i fix my broken laptop.
Well, if the display comes on at all, then it must be a loose connection in the wiring. Sometimes this is a simple reseating of the main cable to the mother board which comes down from the display near or around one of the hinges (in most cases). I would suggest, purchasing a cheap external monitor, and plugging it into the rear or video out port if you have one, and switching your display to go to the external monitor, this will work good as a desktop scenario. Otherwise, you need to take it all apart and see if you can find out where the loose connection is, this is no easy task, and should be done by a qualified laptop repair person who has experience.
Mar 22, 2009 | ASUS F3Jp Notebook
My Neptune top-loader washer,
Evidently the "OP" code indicates the lid is "open". Solution in my case: I had to replace a wire on the lid switch that a
had rusted and no longer connected to the switch resister.
There is a magnet in the left, front corner of the plastic lid insert. When the lid is closed, this magnet sets on top of the tan colored plastic pad on the left front top of the base washer unit. When the lid is closed, the magnet activates two, small metal rods on each end of a resister within the white. You have to pop up the top of the washer base to gain access to the switch, Good luck,
Aug 29, 2008 | Maytag Neptune FAV6800AW Top Load Washer
How do you clear a od error code on a maytag fav6800aww
I agree with fastnhonda troubleshooting. I will just toss out some additional info. I’m an owner like you just trying to troubleshoot from a distance. The OD alarm is signaled by the control board when the control board has not seen a lid open signal from the left lid lock for three completed wash cycles. Could be corrosion issues with the left lid lock and or plug connecting to the left lid lock. If you pull the power plug on the machine then re-power up does the “OD” alarm clear? This might clear the “OD” alarm for three wash cycles. If it does can you do this; open the washer lid and start a Spin Only cycle with the lid open do you throw an OP (Lid Is Open) alarm to the console? If so do you clear the “OP” alarm when you close the lid? I’m checking the signaling functionally of the Left Lid Lock assembly of the magnetic reed relay and lid magnet thru the left lid lock and plug back to the control board.
If no results come from above testing and you want to DIY the repair I would remove the left lid lock (remove the left lid lock as shown on page 34 of the SM) and inspect for corrosion issues as the other forum member speaks to and a possible broken wire connection on the magnetic reed relay. See the red & black wire going to magnetic reed relay switch as shown in the pic. below. Note the black wire is broken away from one end of the magnetic reed relay do to corrosion. If you take apart the left lid lock the tabs holding the case halves together break off very easy so be careful on disassembly. I would not replace the right lid lock just yet. Removing the plugs on the lid locks is difficult so be careful. I would remove the left lid lock and inspect and clean up wih WD-40 if there are corrosion issues such as shown below or a broken wire (re-solder) on the magnitic reed relay. If this doesn’t resolve the “OD” alarm I would then replace the left lid lock only at this time. The right lid lock is not needed for normal washer operation.
Support info;
Left Lid Lock always give you pats supplier you machine model number when ordering parts. No machine serial number is required for this part.
The Service Manual for reference. Sears Parts Direct for reference.
Disconnect the washer power cord.
To raise the top of the machine. Insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base. See page 33 of the SM for putty knife insertion point.
Jul 27, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Clothes are soaking wet because it doesnt spin.
check the door switch for broken or damaged wires. get a jumper wire to go from one wire to the other wire on the switch. If the jumper wire is connected and the washer spins out, then the door switch needs to be replaced
Jul 11, 2008 | Washing Machines
Washer Stuck in Cycle
The timer is bad / shorted. Mine used to try to spin with the water in it... that was a sight to see!
Jan 11, 2008 | Whirlpool LSN1000LW Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
90 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
