Question about Microwave Ovens
Ctb1521gr refrigerator stop working use in motor rv full time yearly 5 years old, light works hear clicking sound under front bottom panel, need help
  • 1 more comment
  • farringtone Jun 05, 2010
    ctb1521gr refrigerator stop cooling and freezing in RV which i travel in full time yearly. Reffer 5 years old, light works, I cleaned the fan and coils already, a white box attached to the compressor is clicking every 1 or 2 minutes bottom of white boxs gets hot, need help
    i have removed the access panel, cleaned the fan & coils which were not that dirty, however there is a white box attached to the compressor every 1 to 2 minutes a clicking noise comes from wht box, ctb1521gr
  • 1,284 Answers
Hi, it's either the start device on the compressor or you have a bad compressor. You'll have to pull it away from the wall and take the bottom back panel off to check the compressor. It will likely be real hot to the touch from what you described happening. If there is a little white colored box on the left side take that off and remove the wires, etc. and shake it... if it rattles and debris falls out then that's the problem. It's fairly common and they make a kit to replace it with a better designed part that's real easy to install yourself. If your compressor has a label on it with a blue indian head symbol, then you're out of luck as that brand pretty much sucks and is destroyed by heat. It would mean a new compressor and then you'd be lucky if the new one even worked from the factory. Avoid those Tecumseh compressors at all cost.
Take care
Posted on Jun 05, 2010
    i took the white box from the compressor and its got little rocks coming
    out and is rattling now on the compressor there is a yellow circle with
    TM in the middle to the left of this is a white lable in blue R134 and
    some designin blue
  • Shehu Pro
    Shehu Pro Jun 06, 2010
    Hi, you have to change the start device on the compressor.....
    President:
  • 1,561 Answers
Check for coil problems. The compressor can overheat due to dust buildup on condenser coils. If so, vacuum the coils. If there's ice buildup on evaporator coils due to bad defrost heater, replace the defrost heater, If there's a squealing sound inside the refrigerator, it's like a failing evaporator-coil fan, you will need to check the evaporator fan to see if there is nothing blocking it, because atimes ice are formed on it, if so, melt it.
Take care.
  • 5,081 Answers
What you can do is take off the bottom kick plate at the front and check the coils to see if there dirty.If they are clean them You should also feel warm air coming from the front of the fridge.If you don't then the fan motor by the compressor is not going.And once the kick plate is off you might see casters under the front . So you can pull out the fridge to look at the compressor for the clicking. Is it warm air coming from the front.If not then the compressor is not going and thats where the clicking is coming from.If thats the case the relay on the compressor could be burnt.If the coils at the front were dirty and you just now cleaned them I would turn off the fridge and let the compressor cool down and try it again in a few hrs.
Posted on Jun 02, 2010
LG LMVM 1935SB doesn't heat.
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
See this file for more help on door switches.
The service manual for your oven is here, but does not contain part numbers.
If you only need a switch, you can order a universal type here for $5 postpaid.
For other part help, contact
Encompass here or call call them toll-free at 866-779-5835.
Let us know if we can help you further.
Feb 09, 2010 | LG Microwave Ovens
Spacemaker XL1800 turntable turns sometimes
I would say an internal post broke inside the motor. This often happens when a heavy item is placed on the tray.
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Mar 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
G.E. Spacemaker microwave turntable won't turn
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Dec 16, 2008 | Microwave Ovens
Microwave stopped working
to indutolia
The original problem was probably a bad turntable motor, which is pretty easy to replace.
Now I'd say you have a bad door switch (whether upper or lower depends on the model number) or a problem with the door switch mount.
This is a pretty simple problem to fix, too: http://www.microwavedisplay.com/doorsw.txt
to lostonisland - Your problem is different enough that it should be a separate post. Please include your brand and model number when you repost.
Dec 10, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker microwave - 5 yrs old..started to make loud sound when the turntable was on..been using it like that for the past 3 years by shutting off the turntable..Yesterday it stopped working...
Carousel stopped turning
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
Dec 05, 2008 | Kenmore 63682 / 63684 / 63689 Microwave...
Doesn't work
Sounds like your magnetron has failed and was going bad for some time.
I would contact Bosch to find their nearest authorized servicer.
If it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
Nov 28, 2008 | Bosch HMV9305 Microwave Oven
Plate does not rotate freely and make noice
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Nov 27, 2008 | Sharp R-1480 Microwave Oven
Model jbm1660wb005 GE Profile Microwave 6 years old Turntable stopped turning with no explanation.
Aug 02, 2008 | Microwave Ovens
Microwave Ovens Logo
65 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
