Question about LG Washing Machines
Hello, Im mike from tennessee i have a Lg tromm wm2277hm that hase a spin issue. To further describe my problem the washer has a jerking motion after the start button has been pushed and its seems as if the soap is being sucked into the machine with a stronger force and also as the wheel is trying to turn it is making a screeching sound deep within the washer... Hopefully someone out here will be able to help me I have lost my owners manual. THanks MIKE
    Sergeant:
  • 351 Answers
Can you turn the drum by hand.if not you may have somthing stuck between the drums hop this helps Ian.
Posted on Jun 02, 2010
My Frigidaire front load washing machine has stopped high-speed spinning. The regular spin works but not the high spin. Any ideas how to fix that?
Hello Mike, thank you for your post!
From what you have described your Frigidaire washer is not spinning on a high speed. This could be a possible issue with your motor, control panel, or speed board. I would recommend performing a reset on your washer and you can do that by unplugging the washer for at least ten minutes. If that does not correct your issue I would suggest having a professional technician out to perform a proper diagnosis and repair on your washer. This will help you avoid any unnecessary part purchases. I hope this information is helpful. -Matt
Apr 29, 2015 | Frigidaire Washing Machines
My lg tromm washer on the wash cycle is not spinning, and is making a grinding noise
check for something in the bowel. pins ,buttons coins etc have a technician check the spin operation.
Mar 03, 2015 | LG 4925ER1015B 4924ER1010 Used Frontload...
LG tromm spins on washer,but doesn't on rinse and won't drain
ur confusing me its not suppose to spin first , first it rinses, then drains then spins
Jul 12, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
"LG Tromm WM2277HW will not
Hello & Welcome to FixYa
LE error in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall effect sensor is used in these washer which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when their is an issue with the motor or when the hall effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sesor and replace the part# that is bad, usually I have seen the sensor going bad. Please get back to me if you have any other questions.
Kevin
Mar 27, 2011 | LG WM-2277HW Front Load Washer
My washer isn't drying anything very well. getting a oe message lg tromm wm2277hm
the OE message means that the machine has not fully drained out all the water. you can try to re set on drain or you may need a service call. hope this helps.
Oct 15, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Tromm Washer Model # WM2277HW by LG
will it spin after it washes if it does not then your belt might be broke
Feb 12, 2008 | LG WM-2277HW Front Load Washer
Tromm LG Washer
On my LG TROMM model # WM1814CW, the door pops open a bit so that water leaks out onto the floor. Is it a simple repair or is it time to get soaked by a repairman. I'm fairly handy, but I don't know if it is an electrical issue or it is a mechanical issue. If you have a suggestion, send it to repihl@yahoo.com.
Thank you,
Bob
Dec 24, 2007 | LG WM2688HWM TROMM SteamWasher
Washing Machines Logo
122 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
