Question about Gucci 7905 Gents YA079303 (17935)
Instructions for gucci gents watch - Gucci 7905 Gents YA079303 (17935)
SOURCE: National Geographic Swiss Gents Time Trekker III Watch Instr
http://www.ronda-startech.com/chrono/main.php?x=functions
If the watch has a Rhonda movement go to the above link for instructions.
Posted on Feb 03, 2009
  • 9 Answers
SOURCE: i would like the instruction how to work on
It should have a CAL number engraved on the watch back and using this you can find instructions for download at www.accurist.co.uk under the after sales service area and downloads option
Posted on Jun 18, 2009
SOURCE: How do I open my gucci watch to change batteries?
Get a #0 1.6mm precision Phillps screwdriver (these are brittle) or similarly strong, thin piece of steel.
Hold the watch upside-down across your index finger while gripping the straps tightly between your index finger and thumb on one side, and index finger and middle finger on the other (ie. squeeze the strap around your index finger).
On the underside of the watch, stick the tip of the screwdriver under a square slot where the watchband is connected at an angle perpendicular to the strap. Firmly pry upwards on the cover on one side, then the other, until the cover pops off.
The battery is a Renata 379.
To put the cover back on, align the square slots precisely with the ends of the straps (keep these out straight), then firmly push the cover straight down until it "snaps" shut.
Posted on Jul 25, 2009
  • 65 Answers
SOURCE: How to Open a Gucci watch
Most watches are either screwed on and typically have a series of small notches around the circumference of the case back. A special tool is generally called for. Otherwise they are "snap back" . These are simply pressed on. To remove you can carefully use a regular knife in the absence of a "case knife". There is usually a small gap/groove/notch area to insert the balde and lift the back off.
  • 2501 Answers
SOURCE: Watch didn't come with instructions and/or care information.
The Gucci web site doesn't have any instruction download feature, so I suggest that you find your nearest store form their web site "gucci.com" and contact them for instructions.
Posted on Feb 20, 2010
Have a gucci watch not sure of model but have serial no
Most authentic Gucci watches have the model number on the back. If you see nothing but a crest, or a crest and the Gucci name, the watch is likely fake. No authentic Gucci watches display just the crest and name without additional markings.
Oct 05, 2017 | Gucci Watches
My Gucci serial number is 10860032 is it fake or original
Bobo, contact Gucci. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Gucci Official Site United Kingdom
Top 10 Tips to Identify Fake Gucci Watches
The difference between real gucci and fake gucci
May 02, 2016 | Gucci Watches
New Gucci watch is not running, will taking off the plastic film with the red strip on the back make a difference.
That decal/sticker is usually only an indicator of a un-worn watch.
The only thing that will turn the battery on is pushing in the STEM.
If it does not run then... your battery SHELF LIFE has been
exceeded... Time to get a new battery
https://www.gucci.com/us/en/st/faq
Gucci offers a repair service for Gucci products purchased from Gucci.com, ... Watch Repairs* East coast: GTS 50 Hartz Way Secaucus, NJ 07094 tel 1.866.692.8244
Gucci Gucci
Dec 14, 2015 | Gucci Watches
What's the proper battery for my Gucci 6400L?
Ensure the watch battery is dead. A Gucci watch is not exactly a cheap trinket, thus the battery should have a fairly long lifespan before requiring a replacement. Once you see the hands of time stop on the face of your luxury item, you can be sure it is time to purhase a new battery. The typical cost for a new battery starts at $50. There are three categories for a Gucci watch: Automatic watches, quartz watches, and bracelet watches. Depending on the type, you will need a battery that suits one of these classifications. Batteries for Gucci watches can usually be obtained on any discount/surplus website (e.g. eBay, batteryright.com, or the actual Gucci store).
Read more : http://www.ehow.com/how_4966607_change-gucci-watch-battery.html
Jul 03, 2014 | Watches
How can i tell a fake from authentic?
mcdevito75 here, Best Bet is to look for a small watch repair shop in your area, they can authenticate your Gucci watch for you. If you can, remove the back cover of your Gucci and record any and all numbers and other info off the watches movement itself then check online at Gucci.com. If your not familiar with watches, specially Gucci an expensive watch let a small watch repair shop remove the back cover and give you all info needed to authenticate the watch.
Oct 23, 2010 | Gucci 03665 Wrist Watch for Women
I need replacement links to add size to the band.
Do you stil have the manual/instructions? I would contact any support number that is listed as GUCCI is the only place to get original links. Most watch companies will allow extra links with watch purchase. Contact them via your waranty/manual.
Best regards.
Aug 19, 2010 | Paolo Gucci PG873WU Wrist Watch
Gucci watch time adjustment
Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals. Try similar watch instructions till you find the right one, because GUCCI do not give manuals. Rate me, please
Mar 28, 2010 | Watches
Feb 20, 2010 | Gucci 112 YA112510 Watch for Women
Watch band broke on Paolo Gucci Womens watch PG873WS
I have here the official website of Gucci for your ready reference. You can run through below link to find assistance. Kindly change the country from where you are.
Gucci
Sep 07, 2007 | Gucci PG873WS Wrist Watch
Gucci 7905 Gents YA079303 (17935) Logo
47 people viewed this question
Top Gucci Watches Experts
Lawrence Oravetz
John mullen
Are you a Gucci Watch Expert? Answer questions, earn points and help others
