Question about Gateway MX6030 Notebook
Gateway mx6030 laptop won't turn on
My laptop will not turn on with the adapter or battery. The battery life is dead so i removed it. I recently purchased a new 90 watt adapter and that doesn't work. The adapter, plugged in, make a slight buzzing sound, but no lights come on or anything.
  • 2 more comments
  • Anonymous Dec 07, 2008
    I have the same problem with this model of Gateway laptop. It wouldn't turn on with battery or with adaptor.
  • mrcoop13 Jan 01, 2009
    I just bought this model was told it worked with ac but battery was not charging, now cant get it to turn on at all. any body have any ideas?
  • hejharold Mar 09, 2009
    Gateway MX6030 will not charge or power up.
  • LindigloJ45 Apr 12, 2009
    MG1-P6822 This Laptop is very new and we can not get any power, it will not turn on at all.
  • Gateway Master
  • 3,051 Answers
Hello there:
hopefully you got the right adapter for the machine and if so and still no lights or nothing you can try to hold in the resetr button on the back of the machine and turn on the power at the same time and see what happens if still nothing i would look at getting the machine serviced by a authorized dealer
you may have a bad board or the internal cmos battery is dead or there is a loose connection somewhere ok?
best regards michael
Posted on Sep 10, 2009
  • Michael Thomas
    Michael Thomas Sep 10, 2009
    also try to remove the battery and see if you can power up the unit that way using the reset button and the power button at the same time
SOURCE:
Battery will only charge for a few seconds
try running laptop without battery (usually removed by sliding tab on bottom of latop to release battery) if laptop runs fine then probably faulty or dead battery.............replace battery. If laptop does not run, turns off then probably faulty adapter........replace adapter.
Dec 16, 2013 | Gateway NV51B15U AMD E350 Processor 156...
Netbook charging indicator light won't light and battery won't charge. AC adapter works on other computers
If the battery won't charge and the laptop won't turn on but the ac adapter works with other laptops, then the problem is the port where you plugin the ac adapter. Some of the laptops has it built in to the motherboard. So you might need to have it repaired by a technician. Or if the laptop is still in warranty, you might need to send it to the manufacturer to have it repaired or replaced. But if the laptop works without the battery, or it will turn on but the battery indicator is not lighting up, you're facing one of these problems.
1. The battery itself is dead. 2. the battery bay is loose 3. the battery itself is loose
Hope this helps...
Sep 15, 2011 | Gateway LT2021u Netbook
Gateway Mx6030 will not charge, battey good, power supply good, bounce on sceen betweeen ac and battery when plugged in. as connection not loose. anything that can be done?
Try to upgrade the chipset driver from here:
http://support.gateway.com/us/en/product/default.aspx?tab=1&modelId=3133
Try also to upgrade them all.
It will do no harm.
Try also to check for bad connections on the battery.
Remember to select the windows you are running.
Good luck.
Mar 09, 2011 | Gateway MX6030 Notebook
Not getting good internet connection
Remove and reinstall or update your NIC drivers.
Do this through the device manager found when you right click MY COMPUTER - Properties, Hardware, device manager. Find the Network adapters and open it. click on Upgrade driver. Find the drivers at www.gateway.com/support
Feb 21, 2010 | Gateway MX6030 Notebook
My gateway mx6030 has no multimedia audio
You can download and reinstall the WindowsXP audio driver for your Gateway MX6030 to restore it's options and functionality.
You can access the driver for this system at:
http://support.gateway.com/support/drivers/getFile.asp?id=20463&dscr=Gateway%20Conexant%20Audio%20Driver%20Version:%206.14.10.0565&uid=25562221
Dec 05, 2009 | Gateway MX6030 Notebook
No sound in Gateway mx6030 MA2 Laptop
Make sure the audio cable is plugged into the MB properly.
Apr 15, 2009 | Gateway MX6030 Notebook
It sounds like this could be one of two things:
1.) The a/c power adapter (power cable) is bad and no longer charges your laptop.  You can check to see if the light on the black box that connects the cable to the wall is illuminated, if so...it probably is not the cable.  If it is not illuminated, you can try plugging it into another outlet to see if it comes on.   2.) This could also be a case of a bad battery.  In which case, you might need to look into ordering a replacement.
Both the a/c power adapter and the battery replacement can be found online (ebay, etc), but you should try to pinpoint if it is the cable or the battery before ordering parts.  Cables are cheaper than batteries!
Hope this helped.
Mar 09, 2009 | Gateway MX6030 Notebook
Gateway MX6030 bios/boot password reset
How long did you leave the battery out?
To discharge the BIOS you need to short out the battery contacts, or disconnect the battery for 1/2+ hours.
If this does not work the it is near impossible to remove because the password would be stored on an EEPROM chip.
Check with Gateway, they might suggest a motherboard replacement just like IBM.
Jan 19, 2009 | Gateway MX6030 Notebook
Battery won't charge.
battery could be dead,standard life for laptops is 1 year
Jun 26, 2008 | Gateway 450ROG Notebook
Computers & Internet Logo
1,508 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
