Question about Philips 51PW9303 51" Rear Projection HDTV-Ready Television
Double vision picture is double i tried to align the red crosses to converge the red nothing happened
    Problem Solver:
  • 7 Answers
I HAVE THE SAME TV. Dont bother with trying to align the crosses your will go crazy if you move your cursor further down the same menu screen you will notice a sort of hidden auto converve option, it will say reset to factory try thatalso i bought a dvi to hdmi adapter and the pic is 1000 times better now good luck
Posted on Apr 21, 2008
  • 2,337 Answers
It looks like the convergence ICs need to be replace. The IC markings are STK392-040 and are mounted on 2 big aluminum heatkinks. This might not be a DIY if you do not have any hand soldering experience. This repair will cost you around $300.00 to $400.00 if you have a TV technician to do it.
Posted on Apr 09, 2008
SOURCE:
Sony kp-57hw40 double picture. regular and the other right next to it is red. tried auto focus and nothing happens. while holding auto focus btton down get red cross and white next to it. tv is 9 years...
Auto Focus button no longer work.Tv have a problems known as a convergence problems,it dead.Tv have colors lnes R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts,must be replaced on the tv convergnce board to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 13, 2010 | Sony KP-57HW40 57" Rear Projection...
My sony kp57ws510 model tv has double vision and the double vision that shouldnt be there is in blue and red..whats wrong with my tv?
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have shadows pictures or 3D pictures look alike.The tv convergence board have dead parts.The 2 STK convergence ICS and some or all it resistors on the tv convergence board are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Oct 29, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Seeing a picture like double vision.Tried to adjust the red & green crosses and the blue. The crosses or plus ( ) signs are supposed to be ontop of each other I assume?. What seems to be the problem.
They have to be on top of each other, converging perfectly. If you are unable to align them - you have convergence issue. Two convergence IC's have to be replaced inside of your TV. I would strongly recommend to let it do by professional technician.
regards.
Russ.
Aug 12, 2010 | Philips Televison & Video
Red color outline and double vision
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 05, 2010 | Sony KP-51WS520 51" Rear Projection...
Picture has ''double vision'' with red.
This is a common problem. Its called a convergence failure.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • TV shutdown - does not display video
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Red/Orange looking video
You can see some examples and find a fix here...
Feb 20, 2010 | Televison & Video
My big screen panasonic tv has a double fuzzy picture what am I supposse to doto fix it
Adjust the convergence or reset it to factory default. Use only the remote when adjusting convergence. The front controls have no effect.
  1. Press action button to enter MENU.
  2. Navigate to SETUP.
  3. Scroll down to CONVERGE.
  4. Press VOL > to select.
  5. Press CH buttons to navigate up or down.
  6. Choose CONVERGENCE ADJ or RESET TO DEFAULT.
  7. Press VOL > to select.
  8. If CONVERGENCE ADJ is selected the align Green to Center screen will be displayed.
  9. Use the navigation buttons on the remote control to align the horizontal and vertical green lines on screen, with the cabinet reference marks on top center and left
    center of cabinet.
  10. Press ACTION button to display red center correction screen.
  11. Use the navigation buttons on the remote control to align the red cross with the white cross pattern at the center of the screen. To prevent picture tube damage do not leave test pattern on for an extended period of time.
  12. Press “0” on the remote control keypad to display the BLUE center correction screen, repeat procedure for adjusting blue. If needed press “0” again to return to RED correction screen. An adjusted cross pattern appears white with a minimum of color protrusion.
NINE POINT CONVERGENCE CORRECTION
Remote Control must be in TV mode.
  1. Press ACTION button to display red correction screen.
  2. Press the 1 through 9 keypad buttons on the remote control to select the desired convergence position.
  3. Use the navigation buttons to align the RED cross with the white cross pattern.
  4. Press “0” on the remote control keypad to display the BLUE correction screen, then repeat procedure.
  5. To exit press ACTION button repeatedly, then press CH up.
Nov 07, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Convergence perfect focus not working and double vision
The problem you have is the 2 STK - 392 convergence integrated circuits need replacing the cost in the UK is about £150.
SUPER8
Nov 26, 2008 | Televison & Video
TV turns on and then, after a few seconds, picture changes to "double vision".
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 25, 2008 | RCA P46921 46" Rear Projection Television
Samsung HCP4752W double vision
*Screen Looks 3-D
*Colors wont align
Oct 09, 2008 | Samsung HC-P4752W 47" Rear Projection...
Apex gb5108
Your Convergence is off. Go through the menue to the CONVERGENCE and follow the on screen instructions.
Start with the RED gun and align each cross point starting with the upper left corner.
You will be pulling the red to match the green.
If the television shuts down during this process, it will reset the convergence and you can try again.
After you get the red gun perfectly aligned with the green, start with the blue.
follow the on screen directs and don't forget to store.
Use the remote for these adjustments.
I hope that this helps..
Jan 06, 2008 | Apex Digital GB5108 51" Rear Projection...
Philips 51PW9303 51" Rear Projection HDTV-Ready Television Logo
59 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
