Question about Garden
Scotts 2046 mower will not start - Garden
  • psiwan Jun 05, 2010
    great thanks but problem is still active
  • 3,247 Answers
If the 2046 is not starting at all then could be one or many of following reasons
Out of fuel.
Loose or corroded electrical connections.
PTO drive lever is in ON position.
Fuse is blown.
Spark plug wire is loose or disconnected.
Brake switch not engaged.
Engine flooded.
Dirty air filter.
Dirty fuel filter.
Water in fuel.
Bad starter solenoid.
Carburetor out of adjustment.
Engine valves out of adjustment
Depends on what state this happened in. For example stopped working part way and would not start or was it first time start for the day.
If it starts and stops then like causes are
Dirty air filter.
Bad spark plug.
Weak or dead battery.
Dirty fuel filter.
Stale or dirty fuel.
Loose or damaged wiring.
Engine valves out of adjustment.
Below 32°F (0°C)
If you do not have a copy of the Owner' s Manual then you can get one from
http://lawnandgarden.manualsonline.com/mdownloads/6f102417-eaa0-480c-83e0-caf626e0f22c.pdf
Hope this helps. Please post a comment if you need more assistance with this.
Posted on Jun 02, 2010
Need service manual for scotts riding lawn mower. model # s2554
try www,manualslib.com/manual/149701/Scotts-S2048-S2554.html
Aug 14, 2016 | John Deere L100 Series
Scott's 2046 ignition switch broken. How do I remove and replace?
There should be a rubber slotted cover that key goes through. This should pop off with a screw driver to expose hex nut. Unscrew hex nut and replace switch.
Oct 18, 2013 | Briggs & Stratton Starter Scott's Equip...
I have a husqvarna 2046 with a kohler engine. While mowing, the mower died. I disengaged the blades and tried to start it. It will not turn over and have no power. Hour meter doesn't come on. I was...
The Husqvarna mowers are from AYP, the main fuse will be located by the side of the fuel tank, it will be an automotive style fuse probably around 20amps
Jun 07, 2013 | Garden
The plastic starter gear keeps breaking on my 24 hp. I have inspected the flywheel gear and it is in good condition. I get one or two starts and then the gear breaks. This last time I thought it was going...
The lawn mower you have is manufactured by the John Deere Company. They handle all inquiries and complaints on these lawn mowers. You can contact them at 800-537-8233
Hilary @ Scotts
May 13, 2011 | Briggs & Stratton Starter Scott's Equip...
I have a scotts mower 21595x8b with a loose spring/wire who goes from speed control mechanical stick to rear of the engine,no start
The lawn mower you have was manufactured by the Murray Company, which has been purchased by Briggs & Stratton. For parts and service, you can contact the Murray Division of Briggs & Stratton at 800-258-5011
Hialry @Scotts
May 02, 2011 | Garden
Scott bonnar lawn mower service manual model 520
i have a scott lawn mower,i have run it dry of fuel went to refuel.now it won't start.have cleaned the spark plug and poured fuel thru the carb any clues
May 17, 2010 | Garden
I need to see a belt routing diagram for a Scotts Mower
This is for a Scotts 1642. Picture yourself sitting on the mower looking down at the deck. Starting at the tractor pulley, the belt runs from the right side of this pulley to the left side of the tension arm pulley, around this pulley to the left side of the right hand side mower blade pulley, around this pulley, across the deck to the smaller left hand side idler pulley, then up to the left hand side mower blade pulley, around this pulley to the second (larger) idler pulley, around this pulley and back to the left side of the tractor pulley. If you make a small sketch of the deck pulley arrangement it will be easier. Keep in mind some of the pulleys are for the "V" side of the belt and some (The tension arm pulley & larger idler pulley) are for the flat side of the belt. Be sure the belt is not twisted and lays in a continuous circle with the "V" side of the belt on the inside before you start.
from http://www.ssbtractor.com/wwwboard/view_all.cgi?bd=lawn&msg=135
Please vote !!
May 12, 2010 | Garden
Scotts 1642 riding mower take foot off brake engine shuts off
Sounds like the safety switch in the seat is bad or disconnected. Look under seat to see if anything is unplugged.
Nov 05, 2009 | Briggs & Stratton Garden
Scotts reel mower gear problem
I found some replacements at http://www.reelin.com. The parts number for the pinion gear is 30737-2, 30737-3 (left and right) for the Scotts Classic.
You can find the owner's manual, with part numbers, here:
http://www.reelmowersetc.com/2000-20.pdf
Jun 09, 2009 | Great States 20" Scotts Classic Push Reel...
Drive Belt routing for Scotts Riding mower
I have to replace the belt part number m124895 on a Scotts riding mower.I need the belt configuration,since i bought it used.
Please help
Sep 25, 2008 | Garden
Garden Logo
97 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
