Question about Bosch Axxis WFL 2060 Front Load Washer
I have a WFR2460 Bosch washer and I had lots of water coming out from the soapdispenser, how to fix that and how to get the front panel off this machine? Thank you
  • gunternator Jun 03, 2010
    Thank you, could there be a blockage in the hose going down to the drum?
    Gunter
    Brigadier General:
  • 3,513 Answers
Thanks for contacting Fixya.com.
This is caused by a blockage. The small fabric conditioner compartment in the soap dispenser drawer has a removable plastic cap. This cap fits on the top of a tube which has a hole running through it where the water should siphon through.
When the time comes for the fabric conditioner to be released, cold water enters the small compartment and just washes the conditioner over the top and down the dispenser to the tub. When the water stops flowing, all that is left is the clear water. This water should siphon up the inside of the cap and down the tube.
This tube often gets blocked with the conditioner and if you remove the dispenser drawer and take off the cap you can give the whole thing a good clean out. If the cap is missing, the siphoning will not occur.
To test the function, hold the soap drawer under the tap and allow the water to fill the fabric compartment to overflowing. When you turn off the tap, the remaining water should slowly siphon out of the hole under the cap.
Also it’s a pressure fault caused most likely due to a blockage. Unplug your machine and remove the top. You will see a round switch with a number of wires going to it and a thin pipe at the bottom of the switch. This is the pressure switch that controls the level of water. the water goes into the pipe at the bottom and builds up air pressure within the pipe which operates the switch. the water should never come up this pipe to the switch.
You now need to follow this pipe down to the bottom of the machine. There it will be fitted with a small spring clip to a pipe, or small chamber. This is where your blockage will be and you now need to find something to clear this without damaging any parts. When done replace all pipes secure and test machine.
Let us know if you have something more to know else please accept the suggestion.
Thank You.
Posted on Jun 02, 2010
Bosch wfr2460 washer not working after replacing motor with new motor- will not spin at all
Have you checked to see if it is wired correctly? Next, is there a run capasitor that goes to the moter, ir is it wired directly to the moter?
If it has a capasitor, you might need to change that. Any time you replace a motor, you always replace the capasitor with it. Let me know what you find out and we can move forward from there.
Oct 18, 2013 | Bosch Classixx WFC 2465 Front Load Washer
Leaking drain pump
Yes its very semple takes about 20min.
Jul 05, 2010 | Bosch Axxis+ WFR 2460 Front Load Washer
What does F02 fault mean?
Hello elaineginolf, welcome to Fixya. Error code "02" typically indicates a lock problem. Since not all models are the same can you clarify the model of Bosch you have ? The post category says WFL2060 but that can't be since that model has no display and faults are indicated by way of led lights flashing in a set pattern. Could it be a WFR2460 with the digital LED display ? Let me know and I'll see if I can assist you from there. Macmarkus :)
Jun 26, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Last night our Bosch ''Nexxt'' front loader literally ate a sock. At least I think it was a sock. The only remains are black lent. LOTS of black lent. It is giving an E:04=not draining error code. I have...
The best wat to remove the pump, is to disconnect the washer completely from the water supply, remove the drain hose from the stand pipe, unplug the washer, and tilt the washer backwards.
remove the lower plastic panel if there is one, and access the pump from underneath at the front.
Hope this helps.
Dec 19, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Bosch washer WFMC2201UC/15 has E13 error and will not fill
Hi  hartselectri,
Check the drain hoses and pump That code is for a longer than normal drain if it did not drain it would not let you open the door, You need to clean the filter. Remove the circular panel on the front right put a little screw driver in the hole and twist the access panel will pop off. Then you will need to twist the handle of the filter and pull it out you will find what is stopping the unit from draining in there very common. Also have a lot of towels handy all the water in the unit will come out when you pull the filter.
Regards
R.K.
Sep 08, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch wfr2460
after ensuring the sump hose and transfer hoses are clear clean out the pressure system to ensure the water wash level is not more than usual, secondly check whether the waste hose is not back filling from a sink u bend and also check the sink u bend for blockages (usually fat).
if all ok start to check the wiring connections from pump to pcb board, if these are ok then there may be a fault on the board. (pumping problems are usually easily solved with the above proceedure, the pcbs are rarely at fault for bosch but you may be the unlucky one !). tony
Aug 22, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
Washer Probem.. the rubber came off the metal rim.
The rubber is most likely damaged and needs replacing. They make and sell repair kits to fix this. Buy the repair kit from any Bosch dealer and the instructions are included in the package.
Nov 24, 2007 | Bosch WFR 145 Front Load Washer
Bosch WFR2460 Leaks
are you sure it only happens in the spin cycle? and is the leak comming from the bottom front of the washer? most front laoders will leak due to a tear in the belows. that is the rubber boot that seals the washer tub to the front panel. if there was a hole or a tear in the bellows it should have a leak inthe wash cycle also. but there are also other possibilitys too.but its strange to only leak in a spin cycle due to the washer is extracting the water and not adding it. so check and see if it leaks in the wash cycle to and get back to me and we can go from there. looking through my training manual i dont see what could cause a leak in just the spin cycle
Aug 04, 2007 | Bosch Axxis+ WFR 2460 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
