Question about Akai Mpc1000 Sampling Music Production Station
I have an AKAI MPC500 that stalls during startup. I just bought it on eBay, and it came that way. I have a feeling that someone tried to upgrade the OS, and powered down during the upgrade. When I try to load the new OS to a CF card on a Mac or PC, the MPC500 says bad boot format CF and won't recognize the OS upgrade that I put on the CF card. How do I get a clean start to reload the OS
A rOLAND G6 A PRESONUS 16.02 A MPC500 AND A MAC TO WORK WITH PRO TOOLS. I need a diagram and what wires to buy so it works all through pro tools 9
You will need a usb mixer or some other usb audio interface. Most likely whatever you purchase will come with installation instructions. Make sure whatever you get has more inputs than you need for future expansion.
Dec 08, 2014 | Roland Music
I am having my akai mpc2500 fixed and fully upgraded, the engineer has found a problem with the IDE line, apparently the hard drive and cd drive will not work with the machine he has tried a couple of
Hello there,
You dont say what was wrong when you said it was being 'fixed' and a Hard Drive and/ or CD added.
Has it been updated to V1.24 software which fixes a bug in hard drives formatting ? As per the release notes. http://www.akaipro.com/product/mpc2500#downloads
I would very much doubt there is problem with the IDE interface UNLESS this was the original reason you were having it fixed.
I would take it to the AUTHORISED AKAI PRO Dealer to have it inspected.and a PROPER understandable report given to you if the Machine still won't accept a Hard Drive or a CD mechanism.
Go to bottom of page here For AKAI PRO dealer near you. It cannot hurt to get a second opinion.
http://www.akaipro.com/kb
Sep 15, 2014 | Akai Professional AKAI MPC 2500
Bought apx500 from ebay. new 9v battery. plug guitar into amp. no sound unless tuner button is pressed. this then cuts out after a minute or so. sounds drops out.
to me it sounds like a loose connection or solder point is completely disconnected take it to your local shop and should take them not time to look it over. unless you feel comfortable doing it yourself. do at your own risk.
May 30, 2011 | Yamaha APX500 Ovs
When i go to format my cf card in the mpc, the mpc does not allow the do it button to be pressed. when i press it nothing happens it does not even blink red.
Check that your CF card is NOT biggerr than the unit allows... read the specs. A lot of equipment is having trouble with the larger memory cards. Unfortunately the smaller ones are almost non-existent.
May 02, 2011 | Akai Mpc500 Mpc 500 Drum Sampler,cf...
Why does my akai mpc2000xl take so long to boot up
This can have to do with several things. You might have a lot of sounds installed and have a lot of projects that you are working on. You can also have a small memory that is not improving the boot. You can expand your mpc memory, take a look at the link for an example:
http://www.edgetechcorp.com/memory/upgrade.asp?cid=25213
Feb 23, 2010 | Akai Mpc2500 Music Production Center
Broken guitar, needs repair
http://www.guitarjamdaily.com/index.php?option=com_content&Itemid=46&task=view&id=318 Try this if you feel comfortable doing it yourself.Otherwise your local music store might be able to recommend a good luthier in your area.
Aug 05, 2009 | Dean Custom Zone Electric Guitar
Akai Mpc1000 Sampling Music Production Station Logo
296 people viewed this question
Top Akai Music Experts
Michial Gueffroy
drivealot
Are you an Akai Music Expert? Answer questions, earn points and help others
