Question about Toshiba TZ50V51 50" Rear Projection Television
My tz50v51 tosuiba projecter tv stop no picter no sond can do noting no start no stop end the red lith flashing I pull off the plug for 10 min and replug the tv cam back for a time you gat a solution merci
  • Toshiba Master
  • 5,138 Answers
Your STK ICs could be causing the problem, try replaceing both of them STK392-110s Mats has them 1-800-628-1118
Posted on Jun 02, 2010
Sound goes off after 15 Min
Assuming it is not hardware but soft settings...
1) Check and make sure that your TV does not have the timer set.
The Timer feature allows you to set a day and time for the TV to turn on automatically and the device and channel to display when it switches on. If the TV is already on at the requested time, the TV automatically tunes to the channel you designated in the Timer menu.
When the Timer turns on the TV, the following message is displayed: "Press a button for the TV to stay on." Press any button on the remote control within five minutes if you wish the TV to remain on.
Note: The TV clock must be set before you can use the
Timer feature (see preceding page to set the clock).
On/Off
Press down arrow / up arrow to enable or disable the Timer.
2) If not working, try SYSTEM RESET. Press SYSTEM RESET button on the front panel with pointed object (e.g. straight paperclip). TV turns off, green LED flashes for about 1 minute. When it stops flashing turn the TV on again. All settings other than Parental Lock need to be set again using the manual.
3) TV RESET. If all else fails for soft error. Your manual describes this last resort for soft type error. It could be hardware problem needing more expertise.
Manual can be viewed on a computer at
http://www.audiolabga.com/pdf/V32-V32L_Service_Manual.pdf
Aug 05, 2014 | Mitsubishi WD-62531 Projection Television
Tv stopped working and red light started to blink
this problem can be solve by changing the 2 IC of convergence. part # STK 392-110. It would take 30 to 60 minutes to open change and reclose.
Apr 23, 2010 | Toshiba TZ50V51 50" Rear Projection...
Toshiba TZ50V51 powering down...flashing led
Resolder all pins of Z801 on power suppy board.
If that didn't fix it post back.
Jun 17, 2009 | Toshiba TZ50V51 50" Rear Projection...
Red Blinking light
if you have some knowledge about the toshiba tv you may get it to work there are some resoldering and you have to replace 2 ic along with 2 fuses
Jul 20, 2008 | Toshiba TZ50V51 50" Rear Projection...
Toshiba blinking red light
YUp i have the same prob 2 How can We fix it?
Jun 24, 2008 | Toshiba TZ50V51 50" Rear Projection...
Toshiba TN 50V71.
the start up or standby power is in need of troubleshooting. I would start by checking the regulator and horizontal output transistors.
Mar 14, 2008 | Toshiba TZ50V51 50" Rear Projection...
Toshiba TZ50V51 - Power light flashes, tv won't turn on
It is hard to say Toshiba is one of the few manufactures that have good step by step procedures for diagnosing ad repairing your television. There is a manual called Toshiba power supply and shutdown circuit troubleshooting. This is a valuable asset to save hundreds of dollars on repair. You can get this manual at the following link it has your model covered in it for 10.99. It is on page 2 of the toshiba section bottom of page. They will even email it to you if you are interested in trying to repair your own set. Hope this helps here's the link.
http://servicemanuals.vstore.ca/
Jan 24, 2008 | Toshiba TZ50V51 50" Rear Projection...
Toshiba TZ50V51
Small dog or large==coincidental/unrelated to problem!General service includes some very precise soldering==requires chassis pull. One or more micro-fuses will be bad and STK IC's should be replaced.Alignment in servicer menu may be needed after repair completed.
Oct 03, 2007 | Mitsubishi WS-55807 TV
Toshiba TZ50V51 50" Rear Projection Television Logo
119 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
