Samsung TMX3298HF: No power, ticking sound
On another bulletin board, I read that you had an e-version of the service manual for this TV or it's family (e.g., TMX2796HFX). I have tracked down part of it, but am missing a crucial element: Part 5: Exploded Views and Parts list. Might you have that?
Thanks,
Jeff
  • 934 Answers
I have both manuals and a full set of service bulletins - where do I send it??
Bill
premtech@willapabay.org
Posted on Apr 09, 2008
I have a Samsung UN60H6203AFXZA (Version GH02) TV that won't power on and the red standby light is not lit.
Your issues come from the hot side of the power supply. You can replace the power supply and it should work again or if your capable of repairing it yourself you can do that for a few bucks. below is a link for a new PS, also shopjimmy.com would have one
Samsung Power Supply Board BN44 00772A for UN60H6203AFXZA eBay
Nov 23, 2017 | Samsung Televison & Video
Mitsubishi ws 65513
Yes, 1000UF 25v would be fine. just replace all capacitors in DM Board.
Need further help, let me know.
Regards,
Sep 14, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Samsung UN65EH6000FXZA (Version YH02)
There is three possibilities:
1. Defective back lights LED strip.
2. Defective LED driver section integrated in the main power supply.
3. the main board.
How to check it:
1. You need a LED back lights tester to check the strips, or open the panel, use a 3.7 V DC power supply to test each LED diode separately.
2. Use a multi meter to test the out put DC voltage from the connector to the LED strip between the + & - for each section, (like 1+/1-, 2+/2- etc.) it should read 140 - 220 V DC. (need power up the TV).
3. Un-plug the cable between the main board & the power supply, power up the TV, if you get the back lights light up, the main board is bad.
Aug 11, 2017 | Samsung Televison & Video
Lg tv ticking
There is some shorted component/s in the circuit board. The short circuit protection circuit detects this short, and shuts down your TV again and again. That is why you hear these 'tick' sounds repeatedly. Contact any experienced service technician to get your TV repaired. The work is skilled one, which need sound knowledge in electronics, and work experience.
Jul 29, 2012 | RCA TruFlat 27F520T 27" TV
Samsung LNT4065 started flashing 2 weeks ago...unplugged to reset 2hrs later back to normal...made a call to Samsung about this problem...contact with customer service sent email with firmware to download...
I'd say what you really needed in the first place is this:
http://www.ebay.com/itm/BN44-00167C-SAMSUNG-POWER-BOARD-REPAIR-KIT-/110735490949?pt=LH_DefaultDomain_0&hash=item19c8597f85
As to why it went dead...I think (and you should pray) that it's because the original problem just showed up again.
The original problem being the power board not functioning right and NOT what Samsung told you.
Chances are I am wrong, of course.
But I'd bet my lunch over anything any large company service rep reads you from a book.
http://blog.coppelltvrepair.com
Sep 24, 2011 | Samsung LN-T4061F 40 in. LCD HDTV
LCD TV LA40R81BM/XTL tv tick tick sound 5min then strat
Hi my name is Roety,
I can help you with your issue ,
This is most likely a power supply issue
I usually replace the swollen capacitors I can see
A repairman would charge about $300 to replace them for you.
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
Dec 15, 2009 | Samsung LA40A450 40 in. LCD TV
SAMSUNG T.V MODEL; CS-29Z40HE This T.V buy on JULY 2007 PROBLEM; No power; total dead; no red led stby; have beep sound...tick...tick...like not enough power when power on (maybe sound come from relay)....
Check the PTC parts,the primary AC power supply board.Disconnect the power supply board,measurement the capacitors and power tranzistors,measurement the output voltage(155V),connect on the output on 60W electric bulb,if it light the power source is ok and the problem in the horizontal driver parts(trafo,power tranzistor...).
Sep 27, 2009 | Samsung Televison & Video
No picture or sound but a ticking sound
Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. The most common thing to go out on flat panel TVs is thecircuit board that supply power to the screen. Commonly called a Backlight Inverter Board. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptoms.
You have a few choices:
1. You can try leaving the TV unplugged for 30 minutes so the TV can reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Jul 13, 2009 | Samsung LNT3242H Television
I have a Samsung HRL6167WX/XAP rear projection TV and the TV went out one day when the color wheel exploded. What happened was that the color wheel exploded, then the reapir guy came and replaced that,...
yes , u need to remove this jumper , and the whine would go away , the bulletin is unique for each color wheel , the jumper is very small so just take u time to look for it , is located at the dmd board
May 07, 2009 | Samsung HLN5065W 50" Rear Projection...
Samsung LN-T3253H LCD Sound Problems
PEOPLE, YOU NEED TO GO BACK TO THE STORE, BUY THE SAME TV AGAIN, SWAP THE TV'S AT HOME AND RETURN THE "OLD" TV IN THE "NEW" BOX WITH THE NEW RECEIPT. IN THE CASE OF TOO MANY RETURNS, HAVE A FRIEND, MOM, DAD, SISTER, GIRLFRIEND TO BUY ONE FOR YOU AND DO THE SWAP LATER.
NOTE: I REALLY HATE DOING THIS TO THE STORES, BUT IF YOU PAY FOR SOMETHING IT SHOULD LAST LONGER THAN 30-40 DAYS. PROBLEM SOLVED! :)
Dec 10, 2007 | Samsung LN-S3251D 32 in. LCD HDTV
Televison & Video Logo
203 people viewed this question
Top Televison & Video Experts
