Question about GE (PSS26MSRSS) Side by Side Refrigerator
My tfx20 fridge, keeps icing up in the freezer. changed timer and defrost thermostat. no help. the fridge does stop on the set times on the timer but never defrosts. Fan is on constantly, no leaks from the door gaskets, cleaned the dust accumulation, no obstruction from the freezer to the fridgge area.??? Help.
  • David Ransom Jun 02, 2010
    have you ohmed out the heater?
  • 375 Answers
If the frost builds up on the evaporator coil, sounds like the defrost heater may be out. Check continuity.
If the frost buildup anywhere else - there must be an air leak somwhere. Usually it's the gasket or the ice dispenser flap stuck open.
Vlad,
First Choice Appliance
Posted on Jun 02, 2010
Freezer works fine, fridge compartment cools but has stopped cooling as good and has recently stopped cooling. did a manuel defrost on fridge and freezer worked fine afterwards, now doing the same thing...
Oncce the fridge was shut off and left for a while the cooling had come back . If frost is seen it is a good indication as the compressor is working with sufficient gas within.
If after about 6 hours you observe cooling it is possible that the defrost timer is faulty.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
replace the defrost timer, heater or thermostat one you have confirmed to eliminate one by one.
Mar 11, 2011 | Hotpoint  14.9 Cu. Ft. Top-Freezer...
Freezer is cold, but cold air is not circulating in refrigerator
Check freezer fan is working.If ice formed over freezer fan by working. It's a common problem due to irregular defrosting. Keep freezer setting temp at 5 degree. And check defrost timer, thermostat,heater are working properly.
Turn timer with small tip screw driver to shut off fridge. If not shut off, replace timer. Turn counter clockwise defrost thermostat. If fridge not shuts off replace defrost thermostat.Check heater by join the 2 wires in the defrost thermostat. And after 1 minute, unplug power and keep your arm on heater. If it's warm heater is o.k. Otherwise, replace heater.
Once heater starts work at regular interval controlled by thermostat and timer, defrost will be good and effective cooling will also be in fridge compartment.
Jan 24, 2011 | Amana ABB2524DE Bottom Freezer...
My double door frig gets its air passage blocked again and again with ice and it stops cooling. When the ice is cleared either opening the freezer back, or shutting it down, frig starts working, but in...
Hi!!
Let's try this:
Check temp. settings the freezer knob controls thermostat settings, set it about one third of the scale.
The fridge knob, (set it half way) controls a door actuator that lets cold air blown by the little fan in freezer go from evaporator (the one that gets iced up) to the fridge, so, the little fan in freezer is the one in charge of making your fridge work. CHECK FAN, it should come on when you open freezer door for a couple of minutes, it must sound strong, and if you put your hand in front of one of the fridge's air vents you should feel cold air coming out, if no or weak breeze comes out, check passages for obstrucion, if none, replace motor, (about 20 at your hardware store)
I assume your mechanic already checked thermostat and defrost operation, because, if your timer is right, the defrost mechanism will de-ice the evaporator about four times a day.
Check your drain hose for blockage.
Let me know how it worked out, good luck.
If helpful, click below
Apr 03, 2010 | GE GSL22JFR Side by Side Refrigerator
Frost free freezer icing up
It should still be covered under the warranty.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 02, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Fridge Icing up on N1B Candy frost free fridge freezer
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Sep 02, 2009 | Refrigerators
Freezer seems to be working ok, plenty of ice. Refrigerator is set at 37 but thermometer shows 57
How to check parts
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR.
Aug 19, 2009 | Refrigerators
I have to keep the temperature turned up to 9 in order to keep the food at 45 degrees. The fridge is only 3 years old.
If it's the freezer control you keep at 9, it's probably a defrost problem. If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
If it's the fridge temp control you're talking about The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Aug 15, 2009 | Refrigerators
My refrigerator will not keep cold. cold air in freezer none in refrigerator.
OR ..
Aug 14, 2009 | Refrigerators
Warm fridge cold freezer
Hi,advance thermostat setting, to get colder , it's possible you got defrost problem, is there excessive ice building inside back of freezer? to determine if you have a defrost problem, unplug ref. for about an hour,let it defrost, let all ice melt away, it's better to remove your produce, keep doors open to speed up defrosting, after defrosting and cleaning plug back your ref, and let it work for another hour, and check result, if it's o/k, put back your produce, let me know, during hot summer months, regular use (opening) of ref, could cause excessive ice build-up evap. if after defrosting and cleaning ref. work good for 3 to 4 days, but start doing the same thing, let me know, it means you got a defrost problem. also check your thermostat, but first defrost and clean it, that could just be your problem. good luck.
Aug 13, 2009 | Refrigerators
Our 4 year old GE side by side frig suddenly warmed to 64 degrees. Freezer stopped freezing and is at 43. Motor is running.
Really need to know what motor(s) are running (compressor, evap fan inside freezer compartment, condenser fan under fridge)?? Of course, check your temperature (thermostat) settings. Side-by-sides usually have 2 of them. They should be labled for refridgerator and freezer. The freezer control usually only opens a baffle from the freezer compartment to the refridge compartment. The refrigerator temp control is the one that controls the compressor on-off cycles and the temp of refrig compartment (this keeps the refrig compartment from freezing the milk and cokes) If the freezer control/baffle is set too far open, this will cause the refrig temp control to shut off too soon for the freezer temp to get low enough. These controls can get bumped out of the correct setting accidently from time to time.
To check the following, the fridge has to be running, or in a condition where it "should be" running: If compressor is running (condenser fan should be too), check if evaporator fan (inside freezer) is running. Open (freezer) door and hold door light switch in when you check evaporator fan operation (some fans stop when door is open) If it is not running you may have a bad evaporator fan motor. It could also be a bad defrost timer, causing the evaporator (also inside back of freezer) to ice-up. This blocks the air flow over evap. Also, there is a defrost terminator switch on the evaporator coil that stops the defrost cycle when coil is clear of ice/frost (but timer hasn't ended defrost cycle). If it is defective, that could also keep the fridge from going into the defrost cycle, or taking it out too soon. If it is the timer, change the defrost terminator as well. Depending on how handy you are, you may be able to check/change any of these parts yourself. If you don't know much about elecrical stuff, you should leave it to a repair tech. Hope this helps.
Jun 25, 2009 | GE Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
255 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
