Question about Hoover F6212-900 / F6215-900 SteamVac Agility Upright Vacuum
F7452900 the brushes won't rotate during floor cleaning
  • 3 more comments
  • early1 Apr 09, 2008
    Suction works and everything else except the brushes won't spin.
  • akslarson Apr 19, 2008
    The rotating brushroll has stopped rotating, or starts and then stops when it hits resistance and then won't restart.
    I have taken it out and it turns freely on its own axle. Checked for something jamming it. Reinstalled. Same problem.
  • muscroft2007 Jan 07, 2009
    brushes will not turn
  • Anonymous Jan 18, 2009
    I've owned this cleaner for about a year. I have used it five times. My brushes have stopped rotating as well, and I have done everything the manual suggests to get them working. The square hole that drives the shaft to rotate the brushes does not even move. I have read something about a turbine (not a belt) spins the brushes, and it's an expensive repair. If that is the case, I will never ever buy a Hoover product again. This is the biggest ripoff appliance ever. If someone has an answer, I would appreciate it.
  • Anonymous Apr 06, 2009
    same plroblem Steam vac brushes won't rotate went through the steps up to removing the floor switch, how do you remove it?
  • 3 Answers
Solution for Hoover SteamVac (F7452-900) brushes not spinning
Uses the turbine model and same solution would be similar. Root cause is simply the main gear attached to turbine becomes stuck. This problem should not happen as often as I see other people also having this problem. Must be a poor design on Hoover’s part. It takes about 30 minutes and a Phillips screw driver and wrench. Pretty easy, just have to remember what screws went where.
Remove brushes, and front suction cover
On the bottom of the machine:
Remove the 4 screws behind brushes which attach the top faceplate
Remove the 2 screws from base in the sunken holes
Remove the two long silver screws from base which connect all the way to turbine assembly
Stand machine upright
Remove the floor select switch handle
Remove 1 screw near the center beside the intake hole
Remove the 2 screws over the rear wheels
Remove faceplate cover, the front will need to be gently pried over the clear plastic part, be careful about the upright disengaging lever under faceplate, move it under the metal wire
Remove the 2 screws in the front of the turbine assembly
Remove the 2 hoses on either side
Disengage the bar on the floor selector switch
Pull out the turbine assembly
Remove the 4 screws and 3 clips to separate the assembly
Remove the filter (which is most likely clean since, cleaning this is the manufactures only solution)
Remove the large white gear and with a wrench remove ball bearing
Remove other large white gear
Note that the metal gear attached to turbine will not move (this was my problem), with a wrench gently grab metal gear and twist free. Spin turbine to make sure it moves freely.
Put everything back together again and you should be good to go.
Posted on Jan 24, 2009
Thanks to Mark406 for the excellent instructions to get down to the turbine. My problem was not as simple as his though. When I got to the turbine, I discovered that water had gotten in and the roller bearing was a rusted mess. I initially thought that just a thorough cleaning would do since all the gears and turbine would spin freely. But when I buttoned up the turbine and tested it, it would bind. I finally noticed that the bearing was frozen on its spindle. I broke it loose but it won't be long before it freezes up again. No way to lube it. Only solution would be to pull the bearing and press a new one on.
Posted on Feb 01, 2009
Buy another at the same place, put the bad one in the bow and write "DEFECTIVE' so they will return it to Hoover.
Posted on Aug 03, 2009
My Guardian had the same problem. I found the solution on another website (http://www.info-vacuum-cleaner.com/electrolux-vacuum-faq.php)
This worked for me!
Q: How come the roller on my Electrolux canister vacuum does not work?
A: Some Electrolux canister powerheads have reset buttons. Electrolux vacuum cleaners tend to utlilize a geared vacuum belt. Geared belts don't break easily. If the roller got jammed up (by the end of a carpet or a hand towel, whatever) the powerhead will shut off, protecting the vacuum motor from any damage. The reset switch is a small red button located on the top of the powerhead.
If pushing the reset button didn't work (you don't hear the motor), it's one of two things. The roller is still jammed up or you have an electrical short somewhere starting from the hose to the powerhead.
Posted on Jul 20, 2008
The plastick gears is broken
Posted on May 24, 2008
2 Suggested Answers
  • 120 Answers
SOURCE: Brushes don't rotate during floor cleaning
Check that no strings or other debris is clogging the brush wheels. If it isnt that check that the belt isnt broken connecting the brush to the motor. If that is ok, most likely the motor is blown and not turning the belt.
Posted on Sep 20, 2012
Our DC41 is impossible to push on carpet. Is there an adjustment to do? Almost like there is too much suction.
See if the following information can help.
CARPETS OR HARD FLOORS
• The brush bar will always default to 'ON' (spinning) each time you switch the
appliance 'ON' and recline it for cleaning.
• The brush bar will not rotate when the appliance is upright.
• To switch the brush bar 'OFF' (e.g. for delicate rugs and hard floors):
- switch the appliance 'ON'
- recline the appliance
- press the brush bar 'ON/OFF' button - the brush bar will stop spinning.
• The brush bar will automatically stop if it becomes obstructed. See 'Brush bar -
clearing obstructions'.
• Before vacuuming your flooring, rugs and carpets, check the manufacturer's
recommended cleaning instructions.
• Some carpets may fuzz if a rotating brush bar is used when vacuuming. If this
happens, we recommend vacuuming in 'hard floor' mode and consulting with
the flooring manufacturer.
• The brush bar on the appliance may damage some carpet types. If you are
unsure, turn 'OFF' the brush bar.
Dec 31, 2014 | Dyson Bagless Upright Vacuum DC41 Animal
Why does the brush continue to rotate on bare floor setting as well as using hose attachments?
Hello! The brush roll shut-off feature is on select models. Your vacuum may or may not have this feature. If it does not, the brushes will continue to rotate while hose is removed or in use and at all times while cleaner is on. The vacuum must be in the upright position to lift rotation brush off the carpet when cleaning above the floor. Be sure the vacuum does not tilt forward when doing above floor cleaning. Hope this was helpful!
Aug 10, 2014 | Dirt Devil Vacuums
Sep 20, 2012 | Hoover F7425-900 SteamVac V2 Widepath...
Brush roller not spinning. belt, spindle okay. roller taken out and cleaned, no thread. replaced but no dice. ???
Use only BISSELL Style 10 Replacement Belts (#32074) in your BISSELL PowerForce Bagless.
  1. Unplug cleaner from electrical outlet.
  2. With Rotating Floor Brush removed from vacuum cleaner, grasp old Drive Belt and remove from Motor Pulley. Discard old Drive Belt.
  3. Place new Drive Belt over Motor Pulley and stretch other end over Rotating Floor Brush in the space between the bristles.
  4. Place ends of Rotating Floor Brush down into slots on sides as shown.
  5. Turn Rotating Floor Brush by hand several times in the direction of Motor Pulley. If properly installed, Drive Belt will center itself on Rotating Brush.
  6. Reposition Brush Cover and snap back into place. Check to be sure all three latches are secured.
  7. When you turn on the vacuum, do you see the motor that spins the belt spinning at the bottom? If not, it sounds like you may have a burned out motor.
If suggested solutions do not correct the problem, call:
BISSELL Consumer Services 1-800-237-7691
Monday - Friday 8 a.m. - 10 p.m. ET
Saturday 9 a.m. - 8 p.m. ET
Jun 01, 2011 | Bissell 6594 PowerForce Bagless Upright...
Need to replace belt and cannot figure how to take it apart to get at the belt --- Took Screws off on the bottom but could not get to the belt
You have already removed the screws so lift the brush cover off. Then grasp rotating floor brush at both ends and lift. Clean strings,hair and other debris from rotating brush, paying close attention to the brush ends. Clean the debris from motor pulley and drive belt areas.Grasp old drive belt and remove from motor pulley. Place new drive belt over motor pulley and stretch other end over rotating floor brush in the space between the bristles. Place the ends of the rotating floor brush down into slots on the sides. Turn the rotating floor brush by hand several times in the direction of motor pulley. If installed properly, drive belt will center itself on rotating brush. Reposition brush cover and screw back into place. I hope that this helps you!
May 26, 2011 | Bissell 3591 CleanView Bagless Upright...
I have a Hoover F7458-900 steamVac all terain. I
You can reach under the brush (on top) and pull down. The manual for an all terrain is here to download
F7452900
Apr 10, 2010 | Hoover F7425-900 SteamVac V2 Widepath...
Need to remove bottom brushes of Hoover Steam cleaner F7452900 to clean
Here is the manual that came with the vacuum if you didn't have it already, in it on page 13 of the pdf shows you how to remove the bottom brushes.
www.thinkvacuums.com/pdf/uprights/Hoover_F7452900.pdf
Aug 25, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
No suction from upholstery attachment
http://www.hoover.com/pdfs/manuals/F5914900.pdf
Problem: Low suction
Problem: Clean solution won’t
dispense
Problem: Brushes/brush indicator
won’t rotate during floor cleaning
Possible cause
Possible solution
• Not firmly plugged in
• Plug unit in firmly
• No voltage In wall plug
• Check fuse or breaker
• Blown fuse/tripped breaker
• Replace fuse/reset breaker
Possible cause
Possible solution
• Recovery tank full/automatic
shut off engaged
• Remove and empty recovery tank
• Blockage In tool on end of hose
• Remove tool and clear blockage
• Recovery tank lid not on
correctly
• Make sure lid is on securely
• Recovery tank front panel not
replaced after stair or upholstery
cleaning
• Replace recovery tank front panel
(page 14)
Before using tool
It may be necessary to remove air from
the system (“prime the pump”) so the
clean solution will flow to the tool. Follow
these steps:
1. Attach tool to hose and turn the carpet
cleaner ON.
2. Put the tool on a hard surface or
against your hand to block off the suction.
3. Wait a few seconds (can take up to
15 seconds). Then squeeze the trigger
and begin cleaning.
GOODLUCK!!!!
Jun 17, 2009 | Hoover SteamVac F5914-900 SpinScrub...
My hoover steam vac is not releasing the cleaner
http://www.hoover.com/pdfs/manuals/F5914900.pdf this is the manual for your model
Godbless
dispense
Possible cause
Possible solution
Possible cause
Possible solution
shut off engaged
correctly
cleaning
(page 14)
Possible cause
Possible solution
• Solution tank not firmly in place
• Make sure tank is securely locked in
position
• Solution tank empty
• Refill tank according to instructions for
surface being cleaned
correctly
• Make sure lid is firmly in place
• Pump needs to be “primed” (when
using tool)
• See “Before using tool” section, p. 13
Jun 15, 2009 | Hoover SteamVac F5914-900 SpinScrub...
DC07 bottom brush does not rotate.
I can not pinpoint what exactly solved the issue. I opened the bottom conver, cleaned any presence of hair, cleaned all hoses (yes hose was completely clogged), made sure that the brush bar was engaged by switching the selector back and forth few times from Carpet to Bare floor. (On bare floor setting, brush bar won't rotate).
Now I am happy that the vacuum is completely cleaned and back in operation!
Nov 05, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Hoover F6212-900 / F6215-900 SteamVac Agility Upright Vacuum Logo
1,197 people viewed this question
Top Hoover Vacuums Experts
Roger Potts
Ryan S
Ryan S
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
