Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Craftsman riding mower jerks and slips while pulling forward. you can go to reverse then back to forward and it will work a little. replaced bith belts. no change
Nick_Savage
  • 45 Answers
SOURCE: Craftsman 42" 19.5hp B&S Stalling
Check to see if all of the belts are in-tact. A belt may have become stressed and out of proportion from sitting for such a long time.
Posted on Jan 04, 2009
  • 6 Answers
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Posted on Apr 06, 2009
wadembly
  • 475 Answers
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Posted on Jun 28, 2009
  • 299 Answers
SOURCE: Craftsman riding mower won't move.
yes it is a bad belt unless it is a hydro-stat(no clutch) you need to look under the mower and see if the belt is on correctly
Posted on Sep 30, 2009
  • 40 Answers
SOURCE: My craftsman 15.5HP kohler riding mower turns over
Try cleaning or better yet, replacing the spark plug. Depending on age and how your tractor was maintained, there are other possible causes.
  • Gummed up fuel system
  • dirty fuel filter
  • defective or misaligned armature/magneto (part that causes your plug to spark, igniting the air/fuel mixture, thus starting the engine)
  • throttle linkage/cable problems
  • low oil level. Some Kohler engines use a low oil shut down sensor which won't allow the engine to run or start to avoid internal damage.
  • Mechanical engine problems
I hope you find this solution helpful. Please rate it thanks for using Fixya!
Posted on Nov 05, 2009
Hi Jerry:
My Craftsman ride on Mower does not have "gears" as such.
There are separate forward and reverse pedals.
Can you give us a model number for your machine?
Jul 07, 2015 | Craftsman Garden
Clutch pulley slippage
you are out of Alignment and need to check the Bearings on your Pulley. They go bad due to Water coming down on it through your deck
Oct 02, 2014 | Craftsman Garden
Why is my Craftsman riding mower model#. 917287140 not moving forward or in reverse
Check to make sure all your likages are properly conncted, could have loose or broken link.
Aug 10, 2014 | Craftsman Garden
I have a craftsman 54 riding mower . It will start but won't go forward or reverse.
Check the lock out lever on the back of the mower. Has someone pulled it out? If so, push it back in and you'll have both forward and reverse then.
Aug 03, 2014 | Garden
Craftsman LT2000 Does not move (wheels do not move). blade engages and works finr
I would lower the deck to the lowes setting and look between the frame and the deck toward rear wheels and check the drive belt it sounds like it is slipping or busted.
May 19, 2014 | Craftsman Garden
Yardman riding mower no reverse forward jerking motion
It sounds like you either have a lose belt that is slipping or the fluid in the transaxle is low, or the transaxle is going bad, if it is a hydrostatic transaxle, drain and replace the fluid first, if that fails, you may have a bad seal in the pump or a worn gear
Oct 16, 2013 | Yard Man Garden
Mower slips in and out of forward gear but rides perfect in reverse;What do I need to adjust?
Reverse is a different gear set than forward gears. Sounds like forward gear set has a broken tooth. Not an easy fix.
Jul 18, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
My craftsman riding mower is a hydrostatic and i parked it a week ago and went to use it today and it will not go forward or reverse
My craftsman riding mower has a lever on the rearend witch on occassion pops out of place and I have to reset it. The lever is on the back just above the little trailer hitch. It is there to put your rear end in neautral in case you need to push it. On mine you have to pull it to put it in neautral and push it in to put it back in gear, it varys from model to model though.
Jul 19, 2009 | Garden
NO FORWARD NO REVERSE
I had the same problem so I looked under the mower and the belt that goes from the engine to the back of the mower was off so I pushed the clutch as far forward as I could and the belt went on it and it worked
May 29, 2009 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
190 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
