Question about Dometic Rooftop RV Air Conditioner
Just bought a used 1987 Real-Lite truck camper. The roof air unit is Dometic as well as the LP/AC refrigerator. When turned to "cool" the air conditioner really draws down, dims the lights, and eventually blows the home AC breakers. It works fine on blower fan only but as soon as I engage the "cool" settings, big brown out. The fridge doesn't work at all. I'm in the Nashville area. Suggestions
  • Dometic Master
  • 6,674 Answers
To start with, if it's plugged in to a 15 amp breaker, and extension cord, the compressor starting up may just be enough to trip the breaker. It will draw close to 15 amps on start-up of compressor, and if there is a light extension cord used to plug it in, that only makes it worse. Make sure you shut all other breakers off in panel except AC, and try it. If you have water heater on hydro, fridge on hydro, and then try to start AC compressor, you'll be way over the 15 amps, especially if it's a light extension cord.
Keep in mind, in order for fridge to work, you need 12 volts DC (Battery) power going to back of fridge. If the controls aren't lighting up at top, you've most likely got no 12 Volt DC power going to fridge. Check all fuses as well.
Posted on Jun 03, 2010
Our Dometic refridgerator in our 1992 camper
I would start there before replacing any parts. The circuit boards require 12volts to operate the refrigerator. If you have a good 12 volts and the LP tanks are full and the flame lights but the unit does not cool then you probably have a bad cooling unit. But start with the obvious issues first.
Sep 03, 2013 | Dometic RM2620 Refrigerator
Rpod ac unit leaking
if the gasket is bad it could leak
Aug 21, 2012 | Dometic Rooftop RV Air Conditioner
We just bought a new 29" 5th wheel camper, that has one 15,000 BTU roof unit. Should this one unit cool the rv?
Yes if its working properly. A 20 degree temp. differential between its supply air and return air its good.
Jul 02, 2011 | Dometic Rooftop RV Air Conditioner
Was given a roof top ac for a popup camper need help
Make and model of unit should be on base of roof assy, please reply with that so we can be sure we have right wiring info for you. Although they are pretty common, let's be sure.
Jul 30, 2010 | Dometic Rooftop RV Air Conditioner
I bought an older camper with a colman roof unit ac. My question is do I need to put small filters under the intake grates inside the camper below the ac cover. There is nothing in there. (bought it this...
its good to put them in, as it will keep dust from building up on the coils, thus reducing cooling.just buy some filter material at any hardware store, coarse, like a sponge, not fine paper stuff.
Jul 30, 2009 | Dometic Rooftop RV Air Conditioner
A/c turns on for 10 minutes
If it was start up capacitors, it wouldn't start initially every time. Do me/you, a favor, and remove your filter inside (return air) , and if it's a ducted system, remove entire plastic cover inside. Take a flashlight & look way up where filter covers in hole & take a good look at cooling fins on evaporator (front of AC). Look for restrictions such as dust etc. That dust will turn just like mud on there due to condensation mixing with dust, and block off flow which could cause unit to freeze up & compressor to kick out. If your real ambitious, and find lots of dust there, taking cover off roof unit would be next, and check same there at back end (condenser) coils & cooling fins.Get back to me after inspection from inside. Could still be electrical but lets check that it has proper maintenance & best chance to work properly by doing this first.
Jul 13, 2009 | Dometic Rooftop RV Air Conditioner
I have a Duo Therm Roof top Camper air conditioner
how old is unit and does it have refrigerant in it
May 30, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
273 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
