Question about Garden
I need an on/off switch for a Century welder, but I can't even find enough information to get a part number.
  • 333 Answers
Need a wiring diagram for a century quick fix wire feed welder
If you can give the code code number I can help you. The code number should be in the same plate as the serial and model number.
Jan 19, 2014 | Welding Tools
Need manual for Century 70 wire welder
Without having the model number (it starts with 117-***) I can't send the proper link, but here's the link to the Century 80 just a newer model but almost the same as the 70:
http://www.lincolnelectric.com/assets/ServiceNavigator/Century/Century/IM888.pdf
Hope it works for you. Have a great day.
Nov 27, 2011 | Welding Tools
I have a century mod 11705093 wire welder. I have replaced the trigger switch. Even before this though, when you pull the trigger without wire in it the feed motor spins freely, when you put wire into it...
That sounds like a direct short short to me. My mig has 1 nylon guide tube,one in front of the feed wheel and one just before it inters the liner.They are both insulating the drive wheel from the wire.If the teeth marks are deep enough they will act like a saw and cut right through the nylon tubes and short out on something.You may need a new liner ,the liner is carrying the current instead of the wire.That may be problem. Thank You for choosing FixYa.com
liner.jpg In addition to guiding the wire, the back end of the liner, shown here, contains o-rings and seals to ensure the shielding gas doesn't escape the gun cable.
May 28, 2011 | Century Welding Tools
I have a Century 155 GL MIG welder, and it will not arc. The fan goes on and it feeds wire, what might cause this?
try the overload reset switch on the back of the unit
ensure the switch is not in purge mode or 0 on the temperature selection dial
ensure the temperature selection dial or rotary switch is fully engaged in the detent location,
not between temperature settings or numbers
check the pc board for a blown fuse
other temperature obvious component-s (fried)
check contractor switch components
Mar 01, 2011 | Century Welding Tools
Have a century 125 gl mig welder 110v and it arc's with out pulling the trigger
Need to ckeck the gun switch trigger the terminals? See if there are grounding out.
Jan 17, 2011 | Miller MATIC 140 MIG WELDING PKG w/cart...
What is required to switch from steel to gas on light duty mig welders
if you mean from flux core wire to gas shielded wire you will need a tank and regulators,and feed hose from the welder to the tank
Sep 06, 2009 | Lincoln Electric LE 83180 Century...
Century mig welder. The wire speed is spinning at max speed as soon as the machine is turned ON. Will only stop when machine is OFF.
My Century 225 mig has lost its power ...with adjustments to max it leaves a high weld deposit and low penertration.
What is the fix ?
Aug 14, 2009 | Lincoln Electric LE 83180 Century...
Garden Logo
47 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
