Question about GE (PSS26MSRSS) Side by Side Refrigerator
How do gain access to a refrigerator fan in a GE PSW26SLRD?
    President:
  • 949 Answers
How to repair a noisy fan in GE GTS16GBSRWW
Remove the back panel to gain access to motor - look for screws back there.. Remove motor and clean and oil motor bearings - make sure fan blades are all even and not hitting anything.
Aug 26, 2017 | GE Refrigerators
How do I access the evaporator fan in a GE apartment-size refrigerator model GTS12BBMARWW?
are u sure its where u say it is and not along the back side of the wall?
Feb 10, 2015 | GE Refrigerators
Where is the drip pan located in a GE Model GTS18EBMDRWW?
Inside the kick panel at the bottom. The panel is pulled out to release it and gain access to the pan
Dec 30, 2012 | GE Refrigerators
Where is the defrost heater on a GE side by side?
the defrost heater is located in the freezer section behind the back panel wall... you will have to remove any shelves and back panel to gain access to the heater....
Jan 25, 2011 | GE Refrigerators
Freezer and fridge not maintaining coolness level
check the fan motor. usually behind the unit toward the bottom. you may have to remove a few screws on the cover to gain access. once you do this, look for a small cylindrical unit connected to a fan, it'll have a couple wires coming from it. check to see if it kicks in at all. if not, smack it a couple times with something light, like a screwdriver handle. if it kicks in, that's your problem. if it's not your fan, your freon level may need to be checked.
Dec 20, 2010 | GE Refrigerators
Refrigerator is only going down to 50.2 degrees and there is frost on back wall of freezer.
the frost on the back wall of the freezer is a usuall indication that there is a problem with the defrost circuit,defrost heater,thermastat, or the defrost timer.you can use a blow dryer and defrost the evaporator coil.remove the rear panel in the freezer to gain access to the evaporator coil.you also need to make sure that the evaprorator fan is functioning properly.
Nov 14, 2010 | GE Refrigerators
After cleaning coils my refrigerator is still blowing warm air yet the freezer is cold what can I do myself to make the refrigerator cold?
There is a small fan which moves the cold air from the freezer to the refrigerator part. Make sure that this fan is working. If it is not turning, the cold air will not reach the refrigerator.
These fans are easily replaceable; however, you probably will have to remove the interior panels from the refrigerator to gain access.
Oct 09, 2009 | Amana ABB1927DE Bottom Freezer...
GE fridge fan clicks, ice dispenser not working
Main control board problem . Pt # WR55X10656 . The freezer fan motor , works off DC voltage . The board is not giving it enough voltage . The main board , also controls the dispensor board .
Sep 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Side by side GE refrigerator psf26pgta
The fan should be a standard 12v DC computer style fan , test that you are getting voltage to the fan connector . You should also be able to get the fan to run by connecting it to a suitable supply . Once you have eliminated the possibility of fan failure then it gets more involved.
Aug 08, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
67 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
