Question about Samsung Propel A767 Cell Phone
Screen reads "Download". Black screen with red line and in that line it says Download. Have tried taking out battery and re-inserting....nothing seems to work
    President:
  • 1,561 Answers
This could be virus problem on your phone, since you said you have taken battery out and inserting back, did not still work, it means you will need to flash your phone.
You will need to flash the phone with a software in other to restore the phone back. Go to any phone service center and tell them you want to flash your phone, they will help you flash the phone and your phone will be restore back.
Before going to flash the phone, you can try this to see if it will fix the problem, power on the phone, during the process of the phone powering up, remove the battery, this is a hard reset on the phone, it may fix the abnormality, but if not, then proceed to flash the phone in other to restore it back.
Take care.
Posted on Jun 02, 2010
Loss of complete power on js48ppdbdafridge checked circuit breaker, cord and outlet. I would like to check the main board with ohmmeter not sure how. Can you please provide as well as any other cause.
Be extremely careful as a small mistake could result in severe shock, serious burns, explosion or even *****. 1. Ohms meter 2. 2 probes (red and black colors) Tip: *Insert the red probe into the slot marked V (+) *insert the black probe into the slot marked COM (-) *Turn the rotating knob at the centre of the digital multimeter to the reading/marked indicator V~ (700value) **make sure you can see V~ and that it matches the color of the 700 value Crosscheck this last part very well please. (V~ 700value) **Switch the digital multimeter on (observe that it reads 000 on the display screen) **hold the test probes by the plastic handle, apart and in either hand. *approach the Main circuit board, where you have the breaker. **Balance yourself well on a firm support and make sure no part of your body makes contact with the Main panel whatsoever (you have live mains active) *without allowing the test probes to contact or touch each other, insert the exposed metal tip and touch the live cable, (red for the supply line, exposed part) with the red colored test probe **follow up by touching the black colored test probe (exposed tip) to the black cables Remember; no part of your body must contact any metal part of the mains circuit board/panel Remember, Both test probes must make contact at the same time with the live and neutral lines you are testing **check the value displayed on the screen of your digital multimeter A safer option is to keep your Mains board switched on and then observing the precautions as outlined above, insert the test probes into the socket/power outlet/receptacle on the wall (point where you insert the plug of your fridge on the wall) Switch the wall socket on. Each test probe goes into different slots/holes on the wall socket please. Take your reading on the DMM
Oct 14, 2017 | Exercise & Fitness
MRI ER710 only gives black screen after hitting the power button
try removing one by one components and then try to start.
if there's some beep code or flash pattern then do tell !!
that might take long process of troubleshooting..
do contact me to solve it.
Jan 23, 2013 | MSI Micro Star International Computer - 17...
Blank screen
Try this...if you can still get into the setup menu, scroll to "reset" and follow the on-screen instructions. If not, remove the memory card and battery...press all the buttons...leave the camera alone for 20 minutes...insert the card and then the battery...turn it on. Did that help?
Sep 28, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
I was viewing my pictures and all of a sudden an error popped up on the lcd screen that said "Read: Error" and thent he screen went black and it was as if the camera died. I plugged it in to charge it but...
Take out the card and download any pictures on it using a separate card reader if necessary. With the battery and card out, press all the buttons, insert the card and then the battery. Try turning it on. Also, go to the Fuji website to check for any firmware updates.
Aug 26, 2009 | Fuji FinePix Z3 Digital Camera
Changed out black ink screen says insert
It will be a hardware printing problem mostly. Try cleaning the parts with alcogol or/and elastic rubber. Also try to increase the force of contact with a sticky tape or like that.
Aug 09, 2009 | Lexmark P6250 All-In-One InkJet Photo...
Problem with my Blackberry Curve 8310
You will need to replace your battery with another one.
Jan 29, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Thick Black Line on Screen
This is caused by dead pixel sensors. There are hundreds of pixel sensors at the edges of the screen, when they go out it will cause a line varying in size depending on the amount of sensors that go out, and the line can vary in color, red, blue, green, white, and black. Unfortunately, the only fix for this is to replace the screen.
Jul 30, 2008 | Computers & Internet
Big black dot on main screen
well...unfortunately that cant be fixed. you can try a software flash, which would just require that u take it to a vzw direct store, and back up ur memory because it could be erased. otherwise, ur phone has a 1 year warranty, take it to a store or call tech support to get a replacement.
Jul 03, 2008 | LG enV VX9900 Cellular Phone
Gateway notebook problem
Black Screen of Death - BSoD Black Screen of Death or BSoD computer dictionary definition and information.
Dead or black pixels. Information about dead or black pixels on a lcd or computer display. ... Determining how many dead pixels are on the screen.
Good Luck, Please dont for get to Vote/Thank You.
Dec 22, 2007 | Gateway 450ROG Notebook
Samsung Propel A767 Cell Phone Logo
83 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
