Have beko 32inch L C D , when i power on it comes on for a 5second and then the screen goes black, i still have sound, just no picture? model no 32WLK53OHID and back light is working i cant see any thing on screen no menu nathing on it .when i turn on the tv i can see picturs abut 5 ..6 seconds then from left side geting dark and its spred to right side within second but sound is there am using R F in antena and i tryd dvd player but i cant see any thing when the prob starts i can here the hmmmmm.. sound from power suply side
    President:
  • 1,099 Answers
This can be solve by the following
if the backlight is powering up a bit with a slight glow the issue you are having is about 90% chance of being either the backlight power supply inverter or the main power supply have dropped one of the output voltages. If you would like to try and repair it yourself, you can take the back of the unit off and get to the power boards. Look on both boards for parts called capacitors that have bulging tops. When the start failing in the power supply boards one of the classic symptoms is no video just as you have. If you see the bulging capacitors on the board they will need to be replaced and you should have a fully functional TV again. Yes, You will need to use low ESR, high temp and high ripple current capacitors.
Thanks for asking.
Posted on Jun 04, 2010
  • jayampathi44 Jun 05, 2010
    hi
    thx for reply back light is working good and i cant see any bulging capacitors on the board but i can here hmmmmm sound from one transformer when i power on y is that ??
    thx
  • Sanyade Akinwale
    Sanyade Akinwale Jun 05, 2010
    Hello
    The only solution for this problem is for you to get a new power supply board try website like
    websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
    thanks for the comment..
  • 19,396 Answers
Re:"i can see picturs abut 5 ..6 seconds then from left side geting dark"
That is either a faulty inverter or a faulty PSU. The parts must be tested to find the culprit.You do not fix this using a remote.
Testing must be done by a technician, by testing voltage from PSU to inverter. This will be the higher DC voltage from PSU.
The inverter can be tested reading DC out from digital controller (I think 20V on this TV). If there is volts, then the inverter is bad. If there is no power in the connector, then inverter is OK, and problem is likely PSU.
Goodbye.
Posted on Jun 03, 2010
Spectre 32inch led ty picture center faded
Check the panel Screen If voltage Is there?
Nov 04, 2012 | Sceptre Televison & Video
My 32in beko tv keeps blinking and will not stop. The sound And picture is still good the screen Just goes black every other second Model nr 32WLZ530HID Service info Ix-Id tv...
It sounds like the backlight inverter circuit has developed a fault. This can usually be cured by changing some transistors and capacitors, or it could be a poor solder joint.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 22, 2011 | Beko Televison & Video
My 32inch LCD tv screen goes black and no video shows while the sound evrythingf else works. what could be wrong? am i looking at a large cost to repair? cheers Aa
Now,tv turn on u have a picture few sec.than dies have sound left only?Yes,than those 2 tv long boards call the LCD inverter boards are dead.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 refurbishes long LCD inverter boards for the replacement.
Jan 30, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Beko 32inch L C D model no 32WLK53OHID I NEED POWER SUPPLY PIN OUTS (wich line to wich part and voltage of each line ) from power supply
Hi.
I have problems locating the chassis number correspondent to this model number. I will need chassis number to locate service manual.
Please double check the model number and check if there is chassis written on service tag.
Here manuals for different Beko chassis.
See also here.
Jun 02, 2010 | Televison & Video
Have beko 32inch L C D , when i power on it comes on for a 5second and then the screen goes black, i still have sound, just no picture? model no 32WLK53OHID ITS NOT LED TIS IS LCD
Hi
Thanks for using FixYa. To check what has gone bad you’ll have to open the back of the unit and check the backlight inverter board. The inverter is the power supply source for the backlights. If that’s the issue then it’s always better to replace the inverter board completely just to avoid any future issues. If not then check the power supply board however, it seems to be the inverter board as the sound is still working fine.Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 01, 2010 | Televison & Video
Have beko 22inch flat screen, when i power on it comes on for a second and then the screen goes black, i still have sound, just no picture?
the problem is with horizontal driver transfomer...or
140 volt supply may be having a loose contact, or if any loose contact in vertical section it may happen,,,plz contact a service pro... u can not do it urself..
Apr 02, 2010 | Beko 324250WN 28" TV
No picture Screen black
Hi, you need to get your TV kit replaced... Please reply with the model number of your TV if you repairing it by your own.
Jul 20, 2009 | Protron Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
