Question about Emerson Televison & Video
Have a Emerson 32'' tv/dvd/vcr. Has not been used in 2 months, walked into bedroom today to check something & saw the #'s 2 in each corner & in the middle of screen was: BA4-0.15EB, turned isobar unit off for 10 secs, when i turned it back on, the #'s 2 had dissapeared from the screen but the center msg was still there! Also just below center & to the left was two --(dashes). The entire time the TV was off. Is this a Video chip problem, it is a tube tv! ie: just checked unit, have been out of room 4 hours. Dashes have been replaced with OD & 2's are back in all 4 corner's! What gives??
  • Dean Martin Jun 08, 2010
    I got it figured out, during an electrical storm, power went out, when it came back on, tv turned on, but had those error codes in the places where i said they were, it was in AUX mode, so i put on main menue, reset tv, the on light was not on . It works fine now! Thanks anyway!
techman
  • 3130 Answers
SOURCE: Sony shows a split screen when DVD plays
If the new player you hooked up is causing the spit screen then you have to go into the set up menu in the DVD player and take it out of prograssive scan.. Its in the wrong fornmat for your TV set. good Luck PS please dont forget to rate this.
Posted on Oct 16, 2006
Orbixx
  • 133 Answers
SOURCE: 'no signal input'
D-Sub is usually used for input from a computer, make sure the TV's input source is set to Analogue or Digital (or DTV) as it seems to be set to accept input from a computer, if you do not have a computer connected, then this is why it is complaining of no signal. It will not automatically defer to normal TV without being told to do so, have a look in the manual, or guess around the remote control to change the source of the signal.
Posted on Sep 17, 2007
SOURCE: 2005 Panasonic LCD TV Model# TC-26LX20
I am also having problems with the same year and model number panasonic, it is at the repair shop now. I think it is a lemon tv. won't buy panasonics anymore. Tried all the fixes recommended by panasonic. It happens after the tv is on for longer than 1/2 hour. It happens with dvds and different hook ups. my samsung is fine on all the same connections.
Posted on Oct 06, 2007
SOURCE: Emerson TV won't stay on
I am currently have the same problem . I just got off the phone with the support tech and he suggested unplugging TV for about 5 minutes and if that doesnt work to unplug TV for about 2 hours. He said that may reset the TV . I am waiting now. If it works , I will leave feedback.
Posted on Mar 16, 2008
SOURCE: What do I do when my Emerson TV keeps turning off by itself?
I had the same problem with mine turning off after 3-5 seconds. After much research I found a suggestion that on some combo units the vcr part could have a power supply cutout if it is not working correctly. I tried to insert a tape and found that the tape mechanism would not accept a tape. I used a little bit of force and managed to insert a tape. I then played the tape forwards and backwards and the power stayed on! I ejected the tape and found the TV then worked just fine. The power has now been on for over one hour. I hope this give you another avenue to try and fix your problem.
Posted on Apr 07, 2008
My tv turns off by itself after 10 seconds
That's good for when you are tired. I would put in my bedroom
Mar 28, 2013 | Emerson EWC19T4 19 in. TV/VCR/DVD Combo
I Need A Remote Code For An Emerson EWC19T5 and One For All URC 4021 remote
Hello
Setup codes for Emerson Tv with One For All URC-4021 remote control are:
0154, 0236, 0463, 0180, 0178,
0171, 0623
The One For All 4 Device Universal Remote Control is preprogrammed at
the factory to operate an RCA TV, a Toshiba DVD player, a Motorola cable
box, and an RCA VCR.To control devices other than the default brands,perform
the following steps; otherwise skip this section:
[1] Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
Highlight or write down the codes and device you wish to program
before starting step 2.
[2] On the remote control,press a device key once (i.e., VCR/PVR,
DVD, CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press VCR/PVR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume, and VCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD once.After programming
a DVD Combo device, you will be able to control channel selection,
volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
[3] Press and hold SET until the LED (red light) blinks twice,
then release SET.
[4] Use the Manufacturer's Codes (starting on page 18) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
[5] Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn't work, try
Searching For Your Code on next
NOTE: If the device does not have a POWER key, press PLAY
OK.
Sep 26, 2011 | One For All URC-3021 Remote Control
My 32" Emerson LCD TV
How old is the tv if you have jammed the inputs or the cords they may be just done replacements parts can be on shopjimmy.com
Dec 27, 2010 | Televison & Video
Emerson VCR/DVD player - can't get tv (cable tv) to play anymore
I have the same problem with my Emerson VCR. When the ADD button is flashing, just press the menu button to exit the menu. It will add. That's the only thing I know to do. Sometimes it works, sometimes it doesn't.
Feb 01, 2009 | Emerson EWD2203 DVD Player/VCR
Need code for Emerson TV,DVD,VCR Combo
I don't know if you guys even need this advice anymore, as it's 1-2 years late, but if your universal remote has a VCR setting, the Emerson 13" CRT TV/VCR combo I have operates under that mode.
The code I used was 002. These may also work: 278, 184, 479, 000, 121, 211, 037, 043, 061, 208
Remember, program your remote as if you were setting up a VCR (and NOT a TV). For instance, on my GE universal, I hold the "code search" button down until I get a steady light. I hit VCR, and then I entered 002. Works like a charm.
Mar 25, 2008 | RCA Universal Remote 3 Device Remote...
Color messed up on tv since lightning strike
your tv may have ben magnetized by the lightning strike.
tv's have an automatic degaussing circuit that demagnetizes
the pix tube when the set is turned on. this degaussing circuit
may not be working or magnetism may have been too strong for
the internal degaussing to correct.
contact local tv repair shop in your area see if they can manually
degauss your set , it should be a min. service charge around $25.
roland
Mar 22, 2008 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
STANDBY BUTTON
call 1-800-256-2487 they will help (maybe)
Dec 10, 2007 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Televison & Video Logo
55 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
