Question about NEC MobilePro 900c Pocket PC
USB Port I purchased a 900c and the product doesn't see the USB or any devices plugged into it.
    Problem Solver:
  • 8 Answers
Are yous sure it is running CE.NET 4.2? I dont think that the HPC 2000 version can effectively use the USB host. If it is HPC 2000 after all, upgrade the ROM. Try http://hpcmonex.net/nec900/roms2.html to upgrade your ROM.
Posted on Dec 30, 2008
Computer doesn't recognize garmin
Your computer uses USB Mass Storage Mode to detect your Garmin unit. If your computer does not detect your Garmin unit, you can try these troubleshooting steps:
Unplug the USB cable from the computer.
Turn the unit off and then back on again.
Plug the USB cable into your computer.
The unit either automatically goes into USB Mass Storage Mode or displays USB Mass Storage Mode as an option on the screen.
Note: If your computer still does not detect the unit, make sure that you plug the USB cable directly into the computer USB port and not the USB hub. If the cable is already plugged directly into the computer, try plugging it into a different port.
If you still experience problems, please contact Product Support.
Garmin car gps
Sep 23, 2012 | Garmin nuvi 1350 Car GPS Receiver
Device not detected
Incorrect, computers have no security measures for USB. Plug the USB device in without ActiveSync running and listen for some sort of jingle and look for any information balloons in the bottom right. If it jingles and says "searching for drivers", your device is fine and Windows is finding it fine. In which case, it's going to be an ActiveSync configuration issue. If it jingles in a somewhat "uh-oh" tone and says "windows does not recognise this device", you're USB device's USB interface is faulty. If it does not jingle at all, you may have faulty USB ports. What would help would be to tell me your Operating System type. Windows...?
Sep 17, 2007 | NEC MobilePro 900c Pocket PC
Computer won't recognize USB port HP Photosmart 7960
when you plug in the printer and turn it on do you get the sound that a USB device as been added
NO :
try a different cable
YES :
it might be worth trying new drivers only ad downloading the latest version direct from the manufacturer
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ps-18223-2&cc=uk&dlc=en&lc=en&os=228&product=305383&sw_lang=
Hope this helps
Dec 14, 2011 | HP PhotoSmart 7960 InkJet Printer
I PLUGGED MY MP3 PLAYER INTO MY LAPTOP USB PORT AND IT USED TO WORK NOW IT SAID THE USB DEVICE HAS EXCEEDED ITS POWER LIMITS OF ITS HUB PORT AND WONT WORK NOW
If you get an error message"Insufficient power to operate USB device" when you plug a USB deviceinto the computer's USB port, then this device is drawing excessive currentthat the USB port cannot supply. The maximum output from an USB port is 500mA. In case such as this, youneed to purchased a powered USB hub and connect this hub into the computer'sUSB port and then connect the USB device into this powered USB hub.
Sep 05, 2011 | Computers & Internet
When plugging my hard drive in my computor tells me that there is a powersurge and the usb port cannot deal with it ? how do I get around this ?
If you get an error message"Insufficient power to operate USB device" when you plug a USB deviceinto the computer's USB port, then this device is drawing excessive currentthat the USB port cannot supply. In case such as this, youneed to purchased a powered USB hub and connect this hub into the computer'sUSB port and then connect the USB device into this powered USB hub.
Dec 31, 2010 | Iomega Computers & Internet
Hp pavilion dv4000 usb port can't use
This error occures when a USB device draws more power than the USB port can supply.
To fix this problem, purchase a powered USB hub. Power up the hub and connect it to the laptop's USB port and then plug the USB device into the powered USB hub.
May 05, 2009 | HP Pavilion dv4000 Notebook
Device not detected
If you are having problems with all usb devices, then you'll probably find that your usb ports aren't configured properly. This means that there probably isn't a problem with the Mobilepro.
Using windows update, (you really need this to be set to search/download all microsoft products), download all available updates using the custom search. With laptops, not all drivers/updates will be available, as they would have been modified slightly by the laptop manufacturer. So you also need to download the most current chipset drivers from your laptop manufacturer's website. This should sort the problem.
Dec 05, 2008 | Computers & Internet
USB Header
The only way is to purchase a USB Board to install in the PCI slot, but that would be overkill since you PC already has 4) 2.0 USB ports. I would exchange that internal reader for an external reader.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 02, 2008 | Dell Dimension 2400 PC Desktop
Mobilepro 900c won't sync
I'm having the same problem. Sorry man. I'll let you know if I find something out!
Zach
Nov 23, 2007 | NEC MobilePro 900 Handheld
Device not detected
download the usb drivers
Jul 29, 2007 | NEC MobilePro 900c Pocket PC
Open Questions:
I WAS TRYING TO INSTALL JLIME ON MY MOBILEPRO 900, EVERYTHING WAS DONE AS PER THE DOCUMENTATION AS PER THE WEBSITE. AFTER ALL THE STRESS OF PARITIONING THE FLASH CARD.. I GOT THE FOLLOWING ERROR.. "ROOT=/DEV/HDA2" NOT found kernel Panic VFS cannot mount I dont understand a bit of this error.. i ahve tried all the zImage files on the website.. but still I am getting the same error. I used the Henchman.tar--------( All the versions avaliable on website" Haret.exe as kernel Bootloader file which read as below # boot a kernel with HaRET # # have the kernel zImage and the Haret executable in the same dir as this file # this file if named 'startup.txt' will automatically launch the kernel when you start Haret # # 'set MTYPE 659' is for the NEC MobilePro900c # # in CMDLINE change 'root=' to point to the location of your root filesystem # eg 'root=/dev/hda1' is the first partition on your CF card # and 'root=/dev/hda2' is the second partition # set KERNEL zImage-2.6.23mp900c set MTYPE 659 set CMDLINE "console=tty0 console=ttyS0,115200n8 root=/dev/hda2" bootlinux i have tried mentioning "hda1" , "sda1","sdb1","sdb2" I believe its not the problem with the Henchman file or is it??? I have the following partitions sdb1 as boot flag which is fat-1GB sdb2 which is of ext2-2GB sdb3 as SWAP-1GB i loaded the boot files in the Fat ie the Haret.exe Zimage and startup.txt file in fat system Please help me out in removing this error and getting Jlime installed in My Nec Mobilepro 900.. I used a transend 4GB flash drive
Jul 16, 2011 | NEC MobilePro 900c Pocket PC
NEC MobilePro 900c Pocket PC Logo
118 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
