Question about D-Link DES-1008D 8-Port Ethernet Switch (790069217708)
DLINK SWITCH DES-1008D
I have this DLINK SWITCH: DES-1008D and it is connected directly to the modem. When i test for connectivity by typing IPCONFIG the details are correctly displayed.. ip addess, subnet mask and default gateway but the problem is that there is no ping reply on the default gateway and no ping reply on any website when i do so. What seems to be the problem, can you help me solve this one?
TIA,
wilardboi
  • 4 more comments
  • talahib May 21, 2008
    I have 3 pc connected in d link swich hub
    when i open 3 pc 1 pc will no network connection
    i tried many time the cable are connected perfectly
    computer 1 computer 2 first open no 3 will not have connection
    first boot computer 2 and compter 3 computer 1 will no connection
  • willard john deypalan
    willard john deypalan Sep 26, 2008
    Yes, my set-up is -> Modem -> 4 port router -> PC's
    My problem there was one of the LED light-up even none of the Computer Unit is connected.
    And i tried connecting a pc directly to the router it has no connectivity, no LED light-on and no ping reply either. Well, now is just bought a switch/hub in replace of that router. And now the network is back to normal. Thanks for you advices!
  • Anonymous Nov 01, 2008
    The computers do not get linked when connected through the d-link 1008D.
    Would you kindly explain the whole procedure from the very beginning... starting form changing the name of computer and the workgroup and even setting in the ip addresses
  • karravkumar Dec 06, 2008
    I have a Broadband Internet connection. They gave a modem from that modem I connected my 2 pc's. Recently I bought a DLINK DES-1008d switch I connected modem & Switch through a stright cable. When I run PING command some times signal is OK. some times request time out. I want a solwation for this problem. Please
  • Anonymous Dec 10, 2008
  • Anonymous Mar 30, 2009
    You guys are lucky. I can't even connect 2 pc's together. I have just connected 2 pcs under the DES-1008D switch and I get a ping randomly but around each 5 min.
    I am sorry D-Link but this is just a worthless piece of ****. Hope the store can change it for better.
Other units cant connect to my installed port hub and were having hight mare connecting it
Posted on Sep 26, 2008
I have dlink switch des-1008D than it was not converty to internet Sering other computer led light not blinking
Posted on Oct 13, 2008
Dear Sir
Did you try to use static ip for the other computer with preferred dns
or try to use a different IP like 10.10.10.1
best regards.
Posted on Feb 16, 2009
    Problem Solver:
  • 17 Answers
It sound like your network is setup as follows;
Modem -> Switch -> pc's
Most ISP's will only lease you a single IP your network should look more like this;
Modem -> routing device -> pc's
Where routing device is an actual router or firewall that leases private addresses to your pc's and routes outbound traffic to the public address your ISP has leased you.
Do you have more than one computer plugged into this switch? Do none of them work?
Posted on May 02, 2008
  • 3 Answers
Me too... the problem is its worked before but when i reformat all my computer i dont know what to do lol
Posted on Apr 28, 2010
Im having the same problem i have Modem>Switch>PC and PS3.
i can only use one ethernet port i can use my pc but not the ps3 and if i disconnect the pc than my ps3 works but the pc wont.
Posted on Oct 22, 2008
Connecting to the modem to dvr
you didnt state the cameras were IP addressable...are they? brand of camera, and which security DVR you were using. Most DVRs wont or dont use the router as it doesnt rotate or change the picture, but I dont know which one you have. Most instead they use a multiplexer .
anyway the manual is here ftp://files.dlink.com.au/Products/DES-1008D/Manuals/DES-1008D_Manual.pdf
for more referance on CC TV try
http://www.aventuracctv.com/dvr_tutorial/default.asp?index=1
Jul 22, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
When i get connected to d-link des 1008d switch port the computer will get automatically configured 255.255.0.0 to subnet mask therefore i have class c ip address and i dont have internet connection...
u no need to worry about the subnet mask 255.255.0.0
just do the following connections
  1. connect a utp cable from modem/router to dlink switch.
  2. connect a utp cable from switch to ur pc
Assign ur pc manually with following configuration
ip: 192.168.100.5
subnet: 255.255.255.0
gateway: 192.168.100.1
and your router with ip: 192.168.100.1 And enable pppoe in ur router.
Thats it you are connected to internet. No need to enable ics etc.
Jul 05, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
We've got the Dlink DES-1008D setup in our office. Since the past 3 weeks, we've been facing disconnection problems. 5 desktop computers, all new and very recent, are connected to this. We've got an...
Ok, the next time when the disconnection occurs. Try the following:
Open command prompt. And try pinging www.google.com, if the ping is successful and you are still unable to access the internet, then you may want to check the proxy settings on your web broswer, or possibly repair/reinstall the browser. You can also try accessing the internet on a different browser.
If you are unable to ping google successfully, then try to ping the IP address of your wifi modem, this is your default gateway. If you are unable to ping this address successfully, then check the cable from the DES-1008D switch to the wifi modem. As a local area connection 'connected' just shows that the link from your PC to switch is fine.
Please try these steps and let me know the results.
Regards..
Apr 05, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
1008d wanting to know what to plug in
The D-Link DES-1008d is an unmanaged switch that does not need any configuration to work. You just need to plug in your device (PC/Xbox/Laptop) into one of the ports of the switch, using an ethernet patch cord, and it would start communicating with it. I think your xbox 360 already includes a patch cable in the box. You also need to connect the 1008d to your DSL/Cable/whatever modem, using a similar ethernet patch cord, in order to get online.
This is all that you need to do as far as your 1008d is concerned.
Mar 31, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
I have some problem with my D-link Des-1008D switch.I used it to connect 2 computer in my home and one cable form Internet shop.At that time, that Internet shop used manual IP to connect PC.And then That...
Does your ISP supply _one_ or _two_ IP-addresses per account?
On each computer:
Click Start
Click Run
Type CMD and press ENTER
Type IPCONFIG and press ENTER
What "IP-address" and "gateway" do you get for each computer?
No, a "driver" for the switch is not necessary, and will not help.
Instead, buy a "router" (with or without wireless capability), and rewire your network:
Cable-modem -> Ethernet-cable -> WAN-port on router
LAN-port-#1 on router -> Ethernet-cable -> Computer #1
LAN-port-#2 on router -> Ethernet-cable -> Computer #2
Turn the cable-modem off.
Turn the cable-modem on.
Turn the router on, to get one IP-address from your ISP.
Restart each computer, to get new IP-addresses for each computer.
Within the web-browser on each computer, disable "auto detect proxy".
Nov 16, 2009 | D-Link DES 1008D (DES-1008D) 8x10/100 Mbps...
How to download the driver of d-link DES-1008D is the model
hey just go to this link http://www.dlink.com/corporate/worldwideoffices/?redirect=%2fdefault.aspx then choose your country, then go to the support tab then at the right side of the sit choose your model then download the driver.
Oct 25, 2009 | D-Link DES 1008D (DES-1008D) 8x10/100 Mbps...
DES-1008D connectivity issues.
Is the modem a DSL or cable model?
Does the router have one ethernet port and a WAN port?
Normally the broadband modem is connected to the WAN port on the router and the ethernet port on the router is then connected to the hub/switch and the computers are then connected to the hub/switch.
The modem gets an unique IP address from your Internet Service Provider and then the router then issues Class "C" IP addresses to each computer that is connected to the switch/hub.
Jul 31, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
...my des 1008d switch won't work?...
Your problem doesn't have much details is the power lights are on otherwise check the Power Supply
Do wirte more specific about the probelms and about the lights which are lights etc.
Apr 03, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
To configure this switch
not instal dlink driver, problem for interner connection
Aug 24, 2008 | D-Link DES-1008D 8-Port Ethernet Switch...
D-Link DES-1008D 8-Port Ethernet Switch (790069217708) Logo
1,994 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
