Question about HP Photosmart C6180 All-In-One InkJet Printer
HP C6180 color copies (on plain paper) aren't full color
HP C6180 color copies (on plain paper) have yellow/gray tones. I replaced a low ink cartridge and received an error message that ink was out of date. I've just replaced all color cartridges with fresh and still have yellow/gray toned 'color' copies. I've recently switched to an iMac - could this be part of the problem?
    Director Badge:
    Uploaded 100 video answers.
  • HP Master
  • 685 Answers
Here's the official HP solution for what you're experiencing. If you try all the steps suggested and you still have a problem, remember that you can contact HP for warranty support for the cartridges you've purchased - even if your printer is out of warranty.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00721052&cc=us&lc=en&dlc=en&product=1153494
One thing I'd try first is to print a self-test page. If you print a self-test page and the colors appear normal, you can rule out the iMac as the source of the problem.
The instructions for printing a self-test page are similar to the c7280 shown in the following video.
(do not delete) HP C6180 color copies (on plain paper) aren't full - utube.png
I am an HP employee. I do not represent HP on this site.
Posted on Jun 02, 2010
Testimonial: "Thanks for the info - this did help narrow down where the problem was! Appreciate your taking the time to respond."
Red and blue tint
Often "grayscale" is achieved by mixing some of your colors (CYM) to form composite black and gray - not necessarily just black from your black cartridge. Often there is some yellow used beneath the black -- so if you are getting a red or blue tint, it could mean something as simple as being low on yellow ink.
Jan 26, 2014 | Office Equipment & Supplies
Photo stat in black and white not working
you may have to wipe the ink cartridge flow area off it may have dry ink on it a damp cloth or wet nap should work or you may have to realign the cartridge and make sure it is in the right way hope this helps
Dec 23, 2012 | HP DeskJet Office Equipment & Supplies
HP C6180. I think the Black color print head is clogged. How to remove the print head for cleaning?
The print heads in the C6180 are not removable.
I would suggest getting an 02 XL black cartridge and an 02 Photo Value Pack (because it includes all colors plus photo paper for much less than the cost of the color cartridges separately ... and YES the are FULL 02 cartridges!) and run several head cleaning sessions from the setup menu.
It should do a deeper cleaning each successive time you run the same cleaning, so run 3 black head cleanings in a row (3 is the deepest).
Then disconnect the power from the unit, press and hold the # and the 6.
While holding the keys, reconnect the power to the unit until you see a reset message or until the unit turns itself back off.
If the unit turns itself back off, release the keys and press the power button.
The unit will gyrate and click and whir for quite some time and eventually settle in to a ready state.
At this point, you should be out some ink, but the unit should be printing again.
If it isn't, there really isn't anything you can do.
You can call HP at 1-800-HP-Invent and ask about their trade-in/trade up options for this model.
You can get really good deals on current model printers by trading in your defective unit !
Usually you will have a choice of about 3 replacement trade in (if the C6180 can be replaced with another C6180) / trade up (equal or better models) for your specific printer.
Jul 20, 2011 | HP Photosmart C6180 All-In-One InkJet...
Yellow ink showed empty. Replaced cartridge with three separate cartridges from three separate stores. It still shows empty and won't print.
I can imagine the frustration but I want you to try this procedure:-
Ink may be new, but their nuzzles may be blocked; depending on manner of storage. To be sure apply a folded tissue paper to the ink nuzzle and press firmly. If the tissue comes off well blotted with yellow ink it means you still have a good amount of yellow ink in it and the nuzzle is not blocked. If not blotted or scantily blotted, it means yellow ink is really low or nuzzle is blocked. To be very sure of this, place nuzzle in a plate/saucer with a bit water so that the nuzzle is soaked. Leave for about 10 minutes. Then apply the tissue again. If still not well blotted it means ink is really low or empty. If new you should return it for a replacement. In the case of blocked nuzzles, the procedure may be repeated over to get results.
Dec 18, 2009 | HP Photosmart C6180 All-In-One InkJet...
C6180 failed alignment test, will not print color properly
All colors need to be present to pass alignment. Usually what I see is the yellow is empty. You can blot the print cartridge on a damp paper towel to verify the inks are working and this also cleans the head.
Jun 29, 2009 | HP Photosmart C6180 All-In-One InkJet...
Compatibles wont work
Try this:
The HP all-in-one product will print black copies using both the color and black cartridges to create composite black in Normal and Best modes. This is necessary to create the correct grayscale shades.
  1. The color cartridge may be out of one color of ink. Perform the steps in the 'Colors are not correct' section above to verify that the ink cartridges are not low on ink.
  2. Verify that the correct paper type is selected in the Paper Type setting.
  3. Some photo paper has different chemical characteristics than Hewlett-Packard paper. The HP all-in-one is designed for use with HP Premium and Premium Plus Photo Paper. The photo paper, paper-type setting should be used with HP Photo Paper. For other paper brands, it may be necessary to use the plain paper or premium Inkjet paper, paper-type settings.
OR: The ink cartage you have may be defective if is a refilled or recharged cartage.
Jun 17, 2009 | HP DeskJet F380 All-In-One Printer
Hp F4180 No copy to Plain paper
If you just replaced the ink cartridges, make sure you've removed the plastic tabs that cover where the ink shoots out. If they are old cartridges, make sure that the nozles haven't dried up. Remove the cartridges and dab a cloth (one you don't mind staining) where the ink shoots out, if all the colours show up, it's clear. If you notice very little colour, or none at all, try dampening the cloth and wiping down the cartridges to promote inkflow through the nozles. Hope this helps.
May 30, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
When I print photos they have a purple tone to them. Could it be the photographic paper is a bit old or is it another problem
how old is the paper, it should have an expiration date on the package.  If the paper is good, it could be that your yellow color in the ink cartridge is low.  Run a printer test page and see if all colors work.
Mar 07, 2009 | HP Photosmart 3310 Printer
When printing, if I select any other form of paper than "Plain Paper", e.g. "Photo Glossy Paper", the print (of a photo) comes out with a distinct Magenta overhue. The true colours are...
Hello Landscapeman ,
You need to specify the paper type when the print dialog box appears. Heavy glossy paper needs to spend more time in the fuser so that the toner is fixed.
Mar 25, 2008 | Computers & Internet
HP Photosmart C6180 All-In-One Is printing All Documnets Faded Colors
Try to clean your printheads or check the level of your inks, maybe you are low on inks. Operating system does not affect any printing outputs as I know. Check your inks also coz HP cannot guarantee the quality or reliability of non-HP ink. If ink cartridges have been refilled, try replacing them with genuine HP ink cartridges.
If the print defect is minor, it might be caused by reserve mode operation. When the printer runs out of some colors, it can continue printing using remaining inks, but print quality may be affected. If cyan, magenta, or yellow is out, the printer can print only in grayscale.
Replace any empty print cartridges. To check ink levels, follow the steps below.
  1. Press the Setup button.
  2. Press the down arrow button until Tools is highlighted.
  3. Press OK .
  4. The Display Ink Gauge selection should be highlighted. Press OK and the ink gauge will display.
OR try calibrate the color:
  1. Open the printer Toolbox :
  • Open HP Solution Center (click Start , then All Programs , then HP , then HP Solution Center ).
  • If you have more than one printer installed, make sure to select the correct printer tab in HP Solution Center .
  • Click Settings .
  • Click Print Settings .
  • Click Printer Toolbox .
2. On the Device Services tab, click Calibrate Color , then follow the onscreen instructions. The procedure takes about two minutes and requires two sheets of paper.
If the steps above did not help, clean the print head.
  1. Open the All-in-One Toolbox :
    1. Open HP Solution Center (click Start , click All Programs , click HP , and then click HP Solution Center ).
    2. If you have more than one All-in-One installed, make sure to select the correct All-in-One tab in HP Solution Center .
    3. Click Settings .
    4. Click Print Settings .
    5. Click Printer Toolbox .
  2. On the Device Services tab, click Clean the Print Cartridges , and then follow the onscreen instructions. Three levels of cleaning are available.
Please let me know if these steps helped you or not. Thanks
Jan 02, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
165 people viewed this question
Seeker5211
Seeker5211
