Question about JVC Everio GZ-MG21 Camcorder
Pro video camera repair
JVC gy hd 100 Y PB PR RCA output connectors
The Y rca connector is broken off . Need to remove and replace.
Need instructions.
the everio is actually not the correct model of camera
  • snight Apr 11, 2008
    need source for replacement part for gy hd
    100 not everio. part is Y composite out
    rca connector.
  • 2,337 Answers
You will need to open your camera very carefully.
Buy a 25W soldering iron and practice some soldering on any other board if you have one before you try it on the actual camera.
You should also should buy a de-soldering pump at radio shack.
When you try to remove the connector, be carefull not to apply any pressure with the soldering iron because you might damage the conductor.
I would suggest to google for some more info on how to solder, just to have a better idea about it.
Posted on Apr 09, 2008
  • Jaime Hernandez Apr 09, 2008
    check this site for some instructional guides.
    Here are some sites on how to desolder as well.
  • 871 Answers
Hey snight
you can just use a small pick or tweezer to take of the broken connector. it wont do much now because its broken.
what you can do is that you can bring that camera to a place where they sell camera accesories and tell them that your looking fore an exact replacement for your jvc.
  • 3 more comments
  • earl norman llanera
    earl norman llanera Apr 09, 2008
    a small pliers will also do.
    you dont have to solder it ye! you just need to remove it right. after removing it, replace with a new one...
    earl norman llanera Apr 11, 2008
    so whats happening now?
    earl norman llanera Apr 12, 2008
    even if its not for your everio or an exact model. it will still be compatible if you try to use it. if the part is a y composite out connector, you shouldnt have much problem with looking to replace that.
    earl norman llanera Apr 13, 2008
    there you go! its not for an everio...
SOURCE:
Black and white screen , cant get out of it
Hi Debbi,
Please check whether you have connected your tv video cable (normally Yelllow colour RCA Pin) to component "Y " in the dvd box.. If yes, remove it and connect it to Composite out Yellow RCA female connector for Coloured output. If you connect to "Y" it wl give only Black and White in component ( Y Pr Pb )
Oct 31, 2013 | Memorex MVD2016 DVD Player
How to you conect a kawasaki dvd to a hd tv
The best connection the kawasaki dvd has is a Component connection. This connection separates the Red, Green and Blue colour signals. Your HD TV should have a component input, just look for Red, Green and Blue RCA inputs labelled "Pr", "Pb", and "Y".
You don't need the red, green, and blue colored RCA's specifically for this type of connection. The colors are there to help make it easier to connect. You can use any coloured RCA as long as you have the Pr on the DVD connected to the Pr on the TV and likewise for the other two connections.
In addition to these connections you will need two more RCA's (Red and White) for the audio signal. You will need to connect the audio output of the DVD, to the audio input corresponding to the same Component Video input you are using for Video. This should be fairly self explanatory when looking at the DVD's and TV's connections at the back.
Oct 27, 2012 | kawasaki 5-DVD Home Theater System - 1152...
Video noise on jvc gy-dv500u
I have the same camera with the same problem.
Mar 09, 2012 | JVC -GY-DV500 w/lens, VF, Fuji 14x1:...
Can you hook up ipod touch to a HD TV or media player
Yes. What you need is an adapter from apple, depending on the type of input your HDTV has. If you need composite, generally denoted by a single yellow RCA video connector and two (Red and White) RCA audio connectors, you need this cable: http://goo.gl/OlSDa Please note that Composite is not an HD signal. Although iPods are not able to output a true HD signal, over component (see below), they will output a slightly higher signal. If you require a Composite connection, denoted by three RCA video connectors (Red, Green and Blue, labeled Pr, Y, and Pb, respectively) plus two (Red and White) RCA audio connectors, then you need this cable: http://goo.gl/yk8Zt Also note that video out on iPods is only supported for certain video formats/video playing apps. Before buying a cable, you should most certainly research whether the videos/apps you are playing/using support video out.
Dec 31, 2010 | Apple iPod touch
Finding a JVC camcorder A/V output cable
Fixya does not sell spares or accessories. Were these items not included in the package when you purchased the camcorder ? They should be available either from JVC Spares themselves, or on Ebay
Mar 28, 2017 | JVC GR-D290 Mini DV Digital Camcorder
Can an adapter be used to connect this unit to a sony hd ready tv. The sony has the round connector for hook up and not the square type. I want to hook up a DCT 3400 Series High-Definition DVR
If your Sony TV is hd ready you have a number of choices of connections you can use. On the back of the DCT 3400 you have regular AUDIO and VIDEO connections, the separate Y, Pb, & Pr connections (both of these use the regular RCA style connectors), RF in (which uses the standard cable connection), and the HDMI connector, which uses a special flat ribbon style connector. Your Sony should have all of these types of connectors on the back of the TV. The separate Y, Pb, & Pr, or HDMI connectors will give you the best picture.
Aug 08, 2009 | Televison & Video
Connection for y pb pr cables
The color-coding used for the RCA connectors is nearly universal:
  • composite video - yellow
  • audio - red (right channel) and white (left channel)
  • component video - green (Y), blue (Pb) and red (Pr)
Also, these jacks are normally labeled in print as well, although it's sometimes hard to read the text on some equipment.
Match the connectors on your converter box to the corresponding connectors on the TV. If your converter box was one purchased with the $40 US Government coupon, it may not have the component video outputs. The only coupon-eligible boxes are the most basic models, and they sometimes have only RF (channel 3 or 4) and composite video outputs available.
May 03, 2009 | iLO 3200 32 in. LCD Television
I am trying to hook up an HD / DVR and my cable serice to a JVC AV2730 TV The TV ony has RF connector (none from HD/DVR box), S-video connector, and Video Component/Y Pb Pr hookups. Which ones do I use? My...
Well first off i am assuming that your jvc ONLY has rf connections?
if so, the most you can do is go get an adaptor from walmart that has inputs for either svideo or components and output for rf.
Sep 13, 2008 | JVC Televison & Video
Jvc hd 100 camcorder
The Video Output Jack Assembly Board is the part you are looking for. Please see below for a link to purchase this item.
GY-HD100 Video Output Jack Assembly Board VJK
Mar 11, 2008 | JVC GY-HD100 Mini DV Digital Camcorder
Mitsubishi WT-46809 Problem getting HD from DirecTV
I have the same exact problem. Same model, etc. Is there a resolution?
Sep 16, 2006 | Mitsubishi WT-46809 46" Rear Projection...
JVC Everio GZ-MG21 Camcorder Logo
50 people viewed this question
Top JVC Video Cameras Experts
Ekse
Larry Stiles
Larry Stiles
Al Rush
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
