Question about ASUS P5VD1-X (90MBL3C0G0EAYZ) Motherboard
Dear master, i haved asus P5VD1-X motherboard problems, its no beep bios and no display but cpu fan normal, green light at motherboard its normal too, i haved try to clean RAM, clean VGA card, reconect Processor, and replace batteray BIOS, but until now my motherboard still no beep and no dispaly
    President:
  • 2,351 Answers
Every Asus motherboard comes with a seperate four pin two wire ( internal speaker). Either you're speaker is not connected properly or the speaker may be bad.
Check manual page 2-28, PANEL. Asus makes these connections easy by provideding a jumper-block as shown below;
dear master, i haved asus P5VD1-X motherboard - c355ca7.jpg The jumper block is clearly marked.
You also mentioned a removal of the CPU. I only hope you cleaned the old thermal grease from the CPU and heatsink assembly with alcohol and replaced with new thermal past. The P5VD1-X comes with a built in AGP card. Settings are configured within the bios menu. I understand you are unable to receive a single to display to the monitor. Connect the monitor to the rear VGA port. When you replaced the bios battery the bios reset its self to default settings. This means the intergrated AGP video is most likely being used by the bios. Remove any added video cards. If you can't receive video to the monitor I would suggest you contact Asus.
For more information call Asus Tech at:
1-812-282-2787. Eastern time. M-F 8:00AM to 5:00PM.
http://usa.asus.com/product.aspx?P_ID=SkuBYErUHJtQw76w&content=specifications
Mike
Posted on Jun 02, 2010
Testimonial: "thanks"
    Scholar:
  • 77 Answers
Thank you for your question.
I have located the manual for your Motherboard on the Asus website and have provided a link for your convenience. The most likely action is to reset the CMOS information.
http://www.manualnguide.com/manual-get/9350/
Page 2-18 provides a visual on the procedure to be followed. If clearing the CMOS doesn't get you to boot up, then I would believe that the motherboard is "dead". Then again, other experts may have some other rescue method that I am not aware of and I would appreciate their input for your assistance.
Kind regards
I'm faced with a black monitor, no boot beep, with an operating fan and green light on. XP OS with an ASUS P5P800S motherboard, Thanks Jose
Remove all components from your mb and bios battery. Place jumper to clear cmos and make short to battery cmos. Leave 1min and after place cpu and one ram in mb. Replace jumper from clear cmos in normal position and verify. If not display, change ram.
Sep 26, 2014 | Computers & Internet
Looking to get new mother board because it went on fire, old mother bd was asus P5VD1-X HAVE INTERL P-4 CHIP AND DDR 400 MEMORY THAT I WOULD LIKE TO KEEP USING WHAT MOTHER BOARD DO YOU SUGGEST
Better to purchase new mobo, cpu n memory. Bcoz the compatible Motherboard for your CPU/Memory is no longer available. If it is available, only from the dead stock or refurbished. Better to purchase new motherboard/cpu/memory
Sep 17, 2010 | VIA Asus P5VD1-X PT880 Ultra Chipset 1066...
I am slowly rebuilding my computer. When I nearly got it finished, and turned it on, it came up with "Windows Was Not Found". Knowing what to do, I turned everything off, unplugged it properly, and...
Check for motherboard. use only 3 parts:
motherboard
PSU
CPU + COOLER
Connect your motherboard to PSU and see, if any LED light comes from motherboard. If LED is on, then try to turn motherboard on and see if cooler works.
Are case wires (power +, power -, hdd +, hdd -, reset+, reset -, power led+, power led - and speaker wire ) connected correctly?
Those wires look like this:
front-panel-headers-nsatmeh50lx5u1woeaeqllmn-4-0.jpgThis image is just reference.
If the power wire (sometimes called POWER SW) is not connected correctly, when you press the power button of case, PC just won't turn on.
If PC turns on and CPU fan spins, then try to add RAM, Graphics card and try again.
Next step is to hear BEEP sound. One short beep sound is normal, anything else is not normal and indicates the problem of the specific hardware according to the sound code. Sound code is BIOS dependent. In case ASUS A8V-E Deluxe, it is Award BIOS. Check below for Award BIOS beep codes
1 long, 2 shortIndicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information
1 long, 3 shortVideo card not detected __ (reseat video card) or bad video card
Beeps repeating endlessly __ RAM problem.
Repeated high frequency beeps while PC is running __Overheating processor (CPU)
Repeated beeps alternating high & low frequency ___Issue with the processor (CPU), possibly damaged
Mar 17, 2017 | ASUS A8V-E Deluxe Motherboard
What is the beep code asus p5ntws
AMI (American Megatrends International) BIOS Beep Codes.
AMI BIOS uses beeps of the same length and pitch. The error is displayed as a number of beeps. For example, 4 beeps indicated a timer failure.
BEEP CODE MEANING POSSIBLE CAUSE
1 Beep (No video) Memory refresh failure Bad memory
2 Beeps Memory parity error Bad memory
3 Beeps Base 64K mem failure Bad memory
4 Beeps Timer not operational Bad motherboard
5 Beeps Processor error Bad processor
6 Beeps 8042 Gate A20 failure Bad CPU or Motherboard
7 Beeps Processor exception Bad processor
8 Beeps Video memory error Bad video card or memory
9 Beeps ROM checksum error Bad BIOS
10 Beeps CMOS checksum error Bad motherboard
11 Beeps Cache memory bad Bad CPU or motherboard
Award BIOS Beep Codes
Award BIOS uses beeps of varying duration. A long beep will typically last for 2 seconds while a short beep will last only 1 second. Award BIOS also uses beeps of different frequency to indicate critical errors. If an Award BIOS detects that the CPU is overheating it may play a high pitched repeating beep while the computer is running.
1 Long, 2 Short Video adapter failure Bad video adapter
Repeating (Endless loop) Memory error Bad memory or bad connection
1 Long, 3 Short Video adapter failure Bad video adapter or memory
High freq. beeps (while running) CPU is overheating CPU fan failure
Repeating High, Low beeps CPU failure Bad processor
Phoenix BIOS Beep Codes
Phoenix BIOS uses beep code patterns to indicate problems. In the table below the '-' indicates a brief pause between beeps.
Example: 1 - 1 - 2 would sound like BEEP <pause> BEEP <pause> BEEP BEEP
1 - 1 - 2 CPU / motherboard failure Bad CPU / motherboard
1 - 1 - 3 CMOS read/write failure Bad motherboard
1 - 1 - 4 BIOS ROM failure Bad BIOS chip
1 - 2 - 1 Timer failure Bad motherboard
1 - 2 - 2 DMA failure Bad motherboard
1 - 2 - 3 DMA failure Bad motherboard
1 - 3 - 1 Memory refresh failure Bad memory
1 - 3 - 2 64K memory failure Bad memory
1 - 3 - 3 64K memory failure Bad memory
1 - 3 - 4 64K memory failure Bad memory
1 - 4 - 1 Address line failure Bad memory
1 - 4 - 2 Parity error Bad memory
1 - 4 - 3 Timer failure Bad motherboard
1 - 4 - 4 NMI port failure Bad motherboard
2 - 1 - 1 64K memory failure Bad memory
2 - 1 - 2 64K memory failure Bad memory
2 - 1 - 3 64K memory failure Bad memory
2 - 1 - 4 64K memory failure Bad memory
2 - 2 - 1 64K memory failure Bad memory
2 - 2 - 2 64K memory failure Bad memory
2 - 2 - 3 64K memory failure Bad memory
2 - 2 - 4 64K memory failure Bad memory
2 - 3 - 1 64K memory failure Bad memory
2 - 3 - 2 64K memory failure Bad memory
2 - 3 - 3 64K memory failure Bad memory
2 - 3 - 4 64K memory failure Bad memory
2 - 4 - 1 64K memory failure Bad memory
2 - 4 - 2 64K memory failure Bad memory
2 - 4 - 4 64K memory failure Bad memory
3 - 1 - 1 Slave DMA failure Bad motherboard
3 - 1 - 2 Master DMA failure Bad motherboard
3 - 1 - 3 Interrupt controller failure Bad motherboard
3 - 1 -4 Slave IC failure Bad motherboard
3 - 2 -2 Interrupt Controller failure Bad motherboard
3 - 2 - 3 <RESERVED>
3 - 2 - 4 Keyboard control failure Bad motherboard
3 - 3 - 1 CMOS batter failure Bad CMOS battery
3 - 3 - 2 CMOS configuration error Incorrect setting
3 - 3 - 3 <RESERVED>
3 - 3 - 4 Video memory failure Bad video card or memory
3 - 4 - 1 Video init failure Bad video card or memory
4 - 2 - 1 Timer failure Bad motherboard
4 - 2 - 2 CMOS shutdown failure Bad motherboard
4 - 2 - 3 Gate A20 failure Bad motherboard
4 - 2 - 4 Unexpected interrupt Bad processor
4 - 3 - 1 RAM test failure Bad memory
4 - 3 - 3 Timer failure Bad motherboard
4 - 3 - 4 RTC failure Bad motherboard
4 - 4 - 1 Serial port failure Bad motherboard
4 - 4 - 2 Parallel port failure Bad motherboard
4 - 4 - 3 Coprocessor failure Bad motherboard or CPU.
9 - 2 - 1 Video adapter incompatibility Use a different brand of video card
Apr 20, 2010 | ASUS P5NT WS (P5NT WS GREEN) Motherboard
Powers up ,but no bios beep or video ,displays error 50 on pc analyzer
Accordin to manual: Error Code – 50
Phoenix (50)Display CPU type and speed.(Beep)=2-2-1-1.(50)Per- form LSL instruction test.[Beep]=none Custom chip set or custom platform.
The POST process stop detecting CPU.
M2N-E SLI use Award/Phoenix BIOS.
Oct 19, 2009 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
I have a mecer computer, LGA 775 motherboard asus and the problem is the computer turns on when switching on and there is no display it beeps non stop . CPU and power supply fans are working ,lights goes...
continuous beeping is Power supply, motherboard, cpu, or keyboard problem. somecases it can also be the memory.
start with the memory then cpu and powersupply and finally motherboard.
let me know if the beep code changes as you change components, count the short and long beeps.
Jan 07, 2009 | ASUS P5VDC-X Motherboard
On Asus p5b-mx motherboard no beep no lcd no bios only fans and l
Check your Video Card. Perhaps Bad driver or a malfunction
Dec 11, 2008 | ASUS P5B-VM DO Motherboard
No Output to monitor, no beeps, fans all OK
Hi karanda,
The green led on the board shows green letting you know there is power to the borad.
Does your GFX card have dual outputs? Try plugging into the other output.
If your monitor light goes from green to amber than your PCI-E is not putting out signal. Pull & re-seat video card.
Did you check Asus to see if your CPU is supported & check what bios version you may need to run CPU?
Chcek here: Check what your M2M-E supports.
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us
Your board only supports these two CPU's
Phenom 9500 (HD9500WCJ4BGD),2.2GHz,95W,SocketAM2+,Quad-Core
Phenom 9600 (HD9600WCJ4BGD),2.3GHz,95W,SocketAM2+,Quad-Core
You need Bios version 0802 in order to run the above CPU's.
Good Luck & kind regards!
Mar 10, 2008 | ASUS M2N-E Motherboard
ASUS P5VD1-X (90MBL3C0G0EAYZ) Motherboard Logo
486 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
