Question about Briggs & Stratton Garden
My Troy Bilt Pony blades will not engage when I place the lever down
wadembly
  • 475 Answers
SOURCE: engine bogs big puffs of white smoke from front
the engine will bog because the cutting blades are either cutting to much grass or the blades are touching the ground making it hard to keep rpm's then it will smoke a bit
Posted on Jun 08, 2009
dolharoobang
SOURCE: troy bilt pony riding mower will go in reverse but
have a troy-bilt riding mower. place a gear in neutral and park it.
it dies instead idling. want to know why?
Posted on Nov 14, 2009
  • 3911 Answers
SOURCE: I have a troy bilt pony and the drive belt to
well i would take a long look at the spring which holds the tension pulley in place. if it is weak, or not connected correctly, there will be inadequate tension and the belt can come off. I would also take a look at whatever fasteners keep the deck in place as if it is not kept to the rear, there again will be too much play in the deck belt.
Posted on Apr 06, 2011
  • 32 Answers
SOURCE: i have a troy bilt
Those units are self adjusting. No way to adjust it. It sounds like you have a bad idler pulley or a bad spindle bearings, which would cause the pulleys to be out of alignment.
Posted on Sep 20, 2011
waynepwelker
  • 25 Answers
SOURCE: I have a troy bilt riding mower blades will not engage in the 1 or 2 deck setting
There is a spring attached to a tensioner that probably came unhooked while changing the belt. Higher deck settings push the deck backwards enough to spin the blades, the lower setting need the spring tensioner to take up the slack in the belt.
Posted on Jun 27, 2012
I have a Troy Bilt Pony riding mower. The blades will not engage to cut when the lever is turned on. Prior to this happening today, the blades would Not Disengage when lever was turned off.
Someone will need to take the deck apart and service it.
You may need new parts in some places.
That problem is lack of service.
Most other things you have today do not need service anymore, but lawn equipment does.
You will need to clean it and lubricate it regularly, for example: it must be cleaned after every use, and must be lubricated after every 5 cuts, or twice a year, which ever occurs first.
God bless your efforts.
Jul 03, 2017 | Troy Garden
Troy Bilt 33" walk behind mower blades won't turn on.
Troy-Bilt Lawn Mower Blades Won't Engage - Model ...
www.repairclinic.com/...Mower/...-/Troy-Bilt-Lawn-mower-blades-won-t...
Most Frequent Causes for Lawn mower blades won't engage. See All Lawn Mower Parts for model 13AP60TP766. Cause 1 PTO Clutch. If the blades don't rotate the electric PTO clutch might not be engaging. ... Lawn mower wheels don't turn ...
Nov 08, 2015 | Troy Garden
Tines wont engage on my troy built pony. How can i fix it?
The lever for the tines moves easily? Is there an adjustment on the linkage that may need tightening?
May 11, 2012 | Troy-Bilt Pony Garden Tiller
Cant engage parking brake on troy bilt pony
you need to hold the lever until the pedal is released
May 08, 2012 | Garden
I have a troy bilt 17.5 hp pony riding manual lawnmower and my belt located above the deck keep jumping off track after engaging the blades a couple of times,do i need to tighte my belt,if so how?
Sep 20, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
I have Troy Hydrostatic 46" when I attempt to
If you lower the blade deck and get down near the mower, you can see the blades belt on top of the deck. If it is intact, with the engine off, have someone try to engage the blades. A tensioner should move into place to tighten the blades. If it is not, follow the engagement lever to under the dash to see if there is a cable broken or a rod detached.
Post back.
Gary
Sep 11, 2011 | Troy Bilt 22HP Hydrostatic 46" Riding...
Tiller blades barely turns and you have to hold down forward lever to get them to keep turning
belt worn and too loose, maybe pulley slipping on the shaft, shear bolts or pins broke on tines. worse case sheared key in tranny case for drive gears.
May 02, 2011 | Troy-Bilt Pony Garden Tiller
I have a troy bilt pony and the drive belt to engage to blades keeps coming off. I have replaced the belt and the pully what else could it be?
Apr 05, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
Troy Bilt Pony s/n P92695 5Hp Briggs. Drive wheels won't stay engaged. Lever jumps out. Can hold lever in with not much effort and will stay engaged. Any adjustments?
yes there is an adjustment. follow your shift lever down and you will find a block of iron with 2 bolts holding it. you will also see ond the lever itself a spring loaded pin.most of the time this pin gets gummed up and does not engage the block completely.clean and ensure the pin moves freely. if this does not solve the prob then the block can be moved up or down by loosening the bolts.
Sep 06, 2009 | Troy-Bilt Pony Garden Tiller
Troy bilt horse pto clutch will not disengage
The problem is lack of lubrication in the pto coupling. Losen the two swing bolts carefuly,block the front under the motor. Separate the tine transmision from the housing and grease both sides with as much grease as you can work in. Work the lever as you do this. Should fix the problem.
Jan 17, 2009 | Troy-Bilt Pony Garden Tiller
Garden Logo
162 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
