Question about Kyocera Mita FS 1000+N Laser Printer
Paper sensor I am trying to buy a paper sensor (part of the fuser) for this printer. You seem to need to buy the complete fuser to get hold of this small part. Email is [email protected]
  • p257 May 02, 2008
    I live in Roma in Western Queensland. However, I can get to Brisbane, and will happily pay postage for this small part.
    Its Kyocera part number is SENXGP1A73A
  • Anonymous Nov 14, 2008
    my paper sensor is lost and i need to print cause i work for a business is there any way to go around this.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 58 Answers
Where in Australia?
Posted on May 01, 2008
  • justin May 03, 2008
    email me your details and I look in the spares when I get to work tuesday. Email is [email protected]. I am in Toowoomba
SOURCE:
Fix paper jam 2 on a Samsung CLX-3170 printer
paper jam 2 is a jam in the fuser/exit area.
did the paper jam come out in one piece? if not reassemble the torn paper to see how much is still inside.
sometimes there will be a small fingernail size piece of paper holding open the fuser/exit sensor flag.
sometimes the sensor flag itself is dislodged and needs reassembly.
attached is video in how to dissassemble the printer if required
Sep 24, 2014 | Samsung Office Equipment & Supplies
Erro code e02 in toshiba estudio 181
hello
dear you have to verify all the exit sensor related
1. do u have look on fuser unit drive gears.
2. is the exit rollers are good some time exit roller got damaged they don't hold hold paper to run out from machine.
3. do u have clean the exit sensor.
4. do you have verify that the exit sensor actuator is free to operate the sensor.
5. some time exit sensor actuator broken.
Aug 28, 2014 | Office Equipment & Supplies
I have canon 2900 and it having every time paper jam problem please help me
Analyse where paper jamming is happening? remove right left back & top covers..press door switch, shoot print command. Remove cartridge after paper jam, check upto where paper travel?
1. If paper jams with curl foldings in cartridge bank area..before entering the fuser assmbly..
# Teflon sleeve not rotation properly due to this paper not passing through it result curl foldings..Replace teflon sleeve..
2. If paper passed fuser assmebly little bit(near about 2-3 inches.
#Problem with paper out sensor/flag. clean sensor, check sensor flag movement & spring.
3. Check registration paper sensor located back side.
# while passing the paper, sensor flag has to act & once paper out it has to reach home,other wise paper jam error will appear.. check flag spring.
Aug 27, 2012 | Office Equipment & Supplies
I have a problem of when printing out that is only white paper that take it out even I changed new toner and no change . Pls u have any solution give me the solution .
For a laser printer, printing is a few steps:
* receiving the print-data (which seems to be working fine)
* putting an electrostatic charge on the drum, by using a laser to draw the print-image onto the drum (working?)
* forcing toner into contact with the drum, but only the "charged" part of the drum holds the ink (working?)
* using heat from the fuser-unit to "melt" the toner into the paper (working?)
* ejecting the paper
If the paper is warm, then the fuser is working.
If not, then your fuser needs replacing.
Either take the printer to a qualified printer technician, for professional trouble-shooting, or buy a replacement printer, and responsibly recycle the old printer.
Jul 07, 2010 | Office Equipment & Supplies
Printer stops at the exact same point every time.
The paper sensor in the fuser unit is faulty. You will need to replace the fuser unit.
Aug 05, 2009 | Samsung CLP-315W Laser Color Printer
202 paper jam
I have this problem too, but the 2 sensors on the fuser are not stuck and seem ok to me. Any other suggestions?
Mar 06, 2009 | Lexmark T632 Laser Printer
Paper Jam in R300 Epson Stylus which I can't clear
Look for any debris, bits of paper, etc in the printer. You can try using a can of compressed air to blow out any debris inside. Should that fail, try a hard reset: Unplug printer from PC and power source, wait about 5 minutes and reconnect everything and see.
The paper jam error could be due to one of the following:
  • Check for paper in the paper tray
  • Check the size of the paper in the paper tray to see if it is the same as what the printer is set for.
  • Defective D-roller
  • Debris in the paper path
  • Gears not turning or broken gear
  • Defective paper tray
  • Broken input sensor flag
  • Defective input sensor board
  • Defective system cable 2
  • Defective system board
  • Exit Sensor flag (Fuser)
  • Exit Sensor board (Fuser)
  • System cable 1
If there is no bit of paper or debris stuck in the rollers, it would indicate something more serious, and in need of servicing. If your machine is under warranty, I suggest you take it back to the shop and get it replaced.
If your warranty has run out, then you'll either have to get it serviced or buy a new printer (whichever works out cheaper for you)
Hope that helps!
Jul 04, 2008 | Office Equipment & Supplies
202 pam jam
usually it means that a sensor in your fuser is bad. If you have a P.M. Kit replaced the fuser and clean the printer.
but before you do, make sure that you have cleared all jams, including in the fuser.
Its probably time for a Preventive Maintanence
Jun 13, 2008 | Lexmark T630 Laser Printer
Phaser 7300dn Fuser problem
I don't think so. I have had this problem when I'm using a thicker paper and the paper type is set wrong in the printer.
The printer seems to adjust something based on what paper you say is printing. Try pulling the paper out of the printer, then re-inserting it and then choosing a different paper type - one closer to what you are using - or choose the "special" paper type.
This should solve your problem.
Jun 04, 2008 | Xerox Phaser 7300DN Laser Printer
Error 13-jam paper HP Laser 4+
HP LaserJet 4, 4m, 4 Plus and 4m Plus Series Printers - False Error Message 13 PAPER JAM ISSUE: After clearing all jammed paper from the HP LaserJet 4, 4m, 4 Plus, or 4m Plus series printer, the display still reads 13 Paper Jam . Even after cycling the power off and then back on, the error remains. SOLUTION: Open the rear door of the printer. There is a paper sensor near the upper right hand corner of the fusing assembly (just below the right edge of the long yellow warning sticker on the fuser) that can cause paper jam error messages even when there is no jammed paper in the printer. Toggle the thin black plastic lever up and down to make sure it is not stuck or sticky. The lever should be in the down position before closing the back of the printer. If the lever is stuck or missing, the printer will generate a false paper jam message. Hope it will help you !
Apr 02, 2008 | HP LaserJet 4 plus Printer
Kyocera Mita FS 1000+N Laser Printer Logo
98 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Adorjani Laszlo
AAAA262430
Marvin
Marvin
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
